Old 05-02-2011, 07:40 PM   #226
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
I have an old Autocad system on my old PC that I use for drawings. I drew up the structure I wanted for the top, based on the mockup. This way I knew what angles I needed to cut my pieces to form the shape of top.
oldman3 is offline   Reply With Quote
Old 05-02-2011, 07:44 PM   #227
oldman3
oldman3's Avatar
A few days later and here is most of the aluminum structure welded in place. I've never welded aluminum before, and it's not easy, and mine welds look like ****. What I did was convert my MIG to weld aluminum. You have to use pure argon, I also had to use .030 aluminum wire (the .023 just bunched up in gun). When you first start it isn't hot enough, but does OK after you get going. I just ground out the real bad stuff at the start.
Old 05-02-2011, 07:46 PM   #228
oldman3
oldman3's Avatar
View from the back, if you look at the left side you can see how I have the new roof sloping inward, and not going straight up.
Old 05-02-2011, 07:49 PM   #229
oldman3
oldman3's Avatar
When I got the top fabed, I knew I had a problem with the initial header and door piece layout. Before I go on, if you look at the door piece you can see where I welded in a piece of metal to fill in where the old molding used to be.
Old 05-02-2011, 07:51 PM   #230
oldman3
oldman3's Avatar
May be hard to see the yellow tape, but this is the new design layout for header and door piece.
Old 05-02-2011, 07:53 PM   #231
oldman3
oldman3's Avatar
Pic 1 Now I'm on the passenger door, but you can see the metal has been cut for the A pillar and header.
Pic 2 Metal removed.
Old 05-02-2011, 07:55 PM   #232
oldman3
oldman3's Avatar
Pic 1 Part of header material removed.
Pic 2 More header material removed and trying to figure out new design on the A pillar.
Old 05-02-2011, 07:58 PM   #233
oldman3
oldman3's Avatar
Pic 1 Made new inside piece that door will go against.
Pic 2 Here the new metal has been added to door. After I cut off the old curved part I had to dig thru the old door upper parts to find a straight piece to install.
Old 05-02-2011, 08:00 PM   #234
oldman3
oldman3's Avatar
Pic 1 Here is the new header and door design with top it position.
Pic 2 Close up with the wood window up. Now the header, door, window and top all meet at a nice point.
Old 05-02-2011, 08:02 PM   #235
oldman3
oldman3's Avatar
Here is the top with the aluminum sheet installed on the structure. I used .050" aluminum to make the cover.
Old 05-02-2011, 08:04 PM   #236
oldman3
oldman3's Avatar
Pic 1 Front view.
Pic 2 3/4 view.
Pic 3 Full front view.
Old 05-02-2011, 08:08 PM   #237
oldman3
oldman3's Avatar
Most of my info on this top came from an article I read in one of the rod magazines (can't remember which one, but I think it was on a 32 F**d roadster pickup) about size of material, etc.
Well about 3 months had passed during this time, not all in the shop, but time doesn't stand still. On to the next job.
Old 05-03-2011, 06:03 AM   #238
Indian113
Indian113's Avatar
Jim, did you use rivets or screws to put the top together on frame? Love the door latches simple yet unique.
Indian113 is offline   Reply With Quote
Old 05-03-2011, 08:22 AM   #239
Russell Ashley
Russell Ashley's Avatar
Been following this thread for a while now. That is totally cool! Nice work..
Russell Ashley is offline   Reply With Quote
Old 05-03-2011, 01:22 PM   #240
oldman3
oldman3's Avatar
Yes I used rivets, put a little dough over them, primered, then had it covered with closed cell foam and contvertible top material. If i had a Tig welder I would have tried to weld, but not with the Mig.
Old 05-03-2011, 01:24 PM   #241
oldman3
oldman3's Avatar
Thanks, appreciate you following the build. Jim
Old 05-03-2011, 01:36 PM   #242
xpickup
xpickup's Avatar
oldman3, I love the convertable top. I often thought about it if I ever found cab with a damaged roof. Looks good.
Shannon
xpickup is offline   Reply With Quote
Old 05-03-2011, 02:35 PM   #243
oldman3
oldman3's Avatar
Shannon
Thanks, appreciate it.
Old 05-03-2011, 02:45 PM   #244
OrrieG
OrrieG's Avatar
Cool mini-Carson top!
OrrieG is offline   Reply With Quote
Old 05-03-2011, 05:00 PM   #245
oldman3
oldman3's Avatar
Thanks, Jim
Old 05-03-2011, 08:23 PM   #246
oldman3
oldman3's Avatar
Pic 1 Anyone who has one of these old trucks, knows how hard it is to get the hood to fit even close. Since I had a large gap at the cowl, I chose to add steel to the cowl and have a nice gap at the hood. In spots the steel was as wide as 1/4" and others about 1/8".
Pic 2 passenger side view
Pic 3 about center.
Old 05-03-2011, 08:26 PM   #247
oldman3
oldman3's Avatar
A few days later, here is the cowl and header in primer.
Old 05-03-2011, 08:28 PM   #248
oldman3
oldman3's Avatar
Pic 1 Hood, cowl, windshield area and top of doors in primer.
Pic 2 Here I've sanded, and it's ready for another coat of primer.
Old 05-03-2011, 08:29 PM   #249
oldman3
oldman3's Avatar
Here I've got the dash in primer.
Old 05-03-2011, 08:31 PM   #250
oldman3
oldman3's Avatar
Now I've moved to the running boards. This is the back running board bracket, it didn't fit right to the 54 running boards, so I cut, bent and welded it back (both sides).
