Old 12-05-2021, 09:21 PM   #1
Old_Truck_Fan
Re: Project "Financial Burden": 1968 SWB C10
1968 SWB C10 http://67-72chevytrucks.com/vboard/s...d.php?t=508675
2011 Dodge Ram 1500
2012 Camaro ZL1
Old_Truck_Fan is online now   Reply With Quote
Old 01-02-2022, 09:07 PM   #2
Old_Truck_Fan
I picked this up from RPM Transmissions over the holidays. It's a close ratio T56 magnum with a 2.66 first gear ratio and 0.63 sixth gear.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 05-29-2025, 04:35 PM   #3
68 C10 Driver
Originally Posted by BigBird05 View Post
What did you spray on the interior of the fire wall?
Sorry for seeing this so late. I sprayed on Lizard Skin Thermal and Sound Barrier to the inside of the cab. I have read about great results with this product and thought I would give it a shot. The sound deadening properties are great, the cab has a solid sound to it when you knock on it, totally removes that tinny sound. Great product, should also help keep the interior cooler in the summer as well.
68 C10 Driver is offline   Reply With Quote
Old 06-02-2025, 08:52 PM   #4
Old_Truck_Fan
Next wave of parts.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-03-2022, 11:01 AM   #5
Jiggers72-GMC
Very nice Transmission, it will be fun to run through the gears .....
Jiggers72-GMC is offline   Reply With Quote
Old 01-13-2022, 09:11 AM   #6
KevinK7
KevinK7's Avatar
subscribed, ...holy smokes you got some mad skills
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 08-07-2022, 08:58 AM   #7
Jiggers72-GMC
Wow, great idea, very well done, nice workmanship
Old 11-13-2022, 11:33 AM   #8
layinrocker65
layinrocker65's Avatar
Any updates on this project?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 11-21-2022, 02:53 PM   #9
Old_Truck_Fan
Hi layinrocker65, I'm still working through all the small items. Here are a few of the recent pictures. Sometimes you need to go back a little to move forward. I've been working on the panel gaps and I rewired my AC system with the latest controller module from Restomod Air.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-23-2022, 09:15 PM   #10
Old_Truck_Fan
I test fit my carpet and found a few YouTube videos helpful for putting in the hole locations. I used a thin wall tube that was heated up using a propane torch. It made quick work of cutting through the carpet, backing and padding creating a nice OEM look. I also decided to go with a bed mat from Holley. It's specific to the truck so it hugs the contours perfectly. I just had to add in the hole for the fuel tank fill. I also modified the old choke knob with a magnet to hold the Terminator X 3.5 inch screen. When not in use everything looks factory.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-23-2022, 09:24 PM   #11
Old_Truck_Fan
I almost have all the minor details sorted before tearing everything down, perfecting all the panel gaps and starting on paint and body work. I've been able to test out all the electrical systems including the Terminator X setup (minus starting the engine) and everything is functioning correctly. I think I have everything covered so that re-assembly is easy. Do you guys have any words of wisdom on what you wished you checked before everything was painted that I may have missed? Here are the last pics before I start tearing things back down.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 12-23-2022, 09:26 PM   #12
Old_Truck_Fan
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 08-11-2023, 09:35 AM   #13
Stickman
Stickman's Avatar
You have some serious skills sir. Absolut beauty of a truck.
Stickman is offline   Reply With Quote
Old 08-13-2023, 10:02 AM   #14
cornerstone
cornerstone's Avatar
Incredible work on a beast of a truck. Can't wait to see it on its maiden voyage.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 10 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 10-12-2023, 04:37 PM   #15
Shifty One
Shifty One's Avatar
Master class in awesome!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 01-06-2024, 11:04 AM   #16
Old_Truck_Fan
Thanks for all the encouraging comments. I added in several 1/8 alignment holes between all the body panels for when things go back together. Using Cleco's seems to work out pretty nice. Everything is now fully disassembled and I just sent the frame and numerous other parts out for powder coating. Now I need to work on laying down that original 503 green paint code. I've got a quart of test paint to try out.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 01-10-2024, 12:42 PM   #17
raggedjim
raggedjim's Avatar
Can't go wrong with 503! Nice work, Rg
raggedjim is offline   Reply With Quote
Old 01-10-2024, 03:20 PM   #18
KevinK7
KevinK7's Avatar
Amazing!, ...this truck is going to be incredible. Super impressed with your skills, ..and man that shop is CLEAN
'68 C10 50th
Old 01-10-2024, 07:17 PM   #19
Jiggers72-GMC
Agreed, he must have an app where it erases all the clutter from the pictures, wow
Old 03-10-2024, 10:30 AM   #20
Old_Truck_Fan
The frame is back from powder coating with a satin black finish. I've also been using a small toaster oven for some of the smaller parts using an Eastwood kit.
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 03-10-2024, 10:37 AM   #21
mr.mud1
mr.mud1's Avatar
very nice,great work.the finished truck is going to be a knockout for sure.very nice work.
mr.mud1 is offline   Reply With Quote
Old 10-21-2024, 08:49 PM   #22
chewychevy67
The back bumper looks real nice.
chewychevy67 is offline   Reply With Quote
Old 11-11-2024, 07:19 PM   #23
Old_Truck_Fan
Thanks!
I finished up the inner fenders. The scallop work I did around the intercooler plumbing smoothed out nice. Checkout my test panel for the exterior paint. I think I've learned enough to tackle the shiny stuff. Wish me luck!
2011 Dodge Ram 1500
2012 Camaro ZL1
Old 11-11-2024, 07:44 PM   #24
KevinK7
KevinK7's Avatar
More incredible work, omg!
That black satin sheen looks absolutely perfect
This truck is gonna be amazing
'68 C10 50th
Old 11-13-2024, 02:42 PM   #25
68 C10 Driver
that color is the same I am using to paint my stepside. Great color!
