Old 03-17-2013, 11:14 PM   #226
TJ's Chevy
TJ's Chevy's Avatar
Re: Tricked-out Chevy six cylinder engines
Originally Posted by KroAutomotiveInc View Post
my org 230 shes still running strong heres a pic after i build the cold air intake for it.
How well does yer cold air intake work? Nice little motor you have.
TJ's Chevy is offline   Reply With Quote
Old 03-17-2013, 11:15 PM   #227
TJ's Chevy
TJ's Chevy's Avatar
Is anybody here interested in buying a 292 6 cylinder?
Old 03-18-2013, 10:08 AM   #228
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Just agreed to pick one up from another member this weekend. I'm sure it will go fast though.
Just FYI, you need to be a paying member to advertise for sale though... so you should set that up before you go any further.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 03-18-2013, 03:09 PM   #229
TJ's Chevy
TJ's Chevy's Avatar
Thanks for letting me know.
Old 03-19-2013, 06:20 PM   #230
KroAutomotiveInc
KroAutomotiveInc's Avatar
Thank you it works great dropped the idle to 650 witch i could never reach with just a aftermarket air cleaner on there and the most noticeable difference is in 4th gear it really eats up that air and takes the truck to highway speeds much faster then before.
KroAutomotiveInc is offline   Reply With Quote
Old 03-19-2013, 09:49 PM   #231
TJ's Chevy
TJ's Chevy's Avatar
Sweet. I have a couple of 292 6 cylinders and one runs(my half ton) and the
other sat for 13 years(my 3/4 ton) it doesnt run....yet....Planning on swapping it for
a v8. 6 cylinder is to small for a heavy load at free way speed.
Old 03-19-2013, 09:51 PM   #232
TJ's Chevy
TJ's Chevy's Avatar
Seems like the cold air intake act as a small turbo. I should try it. Seems like a graet
idea.
Old 03-19-2013, 10:03 PM   #233
KroAutomotiveInc
idea.
yeah it dose great without it you are sucking air coming right off your exhaust running at 700 degrees! its a 1960's heater box if you haven't already noticed you can check it out on my thread the building process anyways.
Old 03-19-2013, 10:39 PM   #234
hemifalcon
What do you categorize as a "heavy load"??? Anything more than a car on a trailer while also pulling the arse of the '65 Suburban it was attached to??
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 03-19-2013, 11:11 PM   #235
TJ's Chevy
TJ's Chevy's Avatar
I consider a haevy load a full load of wood in the bed and a full load of wood in a 10
foot trailer.
Old 03-21-2013, 03:37 PM   #236
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by K5 Addiction View Post
I've been lurking on this post for a long time waiting till I could finally post my six. It's almost done just exhaust and a few more lines to run but here she is. I'm also including a before pic.
What type of thermostat housing you using. Is that stock? I am havivg a hard time
trying to hook mine up. My thermostat housing is slightly differant.
Old 03-21-2013, 03:41 PM   #237
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by baddawg65 View Post
1965 K20 in progress 292.
Sweeet 292 ya got there! What did you do to it? I am restoring one just like it.
Old 03-24-2013, 04:21 PM   #238
TJ's Chevy
TJ's Chevy's Avatar
Where did you get the box to holde your pipe to your carb? Looks home made to me. If it is you gotta make me one! Nice job, looks good!
Old 03-24-2013, 04:24 PM   #239
Sharps40
N2Trucks, KroAutomotiveInc
Where did that awesome finned stuff come from and what kind of carb is that under there, don't look like a Rochester from here.
Sharps40 is offline   Reply With Quote
Old 03-24-2013, 04:48 PM   #240
TJ's Chevy
TJ's Chevy's Avatar
I have to agree with ya. That dont look like a rochester! I think its a weber.
Old 03-24-2013, 05:58 PM   #241
KroAutomotiveInc
yes thats a holly weber 2bbl and the carb hat and tubing was all built using abs plumbing pipe fittings on my blog it shows the full processes of the build and my build thread also gets the point across of how it was built both in my sig.
and the finned stuff im guessing your talking about the stuff over the front of the intake or back of the heater box lol its just expanded metal in a cool size for using it for stuff like that its also in my hood vents.
Old 03-24-2013, 06:28 PM   #242
TJ's Chevy
TJ's Chevy's Avatar
I think your gmcs are awsome! I hope to restore one...one of these days!
Old 03-24-2013, 06:33 PM   #243
KroAutomotiveInc
Thanks there so much fun and if you think out of the box and refurbish whats there you can be on the road for pennys compared to some of the stuff around here!
Old 03-24-2013, 07:04 PM   #244
Sharps40
Actually, the side cover, the valve cover and the air cleaner cover.
Hmmm,,,gotta check out holly weber 2bbl. Bet it don't leak like a Mod B
Old 03-24-2013, 07:10 PM   #245
TJ's Chevy
TJ's Chevy's Avatar
I scraped my rochester. Leaked kinda. I changed to a two barrel holley and adapted
it to my one barrel.
Old 03-24-2013, 07:19 PM   #246
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by melhilburn View Post
Here is mine - Keeping it real
Looks good to me!
Old 03-24-2013, 07:47 PM   #247
joeydirt
can someone with a 4bbl 292 chime in with an mpg? Is it true they get better mpg with a 4bbl
joeydirt is offline   Reply With Quote
Old 03-24-2013, 07:57 PM   #248
KroAutomotiveInc
I dont have a 4 barrel on my 230 but i have done tons of research on it and will do it one day. To get out what your putting in with the 4 bbl you must have dual exhaust. A fresh motor also wouldn't hurt but just my guess here your going to be looking at the mpg of a small block 350. If your looking for mpg my 230 runs 15-17 around town depending where my foot is and hits 20 mpg on the high way but ive spent a lot of time making it that way.
Old 03-24-2013, 08:04 PM   #249
KroAutomotiveInc
Heres a picture of a split manifold easy way to get dual exhaust also doesn't take away your exhaust heat to the intake.
Old 03-24-2013, 08:16 PM   #250
KroAutomotiveInc
Ive also found with my 230 that removing the motor fan and using an electric fan has made a noticeable power increases to the motor lol!
