Old 02-08-2011, 05:02 AM   #226
matthew20061
69' Chevy Stepside
matthew20061's Avatar
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
Originally Posted by 85burb View Post
Good to hear of progress was getting worried there for a min.
-Matthew
-69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead"
- Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread
-1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed
-1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting
-2003' Chevy Silverado SS AWD 6.0L! - Daily Driver
matthew20061 is offline   Reply With Quote
Old 02-08-2011, 03:21 PM   #227
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by 68GMCCustom View Post
Got the trans TV cable and throttle cables and linkages all setup.
What is your TV cable hook-up? Did you use bowtieoverdrives? Lookin' good
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-08-2011, 10:52 PM   #228
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
actually my trans builder provided the cable. It had all the various adjustments and a square OEM style plastic mounting point which wound up fitting my TCI carb bracket perfect. I have a Lokar throttle cable and was going to use a Lokar carb bracket but decided to go with this TCI one to keep the trans happy. Also mounted an adapter to the carb linkage that changes the linkage ratio for the TV cable. The TCI bracket isnt fancy but it works great. WOT has the tv cable about 1/4" away from its stop. I'll get pics of it all.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-09-2011, 10:28 AM   #229
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Looking really good buddy!
--Josh
Old 02-09-2011, 03:27 PM   #230
68GMCCustom
thanks!
Kurt -
Old 02-09-2011, 11:50 PM   #231
68GMCCustom
OK...here's some of the latest pics.
heater cores lower pipe busted loose so I decided to pull the heater box apart:
some of the stainless steel brake line going in:
and the trans builder supplied TV cable, TCI carb bracket, and Lokar throttle cable:
plan on reversing the throttle return springs.
Kurt -
Old 02-10-2011, 12:32 AM   #232
85burb
85burb's Avatar
That is some facny set up there. Hope it works good for ya. Cant wait to here that thing running.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 02-10-2011, 01:23 AM   #233
mcbassin
Still Learning
mcbassin's Avatar
Hey your cab looks like it's in really great shape. Don't look like it's gathered any rust at all. Where did you pick up the brake lines? Those look really nice.
mcbassin is offline   Reply With Quote
Old 02-10-2011, 11:28 AM   #234
68GMCCustom
thanks 85burb, it even had a Lokar carb bracket...but I decided function was better then beauty. :lol;
thanks mcbassin, it was redone back in the 90's. I found one bad spot in the heater box area that had been repaired. I plan on doing body and paint in a year or so, and just patch things as i go until then.
I wound up going with Inline Tube for the brake lines and stuff. I ordered the hardware (fittings, clamps, etc) yesterday...forgot about it when I ordered the full brake line set. Guess I thought they were included.
Kurt -
Old 02-10-2011, 05:31 PM   #235
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice progress! It is looking great!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-10-2011, 08:06 PM   #236
mcbassin
Still Learning
mcbassin's Avatar
What fittings and clamps were not included? Where did you order them? directly from inline? thanks
Old 02-10-2011, 08:24 PM   #237
85burb
85burb's Avatar
Shoot you mean it was fancyer??? I still have my factory everything.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2011, 10:27 PM   #238
68GMCCustom
mcbassin...when you buy the lines...your just buying the lines. They sell their clamps, fittings, and brass T's all separately. Would up spending another $95 on all mentioned plus a rear s.s. flex brake hose and S&H.
85burb...it had this carb bracket in until I got to looking at the TV cable I had and what pieces I had and didn't have (would have needed whats called the kickdown bracket to go with it) and by mixing what I had I didn't need to buy anything else. The TCI bracket is deff. sturdier and Lokar cables are built nicely.
here's what the Lokar bracket looked like. I should mention...my TV cable had both the slider type attachment and the black plastic clip-on, both using the barrell type cable lock...and after having a failure... I have a thing about plastic in my linkages. Also, I left some length on that TV cable for now...just so if I do decide to move/change something I'll have the length to do it.
http://lokar.com/interior_pages/prod...es/srk4000.jpg
...and here's how it would be w/the kickdown mounting bar on the bracket
http://lokar.com/interior_pages/prod...00-drawing.jpg
edited the pics to urls.....someones not allowing the linking...
