Old 06-03-2009, 12:44 AM   #226
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: My build. Project Karma. 71 stepside.
I just read through the whole thread and you're doing some good work. It should be a blast to drive. I really liked how the exhaust was run from the headers. I even printed out a couple of the pics. Then disappointed later when you said you cut it out. Could you be more specific about the problem you had there? I liked the little covers you put on the heater shroud bolts. I'm thinking of just using vacuum line plugs.
I also bought the lokar shifter rod, but haven't used it yet. If it's anything like the cable set ups for adjustment you need to set the tranny in it's lowest gear, then put the shifter in that setting, then install the rods and adjust it to match. You might check with Frizzle though, he used the same thing on his tahoe conversion and said it worked out great. He's running a big block also.
I'm not much of a cheerleader. I usually will post questions on a build when I have them, or I will try to answer them when I think I can help. I really don't know how some of the people here can keep up with so many threads or forums and post everywhere. I must be a slow reader, cause I can barely find the time to keep up with the projects I follow now.
Monroe used to be in my territory when I lived out there. I'm a boiler inspector and lived in Marysville for a while (rental) and bought a place on Camano Island (1997-2000). I liked the scenery out there, but it wasn't home for me. I just could not get used to the overcast sky.
hgs_notes is offline   Reply With Quote
Old 06-03-2009, 12:16 PM   #227
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by hgs_notes View Post
I just read through the whole thread and you're doing some good work. It should be a blast to drive. I really liked how the exhaust was run from the headers. I even printed out a couple of the pics. Then disappointed later when you said you cut it out. I didnt cut it out, i just removed it.. it was just a TINY bit to close to the cab. All i need to do is weldin in one of those flex pipes and it will be just fine..Could you be more specific about the problem you had there? I liked the little covers you put on the heater shroud bolts. I'm thinking of just using vacuum line plugs.
I also bought the lokar shifter rod, but haven't used it yet. If it's anything like the cable set ups for adjustment you need to set the tranny in it's lowest gear, then put the shifter in that setting, then install the rods and adjust it to match. You might check with Frizzle though, he used the same thing on his tahoe conversion and said it worked out great. He's running a big block also.THAT is some good info.... Mine doesnt seem to want to stay in park. ahaha.. I havent messed with that much lately.. I go through spurts of wanting to do body work, then mechanical work, then more body... Back and forth.. Im in a body work mode now.
Thanks for the reply man... Will have more pics of the exhaust when its ready.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 06-03-2009, 06:15 PM   #228
my67chevytruck
Under Construction
my67chevytruck's Avatar
Get ur @$$ to work yo !!!!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-06-2009, 07:49 PM   #229
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
HA HA ..good work yea what he said ^^^^
72 SHORTBED 7.0 is offline   Reply With Quote
Old 06-07-2009, 12:33 PM   #230
70stroker
70stroker's Avatar
very nice build man. i love everything your doing. what wheels are you going to roll with, the big inch centerlines? anyway keep up the work it gonna turn out great.
i kinda know how you feel about posting on the build thread and not gettin alot of props, its alot of work and to you its your truck and a 10 hour day in the shop makes for a 5 min post you feel like you did alot and noones noticing. I feel the same way on my build thread and i didnt even take mine down to bare frame. you just gotta remember most of us are in our garage all day to and just to wiped out to get on here and most alot of times.
ill be watching cant wait to see it in paint. what color you going with? you doing it yourself?
70stroker is offline   Reply With Quote
Old 06-08-2009, 03:23 AM   #231
lyrikz
PITbut
lyrikz's Avatar
Ya, big centerlines. Im going with black. I have done everything myself. I didnt build the motor or do the sandblasting, but thats it.. I almost have the bed finished. I used the featherfill for the first time. THAT STUFF IS COOL....
and sold.
Old 06-08-2009, 09:16 AM   #232
my67chevytruck
Under Construction
how did the featherfill sand out... good results?
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-08-2009, 06:37 PM   #233
lyrikz
PITbut
lyrikz's Avatar
OMG. Stuff is friggin AWESOME. Basically i did my body work, shaped it with 40 grit, roughed it in with 80. I then put on 3 or so coats of featherfill on the areas i needed and went back with a DA with 220, then with 400. its SOOOO smooth and nice. Stuff sprays very well and you can put it on fairly thick if you need be... Works very well for those rust pits that you get. So much easier to use then just metal glazing to fill the scratches....
and sold.
Old 06-10-2009, 07:35 PM   #234
my67chevytruck
Under Construction
sounds like it sands well.... any progress?
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-10-2009, 08:17 PM   #235
lyrikz
PITbut
lyrikz's Avatar
yes, bed is all taped up and will be doing the liner on it tonight. Just need to scuff it and clean it up and ready to go. I wanted to have teh bed PAINTEd by this weekend... BUT, someone forgot to order paint... SOO, i will have it all in epoxy and sanded down ready for paint for when it does arrive....
and sold.
