Old 05-27-2011, 10:01 PM   #226
philapino18
Re: SGTUSMC '59 build
I see that you used the brake booster out of the donor truck, did you use the brake pedal assembly as well? If so can you post a pic of how that bolted up above the column?
philapino18 is offline   Reply With Quote
Old 05-30-2011, 04:45 PM   #227
kdog3121
Sarg looks great so far.
Can you tell me what the dimensions are from the outer lip to outer lip on the fleetside bed. I have a ZR2 rear axle and I don't know if it's going to work (I'm in the market for a 58-59 short bed).
Thanks, Kent
kdog3121 is offline   Reply With Quote
Old 05-30-2011, 07:09 PM   #228
sgtusmc
sgtusmc's Avatar
Originally Posted by Barney Rubble View Post
Sgt, just did the full read, nice build you got going. Could you measure the hole positions for the fender emblems please? Vertically they seem to be just above the crease in a straight line.
I want to put them back on my 59 and thought your measurements would help.
Cheers
Barney
Here you go man, Sorry for the long delay. This is measuring from the rear of the fender forward on the crease.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 05-30-2011, 07:17 PM   #229
sgtusmc
sgtusmc's Avatar
Thanks, Kent
I have the bed mounted on the frame. So It's kind of hard to get a direct measurement right above the tire because of the frame and muffler. So I measured forward of the tire. The fleetside bed has a 1 inch inner lip around the wheel well. I measured the bed from outer fender to outer fender. So subtract 2" for the lip or you could trim the lip if your to close.
Old 05-30-2011, 07:20 PM   #230
sgtusmc
sgtusmc's Avatar
Yes I'm use'n both the booster and ped assembly. I'm still in the mock up stage the the pedals. I'm sure I'll chage it around of few more times. Take a look at this guy's Fleetside build. There's a lot of good info there. He's also use'n booster & ped assy. Hope this helps.
http://67-72chevytrucks.com/vboard/s...ight=fleetside
Old 05-30-2011, 07:37 PM   #231
kdog3121
Great thanks for the quick reply!
Old 05-31-2011, 02:48 PM   #232
philapino18
Wow thanks for the link! On page 5 it looks like they left the factory dash brace, and cut the donor brace to fit. Looks like a great solution.
Old 06-07-2011, 05:45 PM   #233
sgtusmc
sgtusmc's Avatar
My neighbor gave me (20) 2ft by 2ft, 10g flat plates. So I decided to use them to smooth out the firewall and new floors. I cut out one side and had the wife weld it in. She did one side and got burned. So she's done. It was nice while it lasted.
Old 06-07-2011, 10:54 PM   #234
xpickup
xpickup's Avatar
sgtusmc, Free metal always is great. She did a good job welding it in. My wife maybe was in my garage 10 times and she usually says about the smoke or the smell isn't good for me. She usually leaves pretty quick but weld no way! Your wife is a keeper.
Shannon
xpickup is offline   Reply With Quote
Old 06-08-2011, 12:56 AM   #235
sgtusmc
sgtusmc's Avatar
We had some family over today, so my wife's welding was kind of her proving to her brother she could weld. I wish she was really into it. I'll take what I can get though. Most of the time she's just hanging out in the garage reading a book.
I'm going to be build/patching the drivers floor and both kick panels in a few days. What are your thoughts about using spray foam inside the kick panels once there painted? I'm going to delete the vents and build speaker buckets out of the 10g plate. I'm thinking it would prevent rust and deaden the sound.
Old 06-08-2011, 04:16 PM   #236
OrrieG
OrrieG's Avatar
I think spray foam is good for sound deading on the back of panels. If you try to enclose the space condensation over time will get trapped and start rusting instead of running down to the bottom and out the drip hole or turning back into vapor as it heats up. I am wondering what kind of shape all of the homes they are using foam to fill the wall and ceiling cavities up are going to be in after a few years. I kept my vents, we have quite a few days up here where that is all you need.
OrrieG is offline   Reply With Quote
Old 06-09-2011, 05:48 PM   #237
sgtusmc
sgtusmc's Avatar
OrrieG, that makes a lot of sence. Thanks for save'n me again.
Old 06-09-2011, 08:35 PM   #238
OrrieG
OrrieG's Avatar
I did the back of my corner panels, but ended up shaving it to about 1/2" to fit and have some clearance. hadn't thought about the back of the kick panels.
Old 06-10-2011, 02:05 PM   #239
renegade6
I used Al's liner to deaden the sound and help with rustproofing on mine. Used body tint to keep it from standing out.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 06-16-2011, 07:00 PM   #240
sgtusmc
sgtusmc's Avatar
The 59's been out in the driveway for the last few days. I went out to work on it today, and found this on the dash. I'm not sure what's worse- the low balling or the fact he opened my door to put his note inside. Your a brave man Frank!...haha
Old 06-16-2011, 07:52 PM   #241
99 to Life
99 to Life's Avatar
thats funny. you should prolly return his call so he don't come back.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 06-16-2011, 08:59 PM   #242
OrrieG
OrrieG's Avatar
"Make your day" LOL. 16 years ago I had a 41 chevy DD, 200K miles, all original, faded paint but drove ok up to 45 mph. One day I was out working in the yard and a kid about 14 came up to me and very seriously offered me $200 for it because it was "really old". I was nice and told him I would need a little more then that. He came back a few times and we talked about old cars while I wrenched away and he got realistic about what he need to do. I did offer to take a look at any he was interested in to keep him from getting hurt but he must have moved because he quit coming around.
Old 06-17-2011, 03:13 AM   #243
drivea55
drivea55's Avatar
haa haa...
I love it, sometimes when you think you have seen it all...
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 06-18-2011, 09:02 AM   #244
Wheelie
Whats worse is he cant spell CHEVY. Come on people....
Wheelie is offline   Reply With Quote
Old 06-18-2011, 05:49 PM   #245
STEVE60
Nobody every comes up to my little honda and leaves a note in it.
Just be glad that you have something that somebody else wants. I have a neighbor that has stopped by and asked about mine, that I once kept in my open shed. I have enclosed my shed now. Makes me happy that someones else may want what I have.
No it wasn't me that left the note!
Steve
STEVE60 is offline   Reply With Quote
Old 06-18-2011, 06:02 PM   #246
STEVE60
oh I forgot, your build looks great. I like the fleetsides.
I'd give $1350 for it.
Steve
Old 06-18-2011, 06:15 PM   #247
56taskforce
56taskforce's Avatar
You are a nicer man than I I am not sure I would have blanked out Franks number
56taskforce is offline   Reply With Quote
Old 06-18-2011, 06:17 PM   #248
Kabwe
Certified Car Nut
Kabwe's Avatar
You should call him and tell him he left out a zero just to mess up his mind.lol
Kabwe is offline   Reply With Quote
Old 06-19-2011, 03:49 AM   #249
sgtusmc
sgtusmc's Avatar
I had planned on calling him back. However, he showed up today. Not at all what I had expected. He looked like Christopher Lloyd from Back to the Future, and twice as nutty. I ended up opening the garage so he could look at it again. By this point I had told him the truck wasn't for sale a hand full of times. He was having a bidding war against himself at one point. He was asking questions, then answering them. I felt bad for the guy. Not all his friggin dog's are barking! I'm happy he stopped by though, he got me outta bed and in the garage.
I'm going to frame the note and hang it in the garage. Any time I'm down, I'll read it. Hell, anything's better than being that guy!
Old 06-19-2011, 03:51 AM   #250
sgtusmc
sgtusmc's Avatar
Steve
$1400 and I'll drive it down to ya...haha