Kurt -
Old 02-10-2011, 10:34 PM   #239
85burb
85burb's Avatar
The pics did not show up. They just look like red Xs. Why do some pics look like that?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-10-2011, 10:53 PM   #240
68GMCCustom
irritates me when sites do that...here's a pic from Summit.
TV cable adds a second bar that drops down...making an upside down V sort of.
Kurt -
Old 02-10-2011, 11:05 PM   #241
85burb
85burb's Avatar
Oh i see. Looks nice. Yes it is just about the worst thing when pics dont show up. Like the ones you really want to see like some one just put new motor in and it looks like a tiny box with an stupid red x in it. Really blows the hole moment.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-12-2011, 01:23 AM   #242
68GMCCustom
Pulled about a mile or more of electric tape off of my trucks external (under hood) wiring harnesses today. What a mess! Looking at the wire it looks like someone bought new harnesses (except rear harness)... then hacked them all up!
I cut out a bad patch in the rear lighting harness and soldered/heat shrinked in some new wire then wrapped with friction tape. I have the harness installed now but not locked down.
I know....I know...I'll try to post the pics tomorrow.
Kurt -
Old 02-12-2011, 02:12 AM   #243
85burb
85burb's Avatar
Ha Ha real funny. I was waiting and waiting for pic to load.....Dang it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-12-2011, 03:36 PM   #244
68GMCCustom
nothing exciting...but heres the pics:
repairing 2' of the harness for the rear lighting. Spliced, soldered, shrink wrapped, over-shrink wrapped, and then friction tape wrapped:
some of the wiring mess after I pulled it all apart:
the new "news".........inline tubes brake line fittings, T's, and rear s.s. flex hose should arrive today, a few new tools (3/8" TAP to fix a bung + 1/4" NPT TAP cause I don't have one) on Monday or Tuesday...and.....B&M Truck Megashifter on Tuesday or Wednesday. I decided I didn't want to wait for it and fight the column shifter at the track.
Kurt -
Old 02-12-2011, 09:44 PM   #245
85burb
85burb's Avatar
If you want when you are done with your wires ya can come help mine out... Looks really good. Wifes truck had a floor shifter and i loved it. Want one in the burb but the hole 4x4 shifter is in way.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 02:47 PM   #246
68GMCCustom
Oh no......wiring is certainly not my calling.....since I'm color blind!
Didn't really want to have to spin the coin for a shifter...but it was necessary for track use.
I installed the O2 sensors for the UEGO gages and routed the cables into the cab. Looks like I'm gonna leave the MSD box under the hood as its too much harness to bring into the cab. Got the starter wires wrapped and routed, and then roughed up and spray bombed semi flat black under the dash to cover all the blue...since I'm going in with all black carpet and trim. It will look good enough with everything in... until I pull it all apart again to paint it properly in a year or so.
Kurt -
Old 02-13-2011, 08:21 PM   #247
85burb
85burb's Avatar
Looks great. Wireing is deff not my calling. I start out doing good job then get in a hurry and just do it to get it done. You should see under my dash..... Scares me sometimes. Do you think they gave you enough uego wires. I have like a 10 foot coil of it zip tied to my steering colum under dash.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 02-13-2011, 11:38 PM   #248
mcbassin
Still Learning
mcbassin's Avatar
Thanks,
So if you don't mind me asking, what does a "complete" SS brake line setup cost you from inline? I'm at the point of needing to decide what to buy. I appreciate your help.
Old 02-14-2011, 11:57 AM   #249
68GMCCustom
well the full s.s. brake line set is $185. I don't have the invoice in front of me...but I think I spent another $75 or so on a rear s.s. hose (got the 2 front s.s. hoses with my CPP brake kit), all the brass T's, all the fittings, and all the clips... + S&H.
So....something like $250-$260? Making it $300 or so with all 3 (2 front-1 rear) s.s. hoses plus the s.s. line set and all the hardware.
Kurt -
Old 02-16-2011, 07:39 PM   #250
68GMCCustom
more parts in.....shifter, brake fittings, and a couple of TAPs and TAP wrench.
Now I can finish fuel system, brake system, and engine/trans linkages. I'm also working on the electrical....so it won't be long before I can prime this thing up and light the fire!
Kurt -
