Old 12-05-2008, 01:12 AM   #226
68chevy68
68chevy68's Avatar
Re: Newbie with a new build thread
Well if I do the wrap around part, I would extend the top part all the way down the door. That half round at the top of the wrap around part. The wrap around part would also become a permenant part of the door. I am going to try and find another arm wrest that is more of the 60's car stuff with some chrome and such.
68chevy68 is offline   Reply With Quote
Old 12-05-2008, 02:08 AM   #227
Frizzle Fry
Frizzle Fry's Avatar
I think if you extended that 1/2 round down the length of the door like you said and maybe taper it down to nothing that would look killer. But then you'll have to mod your door panels too. But I'm sure you are aware of that. Truck's lookin good!
Frizzle Fry is offline   Reply With Quote
Old 12-05-2008, 08:35 AM   #228
71tahoe
71tahoe's Avatar
I agree a new arm rest would tie it together.
With the wraparound, the stock armrest doesn't look right. Maybe a custom one that extends between the handles and follows the bottom curve of the wraparound.
71tahoe is offline   Reply With Quote
Old 12-10-2008, 01:16 AM   #229
68chevy68
68chevy68's Avatar
I need to find an armwrest that will look right. I am also not going to use the 61 impala steering wheel in this truck. I guess it will have to stick around for another project. Its just a little bigger than the stock one and thats not going to cut it. I need all the room I can get.
Old 12-27-2008, 08:21 PM   #230
68chevy68
68chevy68's Avatar
Got some new toys for Christmas!!!!
Made this for the chevelle
Old 12-29-2008, 10:48 PM   #231
68chevy68
68chevy68's Avatar
The weather was outstanding today for December. I mostly cleaned my shop. I did however finish welding the bearclaw latches in. They have only been tacked in place for a year... My next step is going to be the fabrication of the fuel filler. I have not decided on its exact location as of yet. Its either going behind the tail light or the marker light. The tail light will keep the inside of the bed stock which is good with me. Sorry, no pictures this time.
Old 12-31-2008, 02:30 AM   #232
68chevy68
68chevy68's Avatar
Another nice day today. Finished grinding the welds on the bear claw latches. Made a patch panel for the Edsel dash where the speaker used to be in the top. I also stared working on the ends of the dash. I think I have a game plan now and hope it turns out all right. I also welded some new metal in around where the steering column comes through the dash. I will have pictures soon.
Old 01-02-2009, 03:14 PM   #233
muddobber
muddobber
where you at in arkansas
muddobber is offline   Reply With Quote
Old 01-02-2009, 10:01 PM   #234
68chevy68
68chevy68's Avatar
Bryant, right outside little rock.
Old 01-04-2009, 10:03 PM   #235
68chevy68
68chevy68's Avatar
Got some work done on the dash. I think I have a plan now. Let me know what you think.
Old 01-04-2009, 10:07 PM   #236
68chevy68
68chevy68's Avatar
and some more.
To the new brake we go.
Old 01-04-2009, 10:13 PM   #237
68chevy68
68chevy68's Avatar
Here are some pictures of some of the other small stuff I worked on as well.
I filled in the gap between the steering column and dash. Compare the next couple of pictures.
Patch panel for top of dash made and tacked in.
Also finished most of the welding up on the passenger side bearclaw latch. Still have a little to do.
Old 01-04-2009, 11:33 PM   #238
robmrtnbb5
robmrtnbb5's Avatar
Realy like what ur doing with the dash lookin good
bondo bob
bondo bob
http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build
robmrtnbb5 is offline   Reply With Quote
Old 01-04-2009, 11:44 PM   #239
nuke1
nuke1's Avatar
lookin really good,, that dash is coming together nicely, i too just got a shrinker/stretcher, great pieces.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 01-04-2009, 11:58 PM   #240
68chevy68
68chevy68's Avatar
Thanks guys. I have been putting this off for long enough now. I had to work on something with all these new toys. It still needs some tweeking, but the idea it there. I will work the metal a bit more when I pull the dash back out finish the welding, assuming I can get it back out.
Old 01-05-2009, 02:07 AM   #241
VA72C10
VA72C10
VA72C10's Avatar
Looks great...will be following along now.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-05-2009, 03:44 AM   #242
68chevy68
68chevy68's Avatar
It is now 1:50 in the morning and the driver side of the dash is almost complete. I still have to take the dash back out and finish welding it all up. I have some bracing I want to put in the middle as well. The stock truck dash supports around the steering column will have to be raised around a 1/4" or so or it will look dumb.
Old 01-10-2009, 09:45 PM   #243
68chevy68
68chevy68's Avatar
My buddie has these sitting around so I decided to try them on and see what they looked like, not the style I am after, but they fit well.
Old 01-12-2009, 12:36 AM   #244
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Looking good! I like the dash idea, should look great all welded and cleaned up.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 01-13-2009, 01:02 AM   #245
68chevy68
68chevy68's Avatar
Here is a fast rendering of what I would like the truck to look like when its finished unless I change my mind, and that happens a lot.
Old 01-13-2009, 06:25 AM   #246
Very Nice!!
Old 01-13-2009, 02:47 PM   #247
BACKYARD88
BACKYARD88's Avatar
Sweet!
-Mike Owen-
Old 01-13-2009, 03:43 PM   #248
my67chevytruck
Under Construction
my67chevytruck's Avatar
looking good.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-23-2009, 12:46 AM   #249
68chevy68
68chevy68's Avatar
Now if I can just get it to look like the picture........I see a ton of sanding and blocking in my future...
Old 02-05-2009, 09:46 PM   #250
68chevy68
68chevy68's Avatar
Got the dash mostly welded in. I still have some welding to do on the ends of the dash but here is where its at so far. Enjoy.
