Old 03-12-2013, 08:18 PM   #226
williamsboys
williamsboys's Avatar
Re: 66 c10 first timer build
So just line the tdc mark with zero on the tab then check springs, I want the springs to be compressed on the #1 is that right?[IMG]http:/ [/IMG]
[IMG]http:/ [/IMG]
Williamsboy
williamsboys is offline   Reply With Quote
Old 03-12-2013, 08:20 PM   #227
williamsboys
I haven't done it yet. Just put up some pics for the pic lovers. Will probably do it tonight. Actually, I really don't need to do it till we fire it up right?
Williamsboy
Old 03-12-2013, 10:14 PM   #228
Ta2Don
Ta2Don's Avatar
Definitely before you install dist to fire up. Both springs on 1 should be uncompressed
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 03-13-2013, 09:29 AM   #229
rustbucket66
Yes, the springs on number 1 NOT compressed. Now make sure the rotor on the distibutor is pointing to the number 1 post on the cap.
rustbucket66 is offline   Reply With Quote
Old 03-26-2013, 08:51 PM   #230
williamsboys
Anybody running this trans cooler or one like it? Pics of where u mounted them would be great. Thanks.
[/IMG]
Williamsboy
Old 03-26-2013, 08:51 PM   #231
williamsboys
[/IMG]
Williamsboy
Old 03-26-2013, 08:53 PM   #232
williamsboys
Well I can't get the pic to post but it's the tubular finned one from jegs
Williamsboy
Old 03-26-2013, 08:56 PM   #233
williamsboys
[/IMG]
Williamsboy
Old 03-26-2013, 08:57 PM   #234
williamsboys
Williamsboy
Old 03-26-2013, 08:59 PM   #235
williamsboys
Dang now all the sudden my pics won't load.
Williamsboy
Old 03-26-2013, 09:04 PM   #236
williamsboys
[/IMG]
Williamsboy
Old 03-30-2013, 04:49 PM   #237
williamsboys
Ok I just received my champion radiator and shroud and electric fan. I got no instructions on how to put it all together. Any pics or directions I can follow?
Williamsboy
Old 03-30-2013, 04:59 PM   #238
williamsboys
Williamsboy
Old 03-30-2013, 05:07 PM   #239
williamsboys
Do I just use self tapping screws to screw the shroud to rad? And as far as fan mounting kinda confused, do I put the plastic pices that slide into the outside of fan then drill holes where they line up then use the long plastic strips to go threw rad and shroud then cap off on the fan?
Williamsboy
Old 03-30-2013, 06:49 PM   #240
williamsboys
I think I'm just gana screw fan to shroud and screw shroud to rad. Any thoughts on that?
Williamsboy
Old 03-30-2013, 09:28 PM   #241
williamsboys
[/IMG]
Williamsboy
Old 03-30-2013, 09:31 PM   #242
williamsboys
I don't no why my pics arnt showing up now.
Williamsboy
Old 03-30-2013, 09:33 PM   #243
williamsboys
http://
Williamsboy
Old 03-30-2013, 09:37 PM   #244
williamsboys
http://
This was the trans cooler I was trying to post to see if y'all had some picks of any y'all have
Williamsboy
Old 03-30-2013, 10:09 PM   #245
williamsboys
http://
Williamsboy
Old 03-30-2013, 10:10 PM   #246
williamsboys
http://
Williamsboy
Old 03-30-2013, 10:11 PM   #247
williamsboys
I wonder if one of those trans coolers would fit on the crossmember below the radhttp://
Williamsboy
Old 03-30-2013, 10:15 PM   #248
williamsboys
I just have the rad sitten there I got to order two new rubbers for the top mount, and I guess I will need to bend the bracket a little becuase I tried with old rubbers and it was like it wouldnt go all the way down on it. Then I'll screw the fan and shroud on.
Also looking to get one of those smooth stainless canisters for the overflow. Also hereto get rad hoses, going with the braided steel ones I think
Williamsboy
Old 03-30-2013, 10:47 PM   #249
McMurphy
McMurphy's Avatar
Someone just mounted one of those trans coolers to the outside frame rail of their build, rear of the transmission.
Wish I could remember off hand who it was, but it was just this past week.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 03-30-2013, 10:53 PM   #250
williamsboys
O ok, cool thanks man
Williamsboy
