PROJECT 7DEUCE
Re: Tbi swap build thread
First real drive yesterday and it was awesome still have a few small bugs to fix but no big deal... My map sensor was bad so I replaced that and I have a small vacuum leak at the tbi/adapter plate. Only code I seem to have is the vss code which I knew was gonna happen as its not hooked up.. I would like to say thank you very much guys as you have helped me more than you could ever know...
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 07-12-2009 at 08:36 AM. |
Still Learning
Hi guys this is a great thread thanks CJRacing for starting it and all the others that have added to it. My son and I are diving into this swap out well kinda. The plan is to remove the motor and tranny in tact and plug it into the 86.Thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=356697 So far we have unhooked just about all the wiring and mechanical on the donor. I will be junking the car when done so I can keep the complete wiring harness if necessary.
I noticed pretty much everyone on here is using a 87-90 truck or aftermarket tbi harness. I picked up a 92 buick 5.7 with a 700r4 (i think) for $300 on craigslist to put into my Son's 86 swb. It runs and shifts good...we drove it home with the AC on. Anyway, this is a super low buck build just to get him a driveable truck and then sell later to invest in his 69 (we are probably gonna do a 5.3 conversion on it). Or if we stay hooked up on it he may just drive them both who knows? So here is my list of questions for now: 1. Can we use the car harness and ecm ? 2. What parts will we need to buy? 3. What is the K.S. talked about on this thread? 4. I have never even touched a tbi engine until yesterday Can we do this project? I haven't worked on trucks since the 90s.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 08-12-2009 at 03:42 PM. |
Still plays with trucks
The car TBI computer is a little different than the truck version because the car computer does additional things the truck one doesn't (like electric fans) but it will work just fine in the truck swap, actually better.
Check out thirdgen.org for tuning the engine after the swap. The guys over there are very knowledgeable about the TBI motors and computers. K.S. is knock sensor. It is on the block down by the starter threaded into the water jacket. The Buick should be plenty big enough to allow you to use its wire harness and get the ECM into the cab of the truck. It must go inside as it is not weather resistant. |
Wire the heated oxygen sensor relays activation wire to the fuel pump power wire coming off the ECM.
This way the heating element is only working when the fuel pump is running and not at all times the key is on. It will make the sensor last a lot longer. |
#5 | |
A3 Dark Green/Yellow 428 Canister Purge Solenoid C1 Black/Pink 429 Air Divert Solenoid C2 Dark Green/White 459 AC Compensation Relay Control C8 Light Blue/Orange 495 Power Steering Pressure Switch C12 Tan 472 MAT (or IAT) Signal out of the five I/O MAT (C12) you must keep or otherwise ECM will set error code. IAT improves AE and PE over wide range of temperatures. Use car harness as is - no need to buy anything. KS part number is a bit tricky - use the same as on donor engine. Make sure to keep ESC module that was used on B- Body - it is mounted on AC relay bracket - passenger side fender. I'll have to look up this part, but OE part number should be good for your conversion. Swap is straight forward. It is not to difficult just take your time and plan ahead. If you have questions - drop a a line. I took a look at your donor photos - I hope that you re-sealed your donor engine (oil leaks can ruin clean compartment). //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) ![]() New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
Still Learning
RF,
I am so pumped that you saw my post. You have an awesome truck there! I posted my own thread (http://67-72chevytrucks.com/vboard/s...75#post3455975) before I did a search on Google and found cjRacing's thread. I see that you are a bonafied expert on the subject and you have been through this before. You are welcome to chime in on my thread too. You right on the money about the oil/trans leaks. I am planning to put new v/c gaskets and pan gaskets and any other easy fixes since the engine is out already. Right now I'm a little overwhelmed with the wiring thing, but I'm sure I can work around that eventually. I will definetly have some questions in a day or two. thanks for your reponse, Mike
Take your time and sort the wires out one at a time and you can do it. That is why I started this thread in the first place was to show my swap and smoke out others that have done a tbi swap and want to share and, help with others that need help.
