Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-09-2012, 01:12 AM   #226
blazins10
blazins10's Avatar
Re: Power Steering Adapter Plates
can u send me payment info on ps bracket and shaft kit
for 63 using a 82 pump
thanks
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 08-09-2012, 10:57 PM   #227
Captainfab
60-66 Nut
PM sent
thanks
Old 08-11-2012, 09:36 PM   #228
RayPrager
Sent a PM on your adapters and plates ....thanks
Ray
RayPrager is offline   Reply With Quote
Old 08-11-2012, 11:06 PM   #229
Captainfab
60-66 Nut
Email sent as requested.
Ray
Old 08-16-2012, 12:54 AM   #230
drtydog
pm sent
drtydog is offline   Reply With Quote
Old 08-16-2012, 11:10 PM   #231
Captainfab
60-66 Nut
PM replied to
Originally Posted by drtydog View Post
pm sent
Old 08-22-2012, 03:38 PM   #232
drtydog
Great parts just received them today. Top notch work thank you!! Anyone thinking about getting any of Captains parts don't hesitate you won't be disappointed!!
Old 08-22-2012, 09:54 PM   #233
Captainfab
60-66 Nut
Thanks for the compliment and recommend
Old 08-22-2012, 11:00 PM   #234
genesis11
Cap, I need to purchase a power steering bracket, rag joint coupler. & brake booster adapter (all for a '66). Thanks, look foward to hearing from you.
genesis11 is offline   Reply With Quote
Old 08-23-2012, 10:15 PM   #235
Captainfab
60-66 Nut
PM sent
Old 09-08-2012, 07:59 AM   #236
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
on a 4 wheel drive, will this work ok, or do I need an inner plate too?
btw, this is going to be for 87 4wd equipment on a 64 2wd frame..
Old 09-08-2012, 09:08 PM   #237
perro13
perro13's Avatar
I have Factory 65 4x4, What do i need.thanks
perro13 is offline   Reply With Quote
Old 09-08-2012, 10:34 PM   #238
Captainfab
60-66 Nut
I have sold several to guys that installed them on the '67 and earlier 4x4's. I don't think an inner plate is necessary unless you plan on wheeling it hard, and/or running big tires.
Old 09-08-2012, 10:37 PM   #239
Captainfab
60-66 Nut
This adapter plate should be all you need unless you want the tube and flange also. Of course you will need the 4x4 power steering box, pitman arm, draglink, pump hoses, belts and pulleys for your particular engine. I don't think the template I supply for the 2wd's will work on the 4wd's, but then again I have yet to install one on a 4x4. However I do supply some pics and measurements taken from a '69 K20 to aid in the installation. If you do run into a problem I am always willing to help out via email or by phone.
Old 09-14-2012, 05:30 PM   #240
1965Project
PM sent for info.
1965Project is offline   Reply With Quote
Old 09-14-2012, 10:44 PM   #241
Captainfab
60-66 Nut
PM replied to
Originally Posted by 1965Project View Post
PM sent for info.
Old 09-19-2012, 12:00 PM   #242
Chvy2NV
Hey Cap. I'm putting in some PS in my 67 SWB and need one of your brackets.
It is a 68-72 steering box and pump...not sure the exact year....
Please send me payment info. Thanks. Armando.
Chvy2NV is offline   Reply With Quote
Old 09-19-2012, 11:17 PM   #243
Captainfab
60-66 Nut
PM sent
Old 09-20-2012, 12:39 AM   #244
jlsanborn
jlsanborn's Avatar
Captain!
Just gotta say you're the top-notch vendor I've seen on here. Every day there's questions and BAM! - answers. You're posts are what got me hooked on the Hydro-boost setup. I went the hard way and made my own mods vs. adapters, but I still don't have it all sorted out and may just end up wishing I had used your parts. I'm hoping to catch up with you one day!
Johnny
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-20-2012, 01:37 AM   #245
Captainfab
60-66 Nut
Thank you for the compliment Johnny
Old 09-24-2012, 12:47 AM   #246
Captainfab
60-66 Nut
Here are a couple pics for Chvy2NV of a '67 frame mod for power steering.
Old 09-24-2012, 01:20 PM   #247
Chvy2NV
Yes capt. Mine does have the little bumps from factory as the ones in the pics you posted. Please send me the payment info for the spacers.
Old 09-24-2012, 02:11 PM   #248
62-One-Ton
62-One-Ton's Avatar
So do these work on a 60-62?
62-One-Ton is offline   Reply With Quote
Old 09-24-2012, 10:45 PM   #249
VA72C10
VA72C10
VA72C10's Avatar
Interested in a set of these for my 67 also....any issues with steering geometry (I realize it is slight). And I'm assuming they don't have to but it makes the install easier?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-24-2012, 11:14 PM   #250
Chvy2NV
What you referring to here? Welding them?
