#226 |
Restoration Virgin!
Re: Project Cod Fish
That's just sweet!!!....so when is the sheet metal coming back??
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#227 |
![]() Join Date: May 2007
sheet metal is painted and at painters....... waiting on the fuel tank so I can plumb that in before sheetmetal goes on.... I ordered it from boyd and he said it may not ship till after new years...... this thing should come together pretty fast after that.
#228 |
![]() Join Date: Jul 2003
Sweet truck, what motor mounts did you use?
#229 |
VA72C10
![]() Join Date: Mar 2008
Looks great!!!!
Can't wait to see it all together!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#230 |
ece mounts
#231 |
Still Learning
The engine looks great in the chassis! Maybe you already said, but what A/C compressor are you gonna use? thanks
#232 |
rob, that looks great...you work fast, looks like everything just fit right in there..
#233 |
Under Construction
looking great Rob....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#234 |
I am very pleased with the ECE crossmember and engine mounts...... this was a very easy install...... can't thank you enough Don for the good work on the engine...... Can't wait to hear it run.....
I am gonna run a Trailblazer a/c... I think maybe Don will chime in on what he sent. |
#235 | |
also a side note to anyone thinking of switching to a TB style from the truck ones, the mounting bracket is diffrent (but will mount to the engine with the same holes), and the electrical connector is diffrent as well. Last edited by 68 short step; 01-01-2010 at 09:23 PM. |
#236 |
you get the cab installed yet? any more progress reports?
#237 |
Sorry to say I haven't got any progress to report..... Been workin my butt off. Work has been good so gotta keep the boys rollin so I will have money for my toys.... Hope to get drive shaft and exhaust done this week...... Then the fun will begin....
#238 |
Nice build. I love the 5.3's. I'm pulling my 2005 5.3 which I had in my 96 S10 Blazer for over 2 years to put in my 68 C20. You did a great job of detailing your engine. Now i've got more work after seeing how nice yours came out with a little paint. Did you clear coat the intake or just clean and shine it. Looks real shiny in the pics. Great build and an inspiration to get moving alittle faster on mine. Thanks. Jim.
#239 |
It was painted then cleared.... I got the engine from 68 step he did a great job detailing it...... Thanks cant wait to get it back together.....
#240 |
Rob, what trans mount did you use? My salvage yard 4L60 came with a rubber mount but it only has 1 stud. The pics I have seen of the ece trans crossmember show two holes
similar to the oem trans mount. Thank you. Last edited by 1971gmcshortbed; 01-13-2010 at 11:28 PM. Reason: spelling error |
#241 |
I use the ECE mount and just drilled a new hole for the stud worked great and will be plenty strong.
#242 |
Energy suspension's aftermarket poly transmission mount has options to do either the one hole or two (3 tapped holes in the bottom of it).
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#243 |
also a turbo 350,400, or 700r4 trans mount will bolt to the 4l60e trans, and it can be mounted to the crossmember useing the 2 holes... or drilling the crossmember for the single stud mount, is the other option...
#244 |
Going Down?
![]() Join Date: Jun 2009
Thanks Rob and Don for all the pics, I'm installing the same engine configuration but I was unsure as to how all the accessories looked and the belt routing. somebody took all mine off and I had to buy all new brackets, alternator, power steering pump and idler pulley. Mine is a 6.0 and they are the same architecture. Mine is going in next week.
Great build!! and I'll be watching to see this baby get rolling!
Just another day in Paradise Rebuild thread http://67-72chevytrucks.com/vboard/s...d.php?t=354512 |
#245 |
here is a pic I took about a week and a half ago at the body shop. Still waitin on fuel tank.....
#246 |
VA72C10
looks blurry
j/k...looks nice and shiny...I'm looking forward to seeing paint on mine...
#247 |
That color is going to look sharp. In think paint time is probably the nicest part of any build.
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#248 |
LOl yea i took it from my cell phone. I got the good camera all ready.... they are suppose to cut and buff it first of the week then assemble it...... If my fuel tank comes!
#249 |
Hi Rob, what tank are you using?
#250 |
I am using a Boyd custom tank
