#226 |
Re: How about some pics of High Performance haulers.
1st engine pic is a mostly stock 87 octane 500 cadillac, went 12.97 at 100. 2nd engine pic is current engine, although it has a 4781 holly and hei now, went 11.66 at 113.96 so far. Welded valve covers were req'd due to firewall clearance issues and shaft roller.
3rd engine pic is a twin turbo'd engine that I ran two years ago. Turbocharger were too small and it didn't run like I wanted, so it was sold. Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. Last edited by dave brode; 11-22-2009 at 06:29 PM. Reason: new track best |
#227 |
Dave, love the looks of your truck!!
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
#228 |
Have already posted in the '73-'87 section, but thought I would put them here also. Been running without a hood for a long time and finally had it cut and the injector plate and hat spaced 2" for better exposure. No track times, no dyno numbers, just my daily cruiser....
#229 |
Thanks, Joe. Mine's a good 20 footer. Yours looks good. I pity those street radials.
Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108. Last edited by dave brode; 11-16-2009 at 11:44 PM. |
#230 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#231 |
![]() ![]() took it to the track a week ago and stunk the place up bad track horrible air couldnt get it to hook so went home. only thing worth anything was it went 105mph in the 1/8th from half track which is when it finally hooked up. dj how the beast comin along
69 stepside 489ci 60ft---- 1.46 660ft--- 6.570@105.95 1320ft-- 10.37@127.01 |
#232 |
#233 |
hey coggedbelt75 that is a beautiful truck almost everything i want to do to mine. how does the stroker like the blower?
#234 | |
Paul1969, now that's what I'm talkin' about!!! Very nice stepside!!
#235 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Do you have a picture of your bed? The Tubs?
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#236 |
heres a few hope it helps
69 stepside 489ci 60ft---- 1.46 660ft--- 6.570@105.95 1320ft-- 10.37@127.01 Last edited by paul1969; 11-29-2009 at 05:45 PM. |
#237 |
Thanks!
#238 |
Paul1969 sweet truck. Good luck getting her sorted out. My progress is slow but i'm gonna start pushing some of my help to get things rolling along.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#239 |
Here is mine, had it out 3 times this fall. Best time so far was 1.72 60 foot ,12.72 @105 still tuning suspension and engine,hoping for 11.9x in the spring.
#240 |
Ready to go fast!!
hey 67shortbox.... what size motor and power you got?
454 block .30 forged aluminum pistons steel crank valve job Holley Strip Dominator intake 1030cfm holley carb, 250 plate shot roller rockers Erson Solid cam split duration 307/310. .575/.595 lift milodon oil pan fab. aluminum valve covers 4 bolt main splayed anodized caps all studded |
#241 |
cool truck what's done to the motor?
#242 |
.030 over 427 (431) cast crank ,forged TRW pistons,approx 10.7-1,241 Casting heads 113cc with 2.30/188 valves.Comp 282s solid ft cam .244/252@.050 590/598 lift,RPM intake ,750 df/dp holley,2 inch Hooker Comp headers 2455-3 black ceramic coated, 350 turbo trans,too small of convertor lol and a 12 bolt posi with 3.73s. Over winter I am changing the springs and shocks front and rear,adding an air bag on the pass side,convertor and hopefully going to a 9 inch F**d rear. Works pretty good now considering it isn't even broke in yet, but there is alot more left,just need to tune the suspension and engine. Brian
#243 |
nice truck. I have a 431 also
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#244 |
Ready to go fast!!
what kinda power you makin shortbox?
#245 |
At the body shop.
Sorry I just saw the post ADD gets me sometimes any waya hoosier drag radials 325/50-15 on a 10" wheel i need to screw them to the wheel. But...
" That didnt make it any newer " " Dont antique the equipment " |
#246 |
The engine is fresh,so once it is broken in I may put it on a chassis dyno just to see.I would estimate around 475 to the crank.It was built with parts I had accumulated over the years. I run Nostalgia drags and wanted to keep it some what period correct (427),next time may be a 496/540 with 427 decals lol,Brian
#247 |
![]() Join Date: Jul 2009
here is my bucket of bolts still down. putting the engine back together this week hope to have it in this weekend then comes rewiring the hole truck for 2kits etc....
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ Last edited by bigboybodry; 12-10-2009 at 06:36 PM. |
#248 |
Mean Green
That and some tuff guy bars running all over.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. |
#249 |
that is in the makes also. the chassis man wants everything in the truck so we can do all the suspension and rollcage at one time. i am just ready to ride out. this has been a long time coming and i have been looking/gathering parts for a little over a year now.here is the pics. of the new bbc 512 and th400 trans.
#250 | |
Mean Green
![]() I have the same intake in the sbc. Damn 2 systems. So what size of hits are you running?
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. Last edited by 68 C-10 KID; 12-08-2009 at 11:18 PM. Reason: better look |
| Bookmarks |
