Old 10-31-2012, 01:54 PM   #226
xpickup
xpickup's Avatar
Re: 48 panel truck
Chevette, oldman3, Daze57, Thank you for checking in on me, that means alot. My thoughts are there for the people having to deal with it. We were lucky this time from dodging it.
Shannon
xpickup is offline   Reply With Quote
Old 11-02-2012, 07:56 AM   #227
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 48 panel truck
Good to hear ya guys made it out ok..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-07-2012, 08:01 AM   #228
xpickup
xpickup's Avatar
Re: 48 panel truck
FRENCHBLUE72, Thank you.
I changed out the antifreeze last night because it is getting cold here fast. I did not want what happened to my buddies motor. No antifreeze = pushed out freeze plug and the side of the block= JUNK.
Shannon
Old 11-12-2012, 11:15 PM   #229
xpickup
xpickup's Avatar
Re: 48 panel truck
Well I know it is not a Chevy but here is what I am working on now. It is a 1953 Ford F100. It has a scary pipe notch in it that is about a 1/2 thick and that is the cross section of the frame at that point. I started on it this weekend, built a notch, put in a new rear cross member, removed the factory ones, boxed the frame, and removed all the springs. It is getting a triangulated 4 bar and bags all the way around. I hope to have the rear done this weekend which should not be a problem , then onto the front.
Shannon
Old 11-12-2012, 11:44 PM   #230
99 to Life
99 to Life's Avatar
Re: 48 panel truck
I actually really like those fords. The one in the Expendibles or whatever that movie is was sick. I dunno how you get your hands on sooo many projects. Maybe cause I don't know enough people round my parts, but I have one friend I talk to about old cars. Another friend that has a 53' bel air and that is it as far as good friends that are into this stuff. I've met some folks along the way but seems like you know alot of people that have cool old rides. keep up the good work. You building your own tri link? I'm going to be heading into this on my next project. The prices they put on these link systems are ridiculous.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-13-2012, 12:34 AM   #231
oldman3
oldman3's Avatar
Re: 48 panel truck
Shannon, say it is so, a F#rd, nah just kidding. I've always liked the 53 thru 56 F100's. Man that hold frame notch was scary looking. Your doing a great job as always. My son and I have used the tri-4 bar kits from Horton Welder Series and work real nice...Jim
oldman3 is offline   Reply With Quote
Old 11-13-2012, 07:53 AM   #232
xpickup
xpickup's Avatar
Re: 48 panel truck
99 to Life, I like it also. I actually am going to buy a 53-55 cab and hood cheap real soon. I get work by just word of mouth. The rear was a kit but you know it is I am remaking half of it! I like the f100 in that movie also.
oldman3, It was scary. I would not pull the bed off till I had the new one in. I have used stuff from Welder Series and was always pleased with it.
Shannon
Old 11-13-2012, 10:02 AM   #233
69CST-V
69CST-V's Avatar
Re: 48 panel truck
Another one for you to work your magic on. I like the 53-56 F100's as well. Can't wait to see it come together.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 11-19-2012, 11:52 AM   #234
xpickup
xpickup's Avatar
Re: 48 panel truck
69CST-V Thank you.
Well this weekend I got a good bit done. Made the lower links, finished welding in the boxing, and made what I need to put everything in. I have the suspension all in and just need to make the upper bag mounts yet and finish up some welding and a few odds and ends. I could not wait to cut the old notch out so I did at about 7 last night. I was funny when I went in for supper and my wife asked what I was doing because the lights on the house were diming. I was running my big air compresser and running the plasma cutter which draws alot. I was cutting through at least 1/2' plate. The only thing I have to change is the front cross member on the notch because it hits a little on the upper links. Then mount the fuel cell and then onto the front.
Shannon
Old 11-19-2012, 12:25 PM   #235
99 to Life
99 to Life's Avatar
Re: 48 panel truck
shannon, looking good. Where did you get your bushings? This place was the cheapest I found on an them, even link bars. I wanted to build my own but for the cost of bushing and the D.O.M tubing, it would be about the same as buying them. http://www.customconnectionllc.com/ I am going to be making some bottom link bars like yours. I like that set up and bag location the best from the looks of things. I know there are tons of ways to bag something, but I def like this route. keep it up, good work as always.
Old 11-19-2012, 12:59 PM   #236
xpickup
xpickup's Avatar
Re: 48 panel truck
99 to Life, Good site. It is cheaper to buy there weld on ends from them than buying tubing and buy the bushings for them and making the ends. The piece of DOM tubing from McMaster Carr was $29 for a foot. Then I had to saw it and I turned the ends. I used 2"x2" 1/4 wall tubing for the lowers. Then used the kit for the rest.
Shannon
Old 11-19-2012, 01:23 PM   #237
Chevette
Chevette's Avatar
Re: 48 panel truck
Very good fabrication, Shannon. As per usual.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 11-19-2012, 07:51 PM   #238
oldman3
oldman3's Avatar
Re: 48 panel truck
That looks SO much better that the previous stuff, nice job....Jim
Old 11-19-2012, 08:35 PM   #239
99 to Life
99 to Life's Avatar
Re: 48 panel truck
shannon, yeah that site and welder series has some good stuff. D.O.M is just expensive, but sometimes you can get run offs at places for cheap. I'm lucky to have a friend up this way that deals with a supply shop, so now I should be able to get some material. Also summit sells DOM and square tubing now, which is cool. I think you can get a 4ft piece for 30 bucks, but then add 17 for shipping.
