Old 06-30-2010, 08:29 PM   #226
sparkydog
sparkydog's Avatar
Re: Halfbreed - GMC Z71 + IH Extd Cab
Originally Posted by Walts_restoration View Post
i thought they looked a little small on the rear doors, although its not my project nor my time and money lol. Id say if your unhappy now stop and fix it, but make sure its what you want so its done right the first time.
Originally Posted by JimmyFloyd View Post
I would say deal with it now. Think of all the other stuff you'll be basing measurements off of now, and all the custom pieces you'll have to make for the doors, which you'll have to re-do later on if you change your mind.
And if you need a roof cut section, let me know and I can cut that one of the 65. I think it's like $75 or so for a roof here.
Originally Posted by dougminton View Post
I wouldn't mess with re-doing that much wok unless I was going to be the one getting in and out of the back door.not enough difference in the looks.
But that's my opinion. Doug
Thanks guys! I really appreciate your thoughts!
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 06-30-2010, 08:37 PM   #227
sparkydog
sparkydog's Avatar
I guess I should also say that as far as the interior space for the rear seat goes - I'm OK with where the cuts are now. The rear seat area and the rear doorway opening are about the same as the GM Xcab - maybe a little tighter. So it's not the functionality or ergonomics of what I have...
The thing I am obsessing over is the exterior body proportions. It's the "sculpture" shape that I am looking at - the shape and size of the outside of the cab relative to the bed and such. You know - like what if this thing makes it into the Museum of Modern Art someday?!! hee hee.
Balls and a Sawzall
Project Halfbreed
Old 06-30-2010, 08:41 PM   #228
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
I would leave it the way it is I think it looks fine.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 07-01-2010, 05:34 AM   #229
Sven
Sven's Avatar
+1 for leaving it as it is. But it's your project and we're just onlookers ...
-Steve
1969 Chevrolet 4x4 C10 Pickup
Sven is offline   Reply With Quote
Old 07-06-2010, 01:19 PM   #230
sparkydog
sparkydog's Avatar
I'm heading back to SoCal tonight and will have about 4-6 weeks to work on Halfbreed. My next milestone is to have it legal, safe and road-worthy. I have a lot of things I can work on while I continue to think about the cab/rear door size issue.
Here's my punch list:
1 Hood hinge bracket/cowl reinforcement DONE
2 Hood latch DONE
3 Footwell sides DONE
4 Finish front and middle cab mount brackets DONE - DONE!
5 Front lights, horns and wire harness DONE
6 Rear lights and harness DONE
7 Modify and install rear doors DOOOOOOOONNNNNNNNEEEEEEE
8 Finish rear cab roof feathering DONE
9 Finish bed seams Exterior is DONE
10 Fill in rear floor pan DONE
11 Quick cab primer (roof rust stabilize)DONE
12 Front seatbelts & harness attach points DONE
13 Front & Rear window; Front is DONE
14 Install wiper motor, posts and linkage - debug Started
15 Dashboard mods/dash ducting mods Started
16 HVAC unit install & debug Installed but not hooked up
17 Seal up cowl drain seams
18 Reinforce cowl sheet metal
19 Ebrake assy DONE
20 BFH front edge of fuel tank to clearance cab better DONE
21 Move and install rear cab mount brackets DONE
22 Fire Extinguisher DONE
23 Front Bumper Ehh... Maybe Later
24 Rear bumper Ehh... Maybe Later
25 Ground straps DONE
Balls and a Sawzall
Project Halfbreed
Old 07-10-2010, 07:53 PM   #231
sparkydog
sparkydog's Avatar
I wrapped up my hood hinges and installed the hood latch. Like everything else, they are at about 90% complete and will serve their purpose until the day I decide to do a proper body makeover.
I also completed the prep I needed to the tow bar and rigged up some tow lights and harness - then took it for a trial tow/run. This afternoon I towed it up to Lake Elsinore and had a professional body customizer look at the door and cab roof and give me an estimate for what he would charge to do a really nice job of cut and fitment.
Balls and a Sawzall
Project Halfbreed
Old 07-10-2010, 07:59 PM   #232
sparkydog
sparkydog's Avatar
I've got my first "it won't run" problem. When the truck was a bone stock donor 97 XCab it would start within one or two seconds of cranking. This was the way it kept working up until my last 4 or 5 times running it. Now today it wouldn't start at all when I was done towing it back.
I went old school on my troubleshooting and started trying to rule spark and gas in or out. When I stripped the air intake equip all off clear down to the top of the throttle body and squirted some starting fluid in - it fired right up and runs just fine until I shut it off. Once I turn it off same deal - no starty again.
How can it be starved for fuel during crank but get plenty of gas once it is running?
Balls and a Sawzall
Project Halfbreed
Old 07-10-2010, 11:16 PM   #233
67ChevyRedneck
67ChevyRedneck's Avatar
Seeing the "distant" body shot, I think the cab looks great as is
That's an interesting issue. With the vehicle off, when you turn the key on (without trying to start it) do you hear the fuel pump hum? It should make a humming sound while it primes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-11-2010, 12:48 AM   #234
sparkydog
sparkydog's Avatar
Yes there is a little, faint growl for a few seconds and then it stops.
Balls and a Sawzall
Project Halfbreed
Old 07-11-2010, 12:53 AM   #235
sparkydog
sparkydog's Avatar
Here are some pictures of the rear section with the rear seat mocked up. The front seat is slid to where I like it as a 5'8" guy. But if the steering wheel and pedals were "corrected" to their proper locations to compensate for my cab, then I think the front bench would be about where a 6' er would have it.