Old 06-10-2009, 09:06 PM   #236
my67chevytruck
Under Construction
sweet post pics of the liner... looks like the al's liner worked pretty good.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-11-2009, 11:37 AM   #237
lyrikz
PITbut
lyrikz's Avatar
Finished it up lastnight. IM uploading pics now.... I think it came out friggin awesome..... 100 bucks for a spray in liner... I just cant get it off my skin now. ahahaha.
and sold.
Old 06-11-2009, 12:36 PM   #238
lyrikz
PITbut
lyrikz's Avatar
Before, after.. .Just random pics.... I love this stuff... ahaha....
and sold.
Old 06-11-2009, 01:00 PM   #239
lyrikz
PITbut
lyrikz's Avatar
Damn, paint is expensive... WIth the metal glaze, rage gold, gallon of featherfill, 1.5 gallons of epoxy, basecoat, clear coat... IT adds up FAST. That doesnt include sandpaper, which you use a TON OF. Paint thinners, plastics and what not.
I spent 400 last week, and today i spent another 400 or so on the base and clear....
All the little things add up when doing one of these projects.. Holy cow.
and sold.
Old 06-11-2009, 01:56 PM   #240
my67chevytruck
Under Construction
Dude, that's looking bad ASS... one day i will have the cajones to paint a compete truck, maybe the '72 outback. I may have to check out the al's liner.... keep up the pace and you will be crusin soon bro!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-11-2009, 04:33 PM   #241
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by BACKYARD88 View Post
Curious how well they fit and how well they match the factory ones. How much prep work to make them smooth, and where'd ya get em
I have a response to the fender question finally... Not much work.. I just sanded them down with a DA and some 220.. sprayed a few coats of featherfill, and they are good to go....
and sold.
Old 06-12-2009, 09:32 AM   #242
72 SHORTBED 7.0
WOW you put that bed liner on nice and what was that stuff called and how much, did it take to put it on and price..nice
What do the people next door say? Some time people call the police and say,” I smell something funny out side you know.
Old 06-12-2009, 02:51 PM   #243
lyrikz
PITbut
lyrikz's Avatar
All my neighbors are cool. Never once had an issue.... No smell really...
Stuff is called ALSLINER.com It was 90 bucks shipped for a gallon... Now, you need to have a special gun for it.. Its only 40 bucks or so, and you desperatly need a big compressor cause that gun is just huge and runs the WHOLE TIME. There are definetly tips and tricks on how to get it on right.
First time i used it i just pulled the trigger and i went through a gallon SUPER QUICK.... Then i read the instructions and saw you can adjust your flow by just pulling the trigger lightly and it gives you a more linex type look... they also have a flattening agent so it would match linex identically.. i like the shine though.... Im not using it to keep damage out of the bed from hauling stuff, just my kids.... I love this stuff..
and sold.
Old 06-12-2009, 08:38 PM   #244
72 SHORTBED 7.0
cool good info
Old 06-30-2009, 03:15 PM   #245
lyrikz
PITbut
lyrikz's Avatar
Quick tease.
Bed is painted. need to wetsand and polish, then im putting it outside so i can get some more room for the truck...
and sold.
Old 06-30-2009, 03:47 PM   #246
my67chevytruck
Under Construction
SWEET...... Ya TEASE..... more pics. did i overlook it... What paint gun are your using to paint.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 06-30-2009, 05:41 PM   #247
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Thanks for the info, I may have to look into a set of those.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 06-30-2009, 06:52 PM   #248
72 SHORTBED 7.0
Nice work !! you painted that ??,look slick for blk .Can you put it in the light more pic...
Old 06-30-2009, 07:04 PM   #249
lyrikz
PITbut
lyrikz's Avatar
The light pic with flash even shows less.... I did it in the garage.. All the horizontals have some dirt in em.. Going to wetsand it out tonight and maybe put a polish on it and see how it looks. A paint job is only as good as the final color sand in my opinion... right now it looks like a wet black mirror with some dirt in it. ahaha...
I will do a real good close up pic before and after to see how it comes out. For quite a few years i used to work part time at a body shop wetsanding and polishing all the cars... Glas i have that experience... But to be honest, i have never done a black car. Dark blues and metalics, but never just SOLID black...
and sold.
Old 06-30-2009, 09:49 PM   #250
hgs_notes
GEARHEAD
hgs_notes's Avatar
That's experience I really wish I had right now. Back in high school, I spent 6 out of 7 hours a day of my senior year in the ind. arts dept. Auto body was offered, but I was doing mechanical, welding, machine tool, etc. There just were not enough hours in the day for me, or I would have done that too.
Since your doing it yourself in the garage, maybe build a plastic tent around it with a fan for a little positive pressure to keep the dust down. It looks very good so far.
