#226 |
VA72C10
![]() Join Date: Mar 2008
Re: Project Orange to Green
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#227 |
Now time to feel like your getting someting accomplished after your done with that frame!......lol
#228 | |
On the fast track to nowhere..
![]() Posted via Mobile Device
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#229 |
Since you love welding so much you can come over and weld up my new roof and roll pan! lmao.
#230 |
Finally got some work done. The frame is cleaned, primed and undercoated. I also got some of the other parts painted and installed.
#231 |
67cheby
![]() Join Date: Sep 2008
LOOKING GOOD !! keep it up
#232 |
VA72C10
Nice progress!!! Looking NICE!
#233 |
About time you did something!
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
#234 |
Very nice progress! more pix please
1950 chevy PU work in progress. |
#235 |
Still Learning
Frame looks great. Can't wait for more pics....
#236 |
Any new updates Mike???
#237 | |
![]() Join Date: Apr 2008
I just picked up a rack out of a late 90's mustang and I was wondering what i should expect with the mod? Did yoy use the same pump off the Chevy or did you have to use the Ford one? Did you notch the frame because you were going to lay frame and you needed clearance and would I have to do the same notch being only lowered 4 inches up front? and I am assuming that you got some sort of coupler to marry the two makes together at the rod ends. What steering mods are necessary? did you fab your own cross member to mount it to? I cannot see from the picture how you mounted it. Thanks, Mike
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#238 |
He has a dropmember.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
#239 | |
#240 |
Thanks Mike, I did not know the drop member had holes that lined up for the rack. I will just fab one up to match the holes to replace my stock forward cross member. Thanks for the help.
#241 |
No problem
#242 |
No great progress but I have been getting some parts cleaned, painted and installed.
![]() ![]() ![]() ![]() ![]() Posted via Mobile Device
#243 |
Looks good Mike, What is the mod for your bed? Are you going to raise the bed floor and weld it in the new location?
#244 |
Probably won't be a bed floor at all. I'll have to see how much room is there after the fuel cell is in. I would like to do a raised wood floor but if it's going to be 3 or 4 inches from the rail there's really no point.
#245 |
hey if u dont mind i would like to come by and check out ur project. i need some ideas to get my start need someone to help point me in the right direction.
#246 | |
#247 | ||
![]() By the way, I bought some of those rubber isolators for the compressors and they make a world of difference!
#248 |
Cool, I'm glad they worked.
BTW, my bed is now 13" deep after raising the bed floor 6.5", of course I'm not quite as low as you are in the rear. The top of the ice chest sticks out, but it "should" stay in the bed, even during evasive maneuvers. ![]()
#249 |
Hey , I just noticed that your compressors are mounted laying on their side. According to one of the guys that works for Viair they should always be mounted with the cylinder pointing up to help them dissipate the heat from the motor.
Here's a link to the S10 forum where they are discussing this.
#250 | |