I haven't really paid attention to what a modern X-cab rear seat clearance is relative to the front seats. Does this look about right or too narrow?
Balls and a Sawzall
Project Halfbreed
Old 07-11-2010, 12:59 AM   #236
67ChevyRedneck
Well, you got me then
That looks close to how my Z71 is (2000 Ex cab). It looks good to me. Have you butt tested it out? If your knees aren't in the seat, I'd call it good
Jesse James
Project "On a Dime"
Old 07-11-2010, 01:25 AM   #237
sparkydog
sparkydog's Avatar
Heck I don't give a crap whats going on in the back seat. As long as my dogs can fit back there and hang their heads out the window I'm good!!!
Balls and a Sawzall
Project Halfbreed
Old 07-11-2010, 02:13 AM   #238
DorianGray
DorianGray's Avatar
Nice work so far. I look forward to seeing more of the truck. And by the way you've got some skills with metal keep up the good work.
DorianGray is offline   Reply With Quote
Old 07-11-2010, 02:24 AM   #239
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Looks great! Those old IH's are cool!
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 07-11-2010, 09:04 PM   #240
sparkydog
sparkydog's Avatar
In true Halfbreed spirit, I decided to take one of the GM horns and one of the IH horns and put them together into the truck. As usual I spent waaaayyyy too long trying to figure out where and how to mount them but eventually settled for behind the pass side headlight.
Balls and a Sawzall
Project Halfbreed
Old 07-11-2010, 09:07 PM   #241
sparkydog
sparkydog's Avatar
Then I spent the rest of Sunday getting the footwell sides and bottoms mocked up, tacked and finished welded in.
(Donor metal courtesy of 67 Pickup roof!)
Balls and a Sawzall
Project Halfbreed
Old 07-14-2010, 12:50 AM   #242
sparkydog
sparkydog's Avatar
I'm trying hard not to get overly distracted by the "it's not running anymore" problem with this project and stay mostly focused on getting through the punch list for street legal.
On Monday eve I wanted to start the initial phase of mocking up the dashboard. So I cut the dash up so I could extend it farther out toward the driver. Then I tacked in some temp holder strips to keep it from falling off onto the floor.
I like how it lays up so far. It also covers up the GM HVAC module pretty well. I'll have a little bit of blending work to do on each end of the dash. I also re-installed the metal inner door liners that are off the Pickup onto the TAll front doors.
From the bench seat forward it is starting to resemble a real truck! Too bad it no longer runs like an actual truck!
Balls and a Sawzall
Project Halfbreed
Old 07-14-2010, 11:37 PM   #243
sparkydog
sparkydog's Avatar
Got the Ebrake from the GMC re-installed tonight. I harvested 3 weld-on studs from an IH pedal assy and welded them into the hybrid footwell. Mounted up the ebrake pedal and tie-wrapped the release handle until I am finished with the dashboard install.
Balls and a Sawzall
Project Halfbreed
Old 07-15-2010, 12:25 AM   #244
Frizzle Fry
Frizzle Fry's Avatar
Nice work man. Lookin good!
Frizzle Fry is offline   Reply With Quote
Old 07-17-2010, 12:03 AM   #245
sparkydog
sparkydog's Avatar
Dropped the gas tank down and BFH'd the front of it to better clear of the corner of the cab floor.
I also finished welding up the forward cab mounts and was able to finally remove the temp galvanized brackets that have been in this area for several months.
Next up is a similar task with the middle cab mounts and then I can finish the floor where it will blend around the A and B pillars.
While I was on the creeper so much I popped off the fuel filter - sort of hoping I would find a massive clog or a lotto ticket or something to explain why the truck won't start. But it was in good shape and gas was flowing fine through it so I put it back in.
Balls and a Sawzall
Project Halfbreed
Old 07-18-2010, 12:00 AM   #246
sparkydog
sparkydog's Avatar
Doh!
Boy do I feel sheepish.... but glad to have a running truck again.
Long story short - battery voltage had dropped so low from all the starting and short running times that the fuel pump couldn't do it's thing. Then I drained it even more with all my screwing around with the ether.
Once I got the battery charged it fired right up again just like old times!
Back to working on getting this thing street legal! Thanks guys for all the help!
Balls and a Sawzall
Project Halfbreed
Old 07-18-2010, 12:04 AM   #247
sparkydog
sparkydog's Avatar
I had a fun day today. In addition to learning how much better the truck works when the battery has 12v instead of 7, I...
Cut, fit and tacked in my dashboard extension.
And I also finished off the floor/A pillar base which had kind of a tricky transition/blend to it.
Balls and a Sawzall
Project Halfbreed
Old 07-18-2010, 01:04 AM   #248
ERASER5
ERASER5's Avatar
I really like the old dash. I had expected you to use the new dash. Nice surprise. Makes me wonder how the IH dash would look in my 70 or 72.
What are you going to do for defrost vents?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-18-2010, 01:59 AM   #249
Frizzle Fry
Really coming along nicely. Stretching the dash looks like it was fun. Good call on using the IH dash.
Old 07-18-2010, 11:25 AM   #250
sparkydog
sparkydog's Avatar
I've saved the GM plastic ducting system as well as the IH plastic defrost diffusers. I hope to McGuyver some kind of hybrid merge between the two.
The wiper linkage, HVAC ducting and the subtle blends between IH and GM sheet metal up in the cowl intake area are probably going to be the hardest part of the whole cab merge. It's going to get tricky.
Balls and a Sawzall
Project Halfbreed
