Old 06-20-2013, 10:14 PM   #226
budget78gmc
budget78gmc's Avatar
Re: project: 3/4 ton dropped
WOW
SOLD 1978 GMC Sierra Grande "Slow Budget Build"
1969 C10 Build
http://67-72chevytrucks.com/vboard/s...d.php?t=440536
budget78gmc is offline   Reply With Quote
Old 07-14-2013, 08:52 PM   #227
79 blue monster
79 blue monster's Avatar
so i was wondering... should i convert my truck to 1/2 ton? i can get the whole front suspension for $75. ill leave my 3/4 ton leafs so i dont have to remount 1/2ton ones. i just figure ill never use the 3/4ton part and wheels are hard to find. so i want to convert it. what do you guys think?
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP
http://67-72chevytrucks.com/vboard/s...d.php?t=518625
1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972
79 blue monster is offline   Reply With Quote
Old 07-14-2013, 08:59 PM   #228
79 blue monster
i would have to sell my 3/4 ton drop spindles and buy 1/2 ton ones though.
Old 07-14-2013, 09:12 PM   #229
lolife99
67-72 parts collector,…
lolife99's Avatar
Sell your spindles and convert.
But you can actually use ECE conversion spindles on your existing front end.
They use 3/4-ton balljoints and tie rods, but they allow the use of a 1/2-ton rotor and caliper.
No reaseon to swap anything but the spindle, caliper and rotor.
I'm sure you'll be able to sell your 3/4-ton drop spindles,...
Look here:
http://www.earlyclassic.com/tech.asp...e%20Big%20Ship
Keith
Convert to disc brakes.
Old 07-14-2013, 09:59 PM   #230
notallthere
I am biased as I like the 3/4 ton eight lug style. I know that I can get the 1/2 ton for cheap but I want to be unique for the trucks. I still plan on going lower the the 2/5 drop that I have.
notallthere is offline   Reply With Quote
Old 07-14-2013, 10:48 PM   #231
maxxxy
maxxxy's Avatar
Hey dude the truck is looking great! You have probably said it, but what is the paint code on that blue? Keep up the good work!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 07-14-2013, 11:25 PM   #232
nheller76
nheller76's Avatar
Man I don't won't to be mean but man u are letting me down! I've got a 3/4 ton and your truck is an inspiration! I know its hard but keep up the faith man u can do it and it will be great when ya finish.
Faith and Patience with my truck, that is what i pray for every day!
See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013
nheller76 is offline   Reply With Quote
Old 07-14-2013, 11:34 PM   #233
tinydb84
tinydb84's Avatar
Id keep it 3/4 ton. For the trouble and price to swap it you could get rims and tires. I have seen quite a few different types of 8 lug rims.
David
Instagram: myfabguy
Old 08-15-2013, 10:45 PM   #234
79 blue monster
its a Subaru color. World rally blue pearl.
Old 08-15-2013, 11:20 PM   #235
79 blue monster
im gonna leave it 3/4 ton. I just keep getting thoughts in my head....haha. my engine is at the machine shop now finally. I put the front end and part of the doors together, but I cant upload pics for some reason... any tips on restoring vent windows? cause there kicking my ass. also im in need of some parts. I need sierra classic hi option door panel parts, and ac brushed aluminum dash insert.
Old 08-24-2013, 01:36 PM   #236
nheller76
nheller76's Avatar
Ok man I think I'm gathering cash for my drop! What drop spindles did u get and what kind of mods did u have to do? I herd the u have to use c30 spindles and then change rotor size?
Old 08-24-2013, 05:45 PM   #237
cleansquare
Hey what size tires did you put on your stock wheels after you initially dropped it? I wanna run the same drop and the same stock wheels with my hubcaps but my tires are too big
cleansquare is offline   Reply With Quote
Old 08-24-2013, 06:21 PM   #238
79 blue monster
i went to performance online and got everything i needed. i bought drop spindles($399) and i cut a half coil out of my front springs. my crossmember sits about 2-3 in off the ground. keep in mind i have a big block and a th400. its heavier than your motor. the back i bought weld on axle perches(mounts) and welded them parallel to my stock ones. then i put the axle on top on my leafs and fliped my u-bolts unside down and remounted it. i installed c-notches just in case i hit my frame. it you use these spindles you will not need to do anything with rotors. all the same components bolt up just like the original peices.
http://www.performanceonline.com/71-...e-2-half-inch/
Old 08-24-2013, 06:50 PM   #239
cleansquare
You cut a.coil or a coil and a half? Just to clarify. Also...in your archives do you have any pics from the side after the drop and shorter tires? Ive seen the pics in the thread
Old 08-25-2013, 11:16 PM   #240
cleansquare
Do you have a 2 piece drive shaft?
Old 08-25-2013, 11:30 PM   #241
79 blue monster
hey sorry i didnt get back to you yesterday, to answer your questions, i cut only a half coil out. not 1.5 coils. my tire size is 215/65r16. and yes i have a 2 piece driveshaft. feel free to ask any questions, im here to help i couldnt find any pics, but ill take one for you, if this site will allow me to post it.
Old 08-26-2013, 12:46 AM   #242
nheller76
nheller76's Avatar
So are u running 16's on the rear? I'm worried that they don't fit around the break drum?
Old 08-26-2013, 12:48 AM   #243
79 blue monster
yes they are 16's all the way around. no rubbing. the only thing i heard was that 15in rims wont fit on the front due to the caliper hitting. might be the same situation in the back.
Old 08-26-2013, 10:01 AM   #244
cleansquare
So you used 2.5 " drop spindles up front and cut half a coil anf that netted you how much drop again?
Old 08-26-2013, 10:03 AM   #245
cleansquare
And are the stock steel 8 lug wheels 16" or 16.5?
Old 08-26-2013, 12:34 PM   #246
79 blue monster
im not sure but from stock height with good year all terrains to my 215/65r16 and my spindles and coils it dropped 8 in. and 9in in the back. but the tires that were on it were pretty tall. my crossmember sits about 2-3in off the ground and my front suspension is just barley sitting on my bump stops.
Old 08-26-2013, 12:35 PM   #247
79 blue monster
my wheels are 16in but they are off a 90's chev. i dont know what the original size was
Old 08-31-2013, 12:20 AM   #248
79 blue monster
update: tranny was rebuild not to long ago! but i found out my 454 block has a crack.
Old 08-31-2013, 10:55 PM   #249
nheller76
nheller76's Avatar
Cool Re: project: 3/4 ton dropped
O man! That SUCKS!!!!!! Guess its time to find a new one. U gona stick with 454 or 350? Everything is wide open now! I do know how that goes though. Sucky deal man.
Old 09-01-2013, 02:27 PM   #250
79 blue monster
im probibly gonna stick with the 454 but i found a caddy 500 for $700.
