08-09-2013, 09:00 PM | #226 |
Re: '66 Longbed 327 w/AC project
Disassembled the vent windows and window glass tracks, cleaned, painted those parts so i can do glass setting tomorrow. Also put the latches back in the doors/jambs, and the door bumpers in, vertical glass track installed, and put the door catches in that keep the door from opening too far.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
08-10-2013, 10:32 AM | #227 |
Your are Flyin' through this thing!
Looking Sweet |
08-10-2013, 10:47 AM | #228 |
I did hit a snag for today's work...no glass setting tape around anywhere local. Will have to order some after trying a couple more places...guess i could start sanding them fenders down!
08-13-2013, 08:59 PM | #229 |
Got windows,etc in today but window fuzzies clips broke off 2 out of 4 on one fuzzie (precision brand, rest of gaskets seemed nice) and prevent the window from rolling up all the way as others here have mentioned.
08-14-2013, 07:45 PM | #230 |
Did more door assembly today. Need to figure out the window fuzzies situation, but hey progress is progress! Working my way through the pile of parts.
08-14-2013, 08:27 PM | #231 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very nice work!
I am truly impressed!!!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
08-15-2013, 09:45 AM | #232 |
Thanks! I have to say, it feels good to get some of these parts bolted on that have been sitting here for months, before i even decided to paint the exterior at all.
08-15-2013, 09:58 AM | #233 |
looks like original green glass... that will look great with your color choices.
she looks great... very nice detail. |
08-15-2013, 10:11 AM | #234 |
Thank you. That was the color that was in the truck (i believe because it was factory AC they got that color) and i agree, i think it will go with the color on the truck well. I need to order a windshield and back window and have them installed (i really don't want to do either myself and break a window or chip paint) then that pretty much seals up the cab except for the window fuzzies and door jamb weatherstrip, which i'll try to get on before the end of the week.
08-18-2013, 06:01 PM | #235 |
sill plates and weatherstripping in, what a difference! ad to bring the hinge out on the drivers door slightly, passenger door closed no issue, both are nice and tight.
I didn't glue the weatherstrip on, it grabbed on tight (precision brand) and i put the sill plates in. It hasn't budged. If it does in the future, i'll glue it in some spots to hold it. Inside the cab, the flange didn't reach as far over my panel repairs on the inner BBW panel as i've hoped, so you see some of them peeking out from under the gasket. No biggie as it's not a noticeable area and too late to work on now, but one of those things you'll think of now and again.
08-20-2013, 12:24 PM | #236 |
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
08-20-2013, 02:44 PM | #237 |
chevy only
very nice!! congrats
CHEVY ONLY... Nothin Else ! |
08-20-2013, 03:18 PM | #238 |
Thanks guys! I'm at a standstill for probably the rest of the week since busy, but hope to get back on it this weekend, likely fenders and header panel and hood.
08-24-2013, 01:14 PM | #239 |
Put the new rubber cab mounts in so far today (good thing, because previous owners had replaced parts with and without washers, etc.) I used the OEM bolts in the back since the new were bigger and wanted a nut on top, and the top of the floor already has one welded in.
Also put the stronger u-bolts in the front lower control arms (they were help brand/dorman, grade 8, i think they're $15 a set, which is cheaper than a lot of other places.) Taking a break and then going to start sanding the fenders down and filling the seams on them with seam sealer (i want them as smooth as the header panel crease around the headlights, from the factory they're deeper as it's 2 pieces of sheet metal. Maybe get the grille support panel, fenders, and cowl vent/wiper panel painted this week, and i can put new washer motor mounts, seal, washer kit, etc in and tie up that area (or wait until windshield guy puts windshield in...hrmm)
09-23-2013, 06:40 PM | #240 |
After priming the front sheetmetal, i got caught up working on another car, then had a week off with the family. So, blasted the metal brackets and buckets for the headlights, got some stainless hardware and new springs, adjusters, etc and assembled the grille to feel like i made progress and to use up some parts. Here's the work and a pic of it in its new home until i need it.
Also, got the white/black portion of the header panel and fenders wetsanded so i can get those colors on, then do the green on them and they'll be done. Other than the hood and washer/cowl panel, down to the bed, which i don't plan on touching until everything else is done on the truck.
09-23-2013, 08:34 PM | #241 |
Truck is coming out great!
My frame Layin 63 short bed project http://67-72chevytrucks.com/vboard/s...d.php?t=551353 |
09-23-2013, 09:08 PM | #242 |
Grille is Sweet!
09-23-2013, 09:26 PM | #243 |
Thanks guys!
09-27-2013, 09:46 PM | #244 |
Two of three fender colors on, should do the green maybe sunday.
09-29-2013, 04:39 PM | #245 |
Got the green on today, glad to have these panels done!
09-29-2013, 08:50 PM | #246 |
Beautiful work! Nice to see you sticking with the black and white combo on the fender fronts and grill support.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
09-29-2013, 08:52 PM | #247 |
Thanks! I do think it looks better than just painting it all one color (have to prime, paint, assemble, mark, mask, sand, paint, assemble, mark, mask, sand and paint.) but is a lot more work. I think it has been worth it.
09-29-2013, 09:14 PM | #248 |
Very Nice!!!
10-01-2013, 08:29 PM | #249 |
Fender splash shields assembled and on with the fake flower greening clips. They worked great and easy to work with. Took the wiper motor out to rebuild the washer motor, new mounts, clean off overspray on motor nut, etc.
10-02-2013, 12:52 AM | #250 |
60-66 Nut
Coming along very nicely. I love the attention to detail
