Old 05-02-2010, 02:35 AM   #226
watahyahknow
watahyahknow's Avatar
Re: my radical 60 build
Originally Posted by Strodder View Post
Thanks for the info. I'm going to forget about a chop now. Too much trouble.
another thing i seen people do is either using another narower (rear)-windshield from another car and build the topchop around it or make a channel and drop the window intoo the valance/dash keeping it the regulair size , it does take some headscratching to be able to install the window that way and it works better if the bonnet /hood is ending close to the window or the valaceplate and dash can be unbolted to access the window during instalation the wipers can be mounted under the bonnet too
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-05-2010, 10:25 AM   #227
Strodder
Daring to be Different
Strodder's Avatar
Like I said still too much trouble. I want to get this thing on the road, and that would be a big delay. I still have plenty to do. But it's a nice idea.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 05-27-2010, 07:39 PM   #228
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
just saving this info here, alans classic helped me out with some questions, might help others too:
Alan's Classic
1 thing at a time is progress.
Posts: 3,200 Re: grinding welds
Originally Posted by jonzcustomshop
I've got a fewquestions for you.
I am in for some serious weld grinding...
how far do you take them down?
some spots It seems like I have to take them down flush, and others there is a little valley where the weld is just a little lower than the surrounding metal. like a 16th of an inch when the top is buzzed off.
is it bad to smooth the whole thing out with my 36 grit, and a rolock discs?
I use a 3m 1991 stone on a die grinder then go over it with 36 or 50 roloc. Then wipe it.
my body man friend once showed me some 36 grit scratches that you could see through the paint in bright sunlight, is that just because they wern't prepared right before paint, or will you always be able to see them?
I fill 36 grit scratches with filler and prime. As long as it is prep right you won't see the scratches. Don't count on the primer to fill 36 scratches. It will shrink causing the scratch to show up.
if I am doing bondo , and my ground weld bead becomes a high spot, will I be able to gind it a little more, or will I have to completely clean the bondo off that area, grind, and start again?
I've had that happen before and if you gring the high spot lightly not creating much heat you will be fine. It you create too much heat it will cause the filler around that srea to let go.
also one other question.
I am not really ready to start doing bondo work.
can I put some paint over the welds, and then buzz it off and bondo it later? Or am I going to have to sandblast the paint off the welds in order to get it clean enough for the bondo to stick.
thanks, jon
That would be fine. It's easier to remove paint than rust.
p.s. feel free to cut and paste this question into your build thread if you think this info might help others.
Alan
Old 05-29-2010, 12:10 AM   #229
Alan's Classic
Alan's Classic's Avatar
Alan's Classic is offline   Reply With Quote
Old 10-11-2010, 02:27 PM   #230
foxhole
foxhole's Avatar
looking good. i have chopped a few windsheilds using the sandblast method and it works pretty good, best thing i found to mask with was thin flashing material like the roofing stuff and duct tape. leave a quater inch or so extra though because you'll want to get a glass shop to final grind the edge on a water fed belt grinder and aris it after. blasting leaves a pretty raw edge. It's worth calling all the glass shops first and seing if there are any guys that are still proficent in chopping them on the score and snap method. I have cut a few that way myself and it can go either way. don't bother trying to get a used windsheild cut though, all the little tiny chips and marks and pitting from normal driving will make the cut stray when trying to run the cut after scoring. another option is custom curved glass. if there is noone in your area tht does custom curved glass i can put you in contact with a couple of guyys up here, it's not cheep but the more you get made the cheeper they become.
foxhole is offline   Reply With Quote
Old 10-11-2010, 03:19 PM   #231
jonzcustomshop
1961 crewcab
;lol: I wouldn't mind owning a fleet of chopped 60-63's!
never could put together a time to blast this summer, it was real wet here this year, and it seemed the few times I might have a window-(job/kids/wife/weather)-to do it, it never worked out
Old 10-20-2010, 09:23 AM   #232
jonzcustomshop
1961 crewcab
Originally Posted by glendale View Post
i have to say it looks much better now that it's chopped it really brings it back into proportion. it looks really good. i must say though i'm not feeling the tail lights.
the tail lights were kind of a rush job to get it on the road.
I had originally planned on using the front part of a 60-61 gmc hood for a rear grille/tail light area, I cut one up and tried it , and it did not look good!
I have a new idea for making a rolled rear surround, and maybe lower the back bumper down, will probably still use the same taillights, but they should fit in better.
will give it a try this winter some time and see how it looks.
