08-06-2007, 01:20 PM | #226 |
Questionable
Re: Killers 5.3L install
in case you need some thoughts or ideas, or seeing how others are doing it:
http://www.nahrods.com/products/index.php note his pricing and options at the bottom. overally, very reasonable - that is a bit of a tougher install, but ... prices are very reasonable. you could seriously use that general concept as a business idea for yourself.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-06-2007, 01:29 PM | #227 |
thanks shifty, ill have to use that idea.
08-07-2007, 09:57 PM | #228 |
got the frame and suspension back from the powdercoaters....
08-07-2007, 10:00 PM | #229 |
I thought we were goin with "cloud blue"...and where is my jackstand?
I think they turned out nice...
R.I.P. Killer 71 10/26/07 |
08-07-2007, 10:02 PM | #230 |
Is that 4 sale sign intended for your estate or Killer?
08-07-2007, 10:06 PM | #231 |
A guy with a truck
Looks good. Hurry up and send her back to Shreveport so I can see it in person. Not running the exhaust through the crossmember?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
08-07-2007, 10:18 PM | #232 |
08-07-2007, 10:20 PM | #233 |
no, we want the e-brake functional... the exhaust would interfer with the cable.... also at first we didnt plan on doing a drop, now we are.......
08-07-2007, 11:30 PM | #234 |
Everything looks nice .... EYE Candy.
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
08-08-2007, 10:26 PM | #235 |
started assembling the frame today...majority of the day i spend cleanig steering parts and cleaning/ sanding brake lines... the new rear ECE trailing arms are SWEET, they are totally boxed and are a heavy guage, i know this cause they are HEAVYYYYY..... installed front x-member, trailing arms, fuel lines, brake lines... also brought over a buddy of mine to lend his hand on the cab...
08-08-2007, 10:30 PM | #236 |
Nice work don...i was hoping for some updates! While i'm thinkin about it...what differential fluid will you be using?
08-08-2007, 10:56 PM | #237 |
80/90 castrol, do you have a preference?
08-09-2007, 01:00 AM | #238 |
The powdercoating looks great!
I read the entire thread for about the 3rd time looking for this, so forgive me if its been answered. Where did you get the engine stands, mounts, and adapters from? |
08-09-2007, 08:44 AM | #239 |
A lot of guys are using synthetic and was wandering?
08-09-2007, 09:21 AM | #240 |
08-09-2007, 09:24 AM | #241 | |
08-09-2007, 09:40 AM | #242 |
I wanna say use synthetic as i believe that's what was in it...but i'll check with my guy who filled it and let you know what was in it before u drained it!
08-09-2007, 12:34 PM | #243 |
Too many trucks? Nah...
Fantastic progress on this build, as usual. I am quite envious of how that frame looks.
08-09-2007, 02:47 PM | #244 |
On the fast track to nowhere..
Looks nice. I might have to plan another stop by your place to check it out
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
08-10-2007, 03:31 PM | #245 |
getting some more assembly stuff done, while waiting on the suspension stuff to arrive...
got the steering box, intermittent shaft, ideler arm(still need to add washers under the head of the bolts), tie rods painted and installed, trans cooler on, and fuel cell mounted and plumbed.. Last edited by 68 short step; 01-10-2008 at 08:55 AM. |
08-10-2007, 05:57 PM | #246 |
Man, this is the fun part! Get to see it all come together!
08-10-2007, 09:24 PM | #247 |
Fabulous work my good friend...any updates on the cab?
08-10-2007, 10:37 PM | #248 |
the cab will be getting painted tomorrow... im gonna locate the bulkhead connection tomorrow, then do a little more final sanding then shot it... i get some more pics of it tomorrow...
08-10-2007, 10:49 PM | #249 |
computer illiterate
what is the can just outside of the feul tank 2 lines in and 1 out
72 2wd blazer 72 swb 4x4 |
08-10-2007, 10:54 PM | #250 |
Fuel pump/fuel pressure regulator.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
