Old 09-29-2014, 08:47 AM   #226
FarmerSid
FarmerSid's Avatar
Re: Be Gentle. . . I'm an Amateur.
Looks like part of the window trim has dropped down in the center. Show a picture a bit farther back.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 09-29-2014, 09:07 AM   #227
Billys68SS
Billys68SS's Avatar
That's what I was thinking. Something doesn't look right on the painted part just above the chrome window trim.
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 09-29-2014, 10:40 AM   #228
Groyd
Groyd's Avatar
It was before I put the set screw in. I fixed that part, still couldn't get it to the top. I'll get a better pic tomorrow.
Thanks.
1951 Chevy 3100/S-10:
http://67-72chevytrucks.com/vboard/s...d.php?t=406072
1957 Chevy 3200
1971 2WD Blazer - Sold
Groyd is offline   Reply With Quote
Old 10-01-2014, 11:34 AM   #229
Groyd
Groyd's Avatar
I can squeeze both sides of the window and pull it a little higher, but it wins stay up. Almost stripped out the handle trying to keep it raised. Any suggestions? Is it the new guides? When looking at the regulator, the teeth are towards the handle side and you can see the spring wrapping around the bottom of the regulator. I don't think I have the regulator upside down or if that's even possible.
1957 Chevy 3200
Old 10-01-2014, 11:48 AM   #230
Billys68SS
Billys68SS's Avatar
Looks like it's tipped down in the front. So it's probably binding up. I can't tell you how or where, but that's what I would be looking for.
Old 10-01-2014, 06:42 PM   #231
oldman3
oldman3's Avatar
I agree with 68SS, seem like the rear of glass in raising faster that the front. Can you loosen the screws for the regulator, pull the front of glass up a little and then retighten the regulator screws....Jim
oldman3 is offline   Reply With Quote
Old 10-01-2014, 10:04 PM   #232
99 to Life
99 to Life's Avatar
great looking truck and progress. that your 57 as well? nice!!! as for the window I'm sure none of has the exact answer for you since we can't really see what is goin on. Did the other side work?
I personally feel its in the regulator, it just seems like its maxing out. I'd take it out and make sure its in the right position.
the back portion theory may be somewhat right, but I don't think thats your sole problem. If you look close your back isn't even up into the window track fully.
Here is a pic of what you should have correct?
I'd suggest maxing out your regulator either all way up or down and installing in correspondence with window all way up or down.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 10-02-2014, 11:37 PM   #233
Groyd
Groyd's Avatar
Yeah, the '57 is going to be on hold until I get this one buttoned up.
I haven't messed with the windows. It's the same on both sides, about an inch short of closing. Even pulling by hand it's short, makes me think it's the regulators. I'll try and mess with it some this weekend.
Got the back fenders and drivers front fender on today though.
1957 Chevy 3200
Old 02-10-2015, 10:11 PM   #234
Groyd
Groyd's Avatar
Spent approximately 30 hours trying to line up the hood and front fenders. I ended up taking it to a local guy that I met thru another board member (Thanks Hooch). Millard got the hood to close and is still working on the gaps. It's gonna be a booger. Ended up having to raise the front body mounts 1 1/2".
1957 Chevy 3200
Old 02-10-2015, 10:38 PM   #235
J48chevy
J48chevy's Avatar
Originally Posted by Groyd View Post
I need some help on this one, I've considered about a thousand different paint and color options. I've been considering "Legend Lime Green" that was on the 05-06 F**d Mustangs and maybe some small gray or black pinstriping.
But after I saw the "Mocha Steel Metallic" on the newer GM models I've kind of been jumping back and forth. I know I definitely want some pinstriping done afterwards and I'm not sure how great it would look with the brown. I know kustombrad http://67-72chevytrucks.com/vboard/s...d.php?t=320546 did some stripes with brown and it looked great. Any input appreciated.
If it helps, I'm planning on these wheels.
Kind of partial to the green myself.
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 02-10-2015, 10:38 PM   #236
Groyd
Groyd's Avatar
Pass side
Drivers Side
1957 Chevy 3200
Old 02-10-2015, 10:40 PM   #237
Groyd
Groyd's Avatar
That looks sharp.
1957 Chevy 3200
Old 02-10-2015, 10:44 PM   #238
J48chevy
J48chevy's Avatar
That looks sharp.
I really like the color you went with too. Looks good. Going to do my 48 truck in the new Impala blue. Thought about having car and truck same green but decided on blue.
Old 02-10-2015, 10:45 PM   #239
99 to Life
99 to Life's Avatar
dang, yeah good luck with that. I'v heard some horror stories on fitment and really, the factory never cared about fitment. the hood to fender is a pain I feel either you luck out or you don't with what you get to start with.
ever jump back on your window issue?
Old 02-11-2015, 12:00 AM   #240
Groyd
Groyd's Avatar
I ended up stripping the pass side regulator trying to force it up. I'll have to take it all back out and replace the regulator. Hopefully better on the second go round. On a good glass note, I got the front, back, and corner glass put in (hired it out). Looks great.
Dakota VHX gauges installed.
It also smelled like it was running a little rich. May get it tuned by a guy around here. That being said, it sounds nes incredible when it's running.
1957 Chevy 3200