Old 12-22-2012, 10:02 PM   #240
xpickup
xpickup's Avatar
Re: 48 panel truck
Well it seems like forever since I last posted. The truck is all finished and already went home. It took about a month to do everything. It raises up to about 7.5 inches and layes out about an inch off the ground. I used camaro shockes up front and made the mounts, also relocated the bump stops. The rear I used g body shocks mounted to the lower links and bump stops on the bidge (no pictures of that). Tomorrow the next project is coming. So a new chevy build thread. Here are some pictures of the truck.
Shannon
Old 12-23-2012, 12:35 AM   #241
oldman3
oldman3's Avatar
Re: 48 panel truck
Looking forward to your next project, what will it be so I can keep an eye out for it...Jim
Old 12-23-2012, 10:12 PM   #242
xpickup
xpickup's Avatar
Re: 48 panel truck
oldman3, it is 1951 Chevy / C4.
Shannon
Old 12-24-2012, 12:21 AM   #243
oldman3
oldman3's Avatar
Re: 48 panel truck
Sound interesting....Jim
Old 04-30-2013, 09:37 PM   #244
xpickup
xpickup's Avatar
Re: 48 panel truck
Well I have not posted on this thread for a while. I bought a steering wheel for the panel because I had the sad looking Malibu wheel still on. I took it to a show on Friday night and in the morning I drove it to work . It seemed to start hard. Did it on Saturday morning too. Then came Sunday, no spark at all. So put a module in it . Started but ran really crappy. Then I got grease on the fender. I got my spray bottle out that was marked wax and grease remover. Wrong, I put liquor thinner in that bottle the last time and sprayed it on the fender. Well I will need to touch up the epoxy now after I wiped it around. Looked at the rag and seen the grey color, of coarse I had a few choice words. I will probably put spark plugs in it. But I also am changing out the intake from a single plane to a dual plane to get some more bottom end. I also bought a new HEI, wires, and a holley carb. My carb I first had on it is rebuilt but still does not run right and the one that is on it is a buddies. So I bought a new one. So I can not wait to change everything over when I get time, or I should say make time. So I can not wait to get home tomorrow because the brown truck is coming!
Shannon
Old 04-30-2013, 11:35 PM   #245
oldman3
oldman3's Avatar
Re: 48 panel truck
Shannon, love the wheel nice choice. Hope all the new stuff takes care of the engine problem. I think the dual plane with make a big difference....Jim
Old 05-01-2013, 09:37 AM   #246
mknittle
mknittle's Avatar
Re: 48 panel truck
Shannon
Cheaper and you are labor ahead. more time for other things on the project
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 05-01-2013, 09:48 AM   #247
mknittle
mknittle's Avatar
Re: 48 panel truck
Well I have not posted on this thread for a while. I bought a steering wheel for the panel because I had the sad looking Malibu wheel still on. I took it to a show on Friday night and in the morning I drove it to work . It seemed to start hard. Did it on Saturday morning too. Then came Sunday, no spark at all. So put a module in it . Started but ran really crappy. Then I got grease on the fender. I got my spray bottle out that was marked wax and grease remover. Wrong, I put liquor thinner in that bottle the last time and sprayed it on the fender. Well I will need to touch up the epoxy now after I wiped it around. Looked at the rag and seen the grey color, of coarse I had a few choice words. Shannon
When I have days like that It reminds my of an old Chevy Chase movie.
Mark
My GMC build.
Old 05-01-2013, 10:01 AM   #248
mknittle
mknittle's Avatar
Re: 48 panel truck
Shannon
I am the same way. I don't have too many things that I didn't modify.
Even my trees {Bonsai}
It seems the every time I buy a kit most of it ends up in the iron pile.
Mark
My GMC build.
Old 05-01-2013, 03:14 PM   #249
youngrodder
youngrodder's Avatar
Re: 48 panel truck
Shannon-
I see you rebuild carbs like I do. Grab a new one out of the box and bolt it on...Good luck on all the performance upgrades that you have in store.
We will be watching.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-01-2013, 09:30 PM   #250
xpickup
xpickup's Avatar
Re: 48 panel truck
Oldman3, I looked at a bunch of different wheels and they had a bunch of different prices. This one did not break the bank. I thought it somewhat matched my wheels. Yes hope it runs better when I am done. My old intake would be better with a higher converter and more gear. I wanted yo go fast now I just want to get there. I must be getting older. Haha
Mknittle, it always seems like when you buy stuff it never fits and or need modified. At least when my buddy bought that kit and I only used half of it, I now have half of one for myself.
Youngrodder, carbs can be a pain. That is one thing I will never buy used. You never know how much modifying they did and things the drilled out.Yes I can not wait to see the difference in it. Although it was really fun on the highway at the higher Rpms.
It was a good day , my parts came from summit. I also had been looking for another welding bottle. I already have 2 but I wanted another 75/25 bottle. I have a straight argon bottle for my TIG so that is good enough. I always seem to run out of mig gas on the weekend so now I will not. He sold it to me for $80. You can not buy very big bottles anymore. They only want to rent them. I did not want to rent one.