Old 06-08-2011, 06:34 PM   #233
jonzcustomshop
1961 crewcab
here is some stuff I have been working on..
changing up the rear panel with parts from a big truck front end...
this has been stalled, because I need another big truck right front fender, the blue one had an inch of bondo over a bad crease, and the orange one I have has the same problem..
I'll still use the buick taillights, and the 60 elcamino rear bumper, I am going to redo the bedside top across the back so that it will stick out as far as this new rear.
Old 06-08-2011, 06:38 PM   #234
jonzcustomshop
1961 crewcab
I went to a metal shop and had them bend up some inner bed panels and a wheel arch for me .
I cut down a beat wheel tub to see if it would work.
Old 06-08-2011, 09:30 PM   #235
Alan's Classic
Glad to see ya plugging along on it. It's been 8 months since the last post. Looking good.
Old 06-08-2011, 09:45 PM   #236
daverod
SSN 706
daverod's Avatar
8 months He was in hibernation. Cracks me up how you just cut and morph things together. Makes me want to go chop somthing.
daverod is offline   Reply With Quote
Old 06-08-2011, 10:16 PM   #237
jonzcustomshop
1961 crewcab
the pics were from march 28, april 5 and may 5th!
my main problem is that I am working on too many projects at once... nothing is getting done.
Old 06-08-2011, 10:18 PM   #238
Sounds like most of us, well at least me. Nice progress.
Old 06-08-2011, 10:33 PM   #239
Alan's Classic
That's funny, I didn't see any snow. I too have too many irons in the fire. I have sold some of them, but some still exist. Nice progress anyway.
Old 06-08-2011, 10:35 PM   #240
Strodder
Strodder's Avatar
Yup too many pojects, but no time to do my own.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-08-2011, 10:52 PM   #241
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: my radical 60 build
jonzcustomshop,
I keep looking at the rear and thinking about tail lights.
What about these!
1968 Mercury Cougar XR-7 GT
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-09-2011, 11:50 AM   #242
jonzcustomshop
1961 crewcab
yep, those are tempting, I think I have a set of the concave ones...
Old 07-23-2011, 09:57 PM   #243
jonzcustomshop
1961 crewcab
been working on blending the chevy and plymouth fenders together....
used what was left of my big truck fenders for the upper edge and rear brace.
cut up a hood for the top edge of the fender.
bent up some metal bar to form a scoop toward the front of the body line.
put some tape on it and painted it to finish the front edge of the scoop!
(this will be a tough piece of metal to form.. I need to take the deep concave curve,and make it taper to flat on the edge of the scoop.)
mocking up the wheel well... I moved it forward 2 inches to better line it up w/ the front wheel, still have to roll it outside to get a better idea of where exactly it will look right.
Old 07-24-2011, 01:15 AM   #244
Captainfab
60-66 Nut
Good to see you making some progress on this again Jon. That looks like a lot of head scratching, cutting, trimming and tacking
Old 07-24-2011, 07:29 AM   #245
jonzcustomshop
1961 crewcab
yep, kind of frustrating and fun at the same time... had myself painted in a corner with the scoop area.. the lower chevy body line if I had continued it would have ended on the side of the headlight ring...there just didn't seem like there would be a way to get it to flow, I had tried a scoop idea farther back on the fender before, and it hadn't worked, so that idea was off the table.. then yesterday I had a little brainstorm about putting the scoop up front , and it seems to work.
leafing through a few of my 60's little magazines helped too.
seems that that was a customizers way out on a lot of ill fitting combinations in the 60's... where ever it didn't fit..just throw in a scoop!
Old 07-24-2011, 11:28 AM   #246
SFTorange
SFTorange's Avatar
Nice work Jon. It's fun to watch your progress on this one!
SFTorange is offline   Reply With Quote
Old 07-25-2011, 02:46 AM   #247
Project
Project's Avatar
I just read this whole thing and am absolutely amazed, my head hurts from just looking at that roof chop. Mad skills man.
Project is offline   Reply With Quote
Old 07-26-2011, 04:27 AM   #248
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Man that thing is so krazy kool, I love seeing the updates! I think the Cougar tail lights would be sick on there.
fryer1979 is offline   Reply With Quote
Old 08-04-2011, 04:23 AM   #249
coulter
coulter's Avatar
this thread is awsome!!! crazy work man
bagged 66 longbed build
http://67-72chevytrucks.com/vboard/s...d.php?t=449548
my favorite colors.. black, rust, and shiny!!!! instagram: @coulter918
coulter is offline   Reply With Quote
Old 07-26-2012, 04:19 PM   #250
Jamesbbh
Love the truck. Update?
Jamesbbh is offline   Reply With Quote
