Re: Rods 57
Thanks, i am just finishing up cleaning the insides and getting ready to prime and paint some stuff.
Re: Rods 57
I have rust in the same spots on my fenders. Truck is looking good!
My '59 Build Thread |
Re: Rods 57
the difference is in spring rate, there is a slight height and diameter difference, but I have found that just cutting the coils for ride height works fine, they get softer (less spring rate) the more you take off, If you only want 2-3" cutting coils will work fine. if you do ,make sure to flatten the coil after cutting so it sits in the spring pocket as before.
Learn to deal with reality, or reality will deal with you. |
Re: Rods 57
From the pic it doesn't look like the engine is in.
If it isn't the weight of it will lower the front some. Kim |
#5 | |
Re: Rods 57
thanks for the comments |
Re: Rods 57
I have new springs also. Mine didnt drop after first installing engine. Drove it around the block a few times and it dropped about 3/4 inch. My problem is front wheels still have about 1/2 inch negative camber with out any shims installed. Front end still needs to come down about 1-1/2-2 inches to get any positive camber. I am thinking about cutting one coil and see what happens. What did your wheel camber look like with engine installed?
#7 | |
Re: Rods 57
#8 | |
Re: Rods 57
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
Re: Rods 57
thanks I like the ride height of yours. There is a local spring shop here and I think I will have them look at them before I do anything.
Re: Rods 57
put it all together and wait a yr before you do anything
if it really bugs you remove the springs and stick a 2x4 in there cut to the length of your ride height don't jump the gun and start altering stuff untill all the weight is on your truck in the picture below the suspension is locked in on the upper stops by the shocks fully extended, a arms are running down hill
Re: Rods 57
Got the answer back on the springs. there were three different springs they used, with three different rates and sizes. So need to get mine apart and get them checked out or replaced.
In the mean time, got an idea and bought a 70's vette wheel on craigslist, I am going to modify the horn ring off of one of the original wheels from the three trucks I started with and heres what I end up with. total cost, $65... |
Re: Rods 57
Great gob on the truck Rods.
#13 | |
Re: Rods 57
Thanks, Tanman. it's been fun project, and I am always amazed at the info I get on this forums, seems like anything I need to know is here. Posted via Mobile Device |
#14 |
Re: Rods 57
I have one question for you. By chance do you know the width of the camaro front , from I guess hub to hub? where the rim sits on the hub. I have a 79 front clip and its all torn apart. If you dont its ok.
Thanks |
#15 |
Re: Rods 57
So from the hub surface that the wheel sits on its 60 5/8 from the outside of the rotor to rotor it's 56 3/4. It that what you needed?
#16 |
Re: Rods 57
That is what I needed. Thank you very much sir.
#17 |
Re: Rods 57
No problem, see anything you need.....it here.
#18 |
Re: Rods 57
any new pics or updates
1958 Chevy Apache Stepside 1955 BBW Fleetside |
#19 |
Re: Rods 57
Not really, unless sanding dust is an update. I do have a pic of some work I did for my mother in law. I call it practice for my truck...
#20 |
Re: Rods 57
nice repair on the grille
#21 |
Re: Rods 57
got some stuff done. Had my seat frame and springs powder coated 60% gloss black. I know only a few inchs shows but it will never rust. I also got a different steering wheel I only paid $35 for it total, I had the center section already. Also just fitting the doors and getting the springs out decided to go with 1 inch lowered springs up front.
#22 |
Re: Rods 57
That's a nice wheel.
Kim |
#23 |
Re: Rods 57
Thanks, I painted this one they are cheap so I didn't repair the broken one just the paint work.
I know its pretty nice. Has a few cracks but nothing major. should look great red.... |
#24 |
Re: Rods 57
looking good i'm running the same wheel (56 210) in my truck love it
#25 |
Re: Rods 57
I saw rude dude on this site had one of the three spoke type and I loved it, plus I have a 55 as weel as the truck and I have always liked the way it looked.
| Bookmarks |
