#226 |
Re: El Chingon
Those are nice!!
Posted via Mobile Device |
#227 |
Re: El Chingon
Yes sir, They fit really good and looks like clearance for the steering shaft will not be a problem. Not sure about not running a gasket on them. Sanderson says to run a bead of black permatex high heat sealant and that's it. Will see how that goes. The flanges are super thick on these things. If your running an ls swap with dropmember I would recommend them on fit for sure. Time will tell on craftsman ship.
#228 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: El Chingon
Headers looks great the bead of silicone sure is weird though? Seems to me like copper gaskets would work also but then again I don't build headers.. Keep up the good work makes me want to work on mine..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#229 |
Re: El Chingon
Truck looks great! You have some nice fab skills!
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
#230 |
Re: El Chingon
Ran all the fuel lines up to the motor this afternoon. Gonna wait to put the cab on to see how to exactly route them up to the rails. Ran the Aeroquip softline for now, may convert it all to hard line. This way I can get it up and running and replace the sections as I want. Will see. I usually use all aluminum line on my stuff, trying something new.
#231 |
Re: El Chingon
Damn that thing is dusty, need to wiper her down.
#232 |
Re: El Chingon
Man. I was wondering what happened to this. Good to see you're back on it.
#233 |
Re: El Chingon
Installed Porterbuilt Hinge kit this afternoon. The key for me was the time you put into the template. After that it was gravy baby. Top notch product once again from the great Nate. Getting closer to setting the cab back on for some mock up on the fenders, column, fuel lines, etc...
#234 |
Re: El Chingon
Harbor Freight baby, tired of wiggling this thing around.
#235 |
Re: El Chingon
Got the cab back on and everything fit pretty good. Got to trim the floor a little more around the high hump but that's it. I have one sensor on top of the intake that is close to the firewall.
#236 |
Re: El Chingon
This is the sensor that I am referring to. Anyone have a problem or even a solution to this without me hacking on the firewall some more.
#237 |
Re: El Chingon
Trim some more, a little more, and a little more. Its on, but guess what? I need to trim a little more. Its sitting on the top of the tire, but has no room at all. Want a little clearance just in case the floor is not level when parked.
#238 |
Re: El Chingon
Problem solved, thanks to the members of the forum
Posted via Mobile Device Posted via Mobile Device |
#239 |
Re: El Chingon
Do you happen to have a part number on those headers? Thanks in advance.
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 |
#240 |
Farm Truck
![]() Join Date: Aug 2006
Re: El Chingon
Update on this Hot Rod?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
#241 |
Re: El Chingon
Just got new motor mounts to move engine forward to clear transmission Once that is right going to start fitting panels. Mike at sloshtubz said my inner fenders on the way. Got my harness from PSI for the motor. Gonna start knocking stuff out soon
#242 |
Re: El Chingon
Finally got the radiator in with some trimming on the two core mounts. I guess they do not make a three core isolator. Got it in anyway.
#243 |
Re: El Chingon
One inch lowered mounts for PB drop member. Welded them out and going to rattle can them tomorrow. Needed more clearance clarence.
#244 |
Re: El Chingon
What was used to weld these mounts? Looks like a mig but it's almost dry looking?
#245 |
Re: El Chingon
I know it looks funny. What your seeing is that I run a dual action sander over all my parts before paint. It's the new sanded surface vs the original surface. The technique I use when mig welding gives it a certain profile that looks like a series of ripples or weave pattern. It's almost like a shadow in the valleys of the bead.
#246 |
Farm Truck
Re: El Chingon
You see these radiators in the Vendor section. There cheap for Aluminum.
http://67-72chevytrucks.com/vboard/s...d.php?t=617049
#247 | |
Still Learning
Re: El Chingon
BTW.Nice work on the motor mounts. |
#248 |
Re: El Chingon
#249 | |
Re: El Chingon
#250 |
Re: El Chingon
Got the Slosh Tubs in from Mike. Great looking product. Got to cut up my brand new fenders.
