Old 04-21-2010, 12:26 AM   #1
smokedat
smokedat's Avatar
Re: LS1 into a 73 cheyenne
Still working on the rust repair so far I've shaved the coners on the bed and left gas tank. The technique I use in order to prevent warping is to blow air after each tack, and when grinding the welds I go with a ruff grit like a 60 or so to chew the weld faster and not create so much heat. So I desided not to run AC & heater or wipers I will fabricate a sheet and place over the fire wall in order to get the smooth look without going crazy with the filler and relocate the wires to hide them. I will also fill in the inner fenders and the radiator core support.
smokedat is offline   Reply With Quote
Old 04-21-2010, 12:29 AM   #2
smokedat
smokedat's Avatar
Old 04-21-2010, 12:32 AM   #3
smokedat
smokedat's Avatar
After the welds have been grinded
Old 04-21-2010, 12:53 AM   #4
smokedat
smokedat's Avatar
I will be using a Valspar single stage B520 P to paint the frame
Old 04-21-2010, 10:21 AM   #5
nlped
nlped's Avatar
Nice work!!! Color will look cool.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-21-2010, 11:57 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
Looks great. Good job.
Which model of the Lincoln MIG do you have? Mine is too small to do more than sheet metal with and I would like to upgrade.
I like my Lincoln square wave TIG but it just doesn't lend itself to sheet metal work with needing both hands to weld, no free hand to hold the work piece with.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 04-21-2010, 01:16 PM   #7
Jhogan830
Jhogan830's Avatar
BEAUTIFUL man just pretty! good luck with everything congrats on the move! and im loving those rallies! =D
84 chevy LWB-350 vortex heads and longtube headers baby blue...will be black soon...
Jhogan830 is offline   Reply With Quote
Old 04-22-2010, 12:54 AM   #8
smokedat
smokedat's Avatar
started on the firewall template hopefully I knock this out tomorow. I'm using 16 gage sheet metal. Took these low res pics with my phone.
Old 04-22-2010, 12:05 PM   #9
Jhogan830
Jhogan830's Avatar
beastin man!
Old 04-23-2010, 12:31 AM   #10
smokedat
smokedat's Avatar
I finished the firewall today I drilled some holes for spot welds then I welded the edges. Tomorow I will work on closing the cowl screen.
Old 04-23-2010, 12:57 PM   #11
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Nice! Looks good.
--Josh
Old 04-23-2010, 09:05 PM   #12
kvn1011
Kvn1011
kvn1011's Avatar
Awesome trucks! Have you considered one of the brake booster relocation kits?
kvn1011 is offline   Reply With Quote
Old 04-24-2010, 12:07 AM   #13
smokedat
smokedat's Avatar
Yeah im trying to fit it somewere in my schedule
Old 04-24-2010, 12:06 AM   #14
kvn1011
Kvn1011
kvn1011's Avatar
here is one that i may check out, i'm currently gathering parts for my truck
hopefully will get started and put my build thread up in the next few weeks
http://www.scottshotrods.com/UnderDashPedalAssembly.asp
Old 04-24-2010, 12:28 AM   #15
smokedat
smokedat's Avatar
Today I sealed the cowl screen, and wiper openings, still need to finish grinding the welds
Old 04-24-2010, 02:05 AM   #16
menace121978
menace121978's Avatar
looks awesome man!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-24-2010, 12:44 PM   #17
87 chevy silverado
Originally Posted by menace121978 View Post
Looks awesome man!
x2
87 chevy silverado is offline   Reply With Quote
Old 04-25-2010, 10:00 PM   #18
Jonboy
Slots go on anything!
looks great!
1974 Jimmy- 5.3/4L80e/NP241
Old 04-28-2010, 01:30 AM   #19
smokedat
smokedat's Avatar
Today I got the under dash pedal assembly . I also pickd up the mini 7" booster from CPP it accepts any standard corvette style master cylinder. the original stock booster will not work. This kit requires some fab work and welding and some fab work to the gas pedal to mount to the inner fire wall. I knocked out the booster. I still need more time to finish this one but here are a few pics.
Old 04-28-2010, 11:10 AM   #20
kvn1011
Kvn1011
kvn1011's Avatar
Thumbs up Re: LS1 into a 73 cheyenne
Originally Posted by smokedat View Post
Today I got the under dash pedal assembly I went to Scotts Hotrods shop to pick it up since its only 20 minutes away from my place. There was like 15 sweet rides at the shop that were being workd on. Back to buisness, the kit is engeneered and well built with quality welds that consists of a frame and a pedal assembly. I also pickd up the mini 7" booster from CPP it accepts any standard corvette style master cylinder.NOTE the original stock booster will not work. This kit requires some fab work and welding and some fab work to the gas pedal to mount to the inner fire wall. I can confirm that this kit will fit a 1973 Chevrolet C10. I knocked out the booster and cut the rim and bolts from the original location. I still need more time to finish this one but here are a few pics.
cool! Can't wait to see more
Old 04-28-2010, 01:03 PM   #21
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress! looking good!
mcbassin is offline   Reply With Quote
Old 04-30-2010, 01:48 AM   #22
smokedat
smokedat's Avatar
so i finished patchin the firewall were the booster was still need to finish the grinding. I also patchd the holes from the sun vizors and the other small screw holes from the trim pieces, I plan to leave the interior space exposed painted surface no ulpstery or trim peces and for the doors i will fab some panels from aluminim, trying to get a raw industrial type of feeling. Here are some crappy pics from my phone
Old 04-30-2010, 09:57 AM   #23
nlped
nlped's Avatar
You're makin' great progress, And it's going to look great!
It's nice to see that other folks doing these projects aren't exactly expert welders. No offense intented as I am just starting to get a feel for my MIG welder, and my welds make yours look like Nathan Porter's. I was always told the only difference between a great welder and a mediocre welder is a great grinder .
Carter
Old 04-30-2010, 10:47 AM   #24
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
A great welder doesn't own a grinder.
I have 5 set up and ready to go at all times!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-30-2010, 11:15 AM   #25
nlped
nlped's Avatar
I have 4 grinders
Carter
73c10, c10, cheyenne, ls1, swap
