Old 03-05-2007, 10:37 PM   #226
Hart_Rod
Hart_Rod's Avatar
Re: LFD's low buck truck build!
Kevin,
No worries, . I think I have a set found locally. Hopefully, Seanu can use what I have left. Thanks,
R
Hart_Rod is offline   Reply With Quote
Old 03-06-2007, 12:29 AM   #227
Rokcrln
Rokcrln's Avatar
Originally Posted by Hart_Rod View Post
Kevin,
R
Sounds good I want some spy pics as it takes shape for a future idea I have for a family build.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-06-2007, 01:23 AM   #228
PBFAB.COM
PBFAB.COM's Avatar
Originally Posted by Rokcrln View Post
Sorry it sucks getting old as Porter keeps pointing out to me
Just wait til that little one is running around... then you will really feel old!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-06-2007, 08:41 AM   #229
Hart_Rod
Hart_Rod's Avatar
So if I have one in high school, does that mean I'm really, really old?!
Old 03-06-2007, 09:44 AM   #230
PBFAB.COM
PBFAB.COM's Avatar
Ancient!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 03-06-2007, 11:56 PM   #231
Hart_Rod
Hart_Rod's Avatar
Kevin
LFD Inc.
Here's a spy pic, .
Old 03-07-2007, 01:02 AM   #232
Rokcrln
Rokcrln's Avatar
Yep much better!
Old 03-07-2007, 11:18 PM   #233
Rokcrln
Rokcrln's Avatar
Well I only had a few minutes tonight to work in the shop but I had enough time to build 2 more steel saw horses so I will pull the bed in the next day or so to start checking the frame and getting my next mods lined up. It will include a gas tank, air bags just for load leveling, compressor and tank (pulling into a station with a trailer is a pain!), shorten the frame 12", brake lines and Driveline than new exhaust!
Stay tuned..
Kevin
LFD Inc.
Old 03-08-2007, 04:43 AM   #234
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
its looking good..lover to read your posts..lets me know what im not going to do by myself..lol man i need to learn to weld..lol
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 03-08-2007, 10:02 PM   #235
Rokcrln
Rokcrln's Avatar
Well I think I have the youngest kid (with my wifes help) working on these trucks My son Taylor is the one in the yellow circle (about 6 months conceved )
We got the bed off so I could start sizing up the frame for the tank and choping.
Kevin
LFD Inc.
Old 03-08-2007, 10:06 PM   #236
rodstored-72
chevy truck fan
rodstored-72's Avatar
congrats!!!! i felt the same way when my little one showed up. she likes daddy's green "noisy" truck...
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 03-08-2007, 11:22 PM   #237
franky69c10
chevy runs deep
franky69c10's Avatar
congrats!!!!
franky69c10 is offline   Reply With Quote
Old 03-09-2007, 10:18 AM   #238
1lowdiesel
1lowdiesel's Avatar
has anybody ever tried cutting down the bed sides w/a plasma cutter. i see everyone uses a cutoff wheel.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 03-09-2007, 01:52 PM   #239
HeavyD
HeavyD's Avatar
Slots look sooo good on these trucks.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 03-09-2007, 10:26 PM   #240
Rokcrln
Rokcrln's Avatar
Here are my thoughts on that one. I have a very nice plasma and I still used the cut off wheels. I feel I have more control and if you use very thin wheels you will get alot less heat and that means less warpage. Also you will have a much better edge to work with for welding back up. I only use my plasma for rough fitting body parts then use the cut off wheel or snips for fine fitment.
Kevin
LFD Inc.
Old 03-09-2007, 10:35 PM   #241
Crank
Crank's Avatar
I personally have never had any luck cutting thin metals with a Plasma, maybe setting were wrong for thing stuff, but it'd cut 3/8" like it was cool.
Brandon
Crank is offline   Reply With Quote
Old 03-10-2007, 04:04 AM   #242
watahyahknow
watahyahknow's Avatar
used to use a plasma cutter on thin steel and zinkprimed steel at that .... lot of green smoke and headacke and it gave burs too like when you cut steel with gas , you need to move the nozle pretty quick with the thinner steel so a guide would be nice
a anglegrinder is cheaper and in my opinion give cleaner cuts as long as you can get the machine to where you need to be .
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-10-2007, 01:15 PM   #243
Crank
Crank's Avatar
Well yea, I've tried it, but I always overrun the cut or end up with a big hole in it from too much heat.... Haha. You know what, that was with a torch I was thinking about!!!! Nevermind. LMAO
Brandon
Old 03-10-2007, 10:51 PM   #244
Rokcrln
Rokcrln's Avatar
Well I took a personal day today While the owner of Lemon Drop was hard at work finishing up the misc block sanding in the shop I was out side working on Low Buck. I finished up the bed welding and then started pulling dents, their sure were alot of them! I thought this bed was rough but not this rough! Well after a few hours of pulling and filling it started to get with the program. I have a few hours left with the long board and then it will be ready for a nice heavy coat of high build primer. Here are a few pics.
Kevin
LFD Inc.
Old 03-11-2007, 12:45 AM   #245
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice work trucks really starting to come together gotta love the fun builds..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 03-11-2007, 05:18 PM   #246
Rokcrln
Rokcrln's Avatar
The bed is ready to go back on the frame once it has been cut down. I still have some blocking and touch up on the bed but right now it is in better shape then 98% of beds out their. Sure feels good to have this part done.
So I spent an 8hr day cutting down the bed and tacking it back together. Another 8hr day doing body work and 3hrs today sanding and primming. Altogether I have spent about $150 on sandpaper, body filler and primmer.
Kevin
LFD Inc.
$1117.64
62hrs
Old 03-11-2007, 05:33 PM   #247
onetonk5
Cereal Killer
onetonk5's Avatar
are there any concerns with the top body line not matching....looks like you did a great job but what did it take to make those lines flow so well?
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 03-11-2007, 09:14 PM   #248
Rokcrln
Rokcrln's Avatar
It took some hammer and dolly work but they should be real nice once it is done.
Kevin Lewis
Old 03-11-2007, 09:36 PM   #249
corn
Did you by chance take any inside the bed? Looking good BTW!
corn is offline   Reply With Quote
Old 03-11-2007, 10:09 PM   #250
Rokcrln
Rokcrln's Avatar
Here are some inside bed shots but goes easy on me because that is just welded and ground smooth. I do not plan on any body work to the inside because I think I want to get it line-x'd. This is going to be a work truck after all.
Now after more thinking about it the out side will be very good but that is with alot of metal and body work. Would I do this on a show truck and expect it to be flawless, No. But for a super clean street truck it will be great. Also I am not trying to fool anyone with this being a short bed. It is a Low Buck build that will turn alot of heads when going to the shows (staying out in the parking lot) or pulling my trailer. If I wanted to fool people first (I would not post it on here) I would weld up the center stake pockets and also use patch panels for the front quarter panels because the wheel opening is a little different at the leading edge.
So if you want to try this don't expect it to turn out like nothing was ever done unless you are good with a hammer, dolly, filler and sanding blocks. Even then I would not do this to a high end build but then again that is why this is called "Low Buck".
Kevin
LFD Inc.
