08-24-2010, 11:47 PM | #226 | |
Still plays with trucks
Re: 85 burb meets 6.0 lq4
I built my own mandrel bent dual 2-1/2" system for my 79 Malibu using the Flowmaster 50 Series SUV performance mufflers instead since it was supposed to be my wife's car. It toned it down a bit but still sounds nice, just a little bit more civilized. If I didn't have the car torn apart for paint right now I would record it and let you hear what it sounds like.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
08-24-2010, 11:48 PM | #227 |
Truck and auto performance nut
not sure...but my LSx motor guy suggested 112LSA for me...and he knows I wanted it nasty... but streetable.
by comparison....my cam is a 223/231 @ .050, .610/.617 lift, 112LSA. Using Patriots Gold .650 dual spring kit with bases, titanium retainers, keepers, and seals.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-25-2010, 12:02 AM | #228 | |
I put these on my 67 C10 when it had a big block in it. They fit well and have 1-3/4" tubes which is great for an LQ4. http://www.summitracing.com/parts/SUM-G9011/ $120 Add $40 for the flanges http://www.summitracing.com/parts/PTE-H7892/ Just need a little quality time with a cut off saw and a welder. This is what I will be doing when I get to the LS swap in my 67.
08-25-2010, 09:20 AM | #229 |
with all the other work I have to do....thats too much work for me! I'll just buy a set of LS1 swap headers for a 2nd gen.
08-25-2010, 06:20 PM | #230 |
68, that's a good tip.
Now is it long tube headers for torque and Shorties for high rpm horsepower or the other way around?
82 chevy longbed(grey truck)first truck when i was 15! |
08-25-2010, 08:24 PM | #231 |
Comp cams says the 110 will give choppy idle and better low end tq. Does that make cents to any one? I always thought the choppy idle cams were for top end power not low end tq....
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
08-26-2010, 12:00 PM | #232 |
The amount of "lope" or choppy sound is the amount of lobe seperation you have.
08-26-2010, 07:40 PM | #233 |
so what they are saying is ones with massive lope have good low end tq? makes no sence...
08-26-2010, 10:21 PM | #234 |
I guess it makes no since to me either. Only hear radical lopes in drag cars.
08-26-2010, 11:19 PM | #235 |
check out this arcticle:
cam_lobe_centerline_angle_tech and this one: camshaft_lobe_separation_angle_performance_test
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 08-26-2010 at 11:22 PM. |
08-26-2010, 11:34 PM | #236 |
Thanks for the info i will have to read friday after work. Sure it will clear some things up for me.
08-27-2010, 08:30 AM | #237 |
I liked the second article better. Think they both say the same thing tho. Looks like comp was right. Still up in the air about what one. I asked him how comps would compair to the GM Hot Cam. Sent him specs for it and waiting on a reponse. He has ben pretty fast so far. Thanks for the links. Now that i have read that i can remember learning that in school....
08-27-2010, 02:15 PM | #238 | |
If you combine the lift & duration of a cam that has good low end torque with a smaller LSA than the cam typically comes with then it can have a more aggressive sounding idle vs. the same cam with a larger LSA.
08-27-2010, 07:39 PM | #239 |
I sent the specs of the gm hot cam and then he made compleatly custom grind for me. Not sure why he did this but that is what he did. What do yall think. Looks tiny bit bigger gut i not sure.
Hydraulic roller tappet Basic Operating RPM Range 1500-6000/6200 Duration at 050 inch Lift 219 int./228 exh. Valve Lift with Factory Rocker Arm Ratio 0.545 int./0.545 exh. Lobe Separation (degrees) 110 VALVE OPEN INTAKE 3 VALVE OPEN EXHAUST 46 VALVE CLOSED INTAKE 35 VALVE CLOSED EXHAUST 2-
08-30-2010, 10:04 AM | #240 |
Well after 12 days at work i fianlly got home. And there was a surprise waiting for me. All the stuff to install my fuel system and carb onto my factory engine. Got fine fuel filter and fittings, carb plate, fuel pump block off plate and SS AN hose cutting tool. Looks like massive wire cutter. Hope it does good job. I may get time to install it this week too. Will take pic of stuff a little later.
08-30-2010, 10:17 AM | #241 |
you'll have to re-tune (and possibly re-jet/etc) that carb for your LSx when you install it. But at least you'll have your new fuel system in and taken care of so its not as much of an issue when you do the motor swap.
08-30-2010, 07:00 PM | #242 |
Do you think it will be pretty close for my elderly 350? All i want to do is set the idle and speed. It has ben so long cents i have adjusted one. What is the best way to set idle mix?
08-30-2010, 07:17 PM | #243 |
TA DA as my little girl would say....
08-30-2010, 07:57 PM | #244 | |
Set the idle mixture screws so you get max vacuum then back it off a little until the vacuum just starts to drop. It will take a couple times back & forth to get them dialed in but this will get you pretty close. After that you can set your idle speed.
08-30-2010, 11:49 PM | #245 | |
08-31-2010, 09:03 AM | #246 |
...depends on the needs of the motor though and how much power it makes. Your LQ4 will need more fuel then the 350 does.
08-31-2010, 09:10 AM | #247 |
I know was just kidding. I not going to jet it unless it is way off on my sbc. I will try to wait tell i get it to its permanent home to do that.
08-31-2010, 11:53 AM | #248 | |
If I remember right they jet the 3310 for a mild 454 and the 1850 for a mild 350 so your jetting will be off a bit. If you re-jet it you may also need to change the squirters and maybe even the pump cam to reduce the pump shot volume so it doesn't rich bog on you. You can look up the jet size, pump cam & squirter size they put on the 1850 and use them as a good guide line to get you by for a while without spending a bunch of money on trial & error getting it right.
08-31-2010, 03:23 PM | #249 |
My carb has none of them numbers on it. It is a 670 street avenger the part number is 0-80670. It is what holly recs for both my engines. The quad thats on it burns eyes all the time. Idle or driving does not matter it smells like pure gas falling out of tail pipe. Am sure the mains will be closer then what i have now
08-31-2010, 03:47 PM | #250 | |
Does yours have secondary jets or a metering plate?