So if you get stuck just ask and we will try to help. Good luck, Jamie
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck |
#8 | |
Still Learning
I'm so glad I found this site....I wouldn't even attempt this swap without having found this thread. One thing I'm wondering, if you look at my pics, you can see that the original harness is complete and still on the engine. So can I track down the wires that need to be tied into the 86 truck and splice with it still attached? Or would it be better to take the harness off the engine and do a wire by wire splice up? My plan was to leave everything like it was in the car and just tie in where I need to and make it look stock. Also, my harness will require about 2.5" X 3.5" rect. cut out in the firewall for a stock look. Maybe I missed this detail but how did you do yours? thanks, Mike |
You can go back to the first page of this thread and look on post # 8 and I listed all the wires by color and what pin that it goes to. It should be the same with the harness you have with maybe a few extra wires throwed in. Then you can look on page #3 of this thread starting with post # 65 and see what me and RF did as far as routing the spaghetti of wires that you will have left over. You need to get real familiar with a soldering iorn
. Later
The fleet 94 Chevy 4x4 reg cab 2018 Traverse (wifes car) 1977 SWB stepside 1949 Chevy truck Last edited by cjracing15; 08-09-2009 at 11:28 PM. |
#10 | |
//RF
#11 | |
Still Learning
I have sufficient soldering skills, I'm confident about that part and I prefer heat shrink tubing also. As far as the cut-out in the fire wall, I looked at a coworkers 93 blazer and his is just like the car and is just left and under the AC equipment. ( I like this idea) I have some sheetmetal experience too. I have been in the Tooling and Machine shop business since the late 80s, so I can fab just about anything necessary. Right now, this is low on my priority list. I'm really worried about the interface with the truck harness more than anything. I am confident with you guys helping me we will have this puppy running in the next few weeks.....months....before Christmas....Before he hits 16 next Feb. It's all good boys! Thanks, Mike RF, I found this pic on that Jeep thread link you posted on page 3, it should help me a lot:
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 08-10-2009 at 12:58 PM. Reason: added pic |
Mike
I do not want to sound overly optimistic, but harness should not be to difficult to manage. The ECM harness (in grand scheme) is a standalone by design. The B-body car harness has couple extra circuits - AC controls and extra power circuits which can be left alone. Interfacing with your truck you can break it up into two sections - under the hood and underdash. Under the hood: 1) +B - fused from battery 2) Grey wire to fuel pump. Under dash. 3) SES light wiring. 4) Brake actuated switch for TCC control 5) P/N switch - this will require a diode, and relay circuit - very simple to construct. 6) Constant +B (12VDc) (must be always hot) 7) Switched - Ignition ON +12 volt line (Use another to provide sufficient current as existing fuse panel may not sufficient current handling capacity) 8) ALDL connector wiring (3 or 4 wires all together) 9) System ground To fire transplanted engine, at a minimum, you need to have 1, 2, 6, 7, 9 connected. You can search through this thread and IFRC I have outlined color codes for wires which must be connected. If not drop a line. A word of advise - start a note book! //RF
#13 |
Still Learning
Thanks RF for breaking that down for me. I am going to try to pull the harness today and start dissecting it. BTW, you don't have a link to your build? What's up? that is a very impressive truck you have there!
PS I will have questions I'm sure. |
#14 |
PROJECT 7DEUCE
Well guys I have been driving mine almost everyday and the fuel mileage is great.. The only problem I have now is when its cold it does not wanna idle but as soon as it warms up its good to go. I have been told it is the water temp sensor so i guess that's the next piece to replace.
GO BIG GREEN GO DUCKSMEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#15 | |
//RF
#16 |
You really need to data log what is going on to know what the ECM is seeing that makes it run poorly when cold then clean up when the engine gets up to temp.
It sounds like an open loop vs. closed loop issue to me. The CTS is a possible source giving the ECM faulty info but there could be several other causes. Data logging is a good place to start. It helped me diagnose a vacuum leak that two mechanic friends thought was a fuel system issue. It will also let you see where you can fine tune the programming to suite your particular setup. |
#17 | |
//RF
#18 |
#19 |
Still Learning
Where do you get one of these and which one is recommended?
#20 |
Thanks for the pictures! They really help.
Do you know where the vacuum hose coming off the intake by the #8 cylinder goes? A adapter is threaded into the plenum and I think a vacuum hose attaches to it. Thanks again. Last edited by pancake; 09-12-2009 at 08:55 PM. |
#21 |
PROJECT 7DEUCE
I do remeber my friend sayin that it was jumpin from open to closed loop untill it warmed up? I should have written it down....
#22 |
Next project: 1970 K10
Jamie, rfmaster, or anyone else......
I am in the middle of a 5.3L Vortec install in my 85, which prior to this had been converted to TBI with parts from a donor 87. I am trying to find the wire that runs from the firewall to the pumps, the wire that actually powers the fuel pumps. Is it the tan/white wire that comes from the relay that powers the pumps? What about power for the tank selector switch, is it from the same wire? I have a signal wire that comes from the 5.3's PCM that will turn on a relay. I just need to find the wire that goes to run the pumps now.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 09-08-2009 at 12:27 PM. |
#23 |
Still Learning
Bob,
On mine it is a grey wire that goes to the fuel pump. I don't know about yours because my donor is car harness. mike |
#24 | |
The tank switch should be a completely different circuit - I do not have this information handy at this time //RF
#25 |
Exactly the info I needed, thank you very much!!!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
| Bookmarks |
