Old 07-07-2015, 04:38 PM   #226
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Today I finished up putting in my mock up drive shaft. I used the front and rear section of the cube vans two drive shafts to make one. Now I can get one made. I used some 6" tube for the frame notch. Also got the E brake peddle in place, once I figured where I wanted it.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 07-10-2015, 04:37 PM   #227
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well after getting my e brakes hooked up with my universal cables that work great. Also hooking up my shifter cable. I decided to see if my electronically controlled trans had any gears with no computer. So I put it in gear and pulled it out of the shop slowly (no real brakes). Then put some blocks on front of the wheels and did a burn out I'll get a vid this weekend.
Today I picked up all my steering components and shocks.
1951 MG TD
Old 07-10-2015, 08:38 PM   #228
FarmerSid
FarmerSid's Avatar
Re: My 52 GMC Build
What kinda burn out's that? LOL! More black than white smoke?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 07-10-2015, 09:23 PM   #229
lower50's
lower50's's Avatar
Re: My 52 GMC Build
It's hard with a locked dually with no brakes and no shocks lol
Action shot!!
1951 MG TD
Old 07-10-2015, 09:29 PM   #230
FarmerSid
FarmerSid's Avatar
Re: My 52 GMC Build
Ya sure you got all the ford crap off? That IH motor should light er up! Just rubb'in ya!
C4 IFS & D44 IRS
5.3 HO L33
Old 07-10-2015, 09:32 PM   #231
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Ya np. I was happy it moved. I can't wait to lay some lines all the way down the street. Oh and I found out after it was in 3rd gear
1951 MG TD
Old 07-10-2015, 09:37 PM   #232
FarmerSid
FarmerSid's Avatar
Re: My 52 GMC Build
Lol!
C4 IFS & D44 IRS
5.3 HO L33
Old 07-13-2015, 01:18 PM   #233
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well I got the gas tank filler neck welded in the fuel tank. Then pressure tested to 10 psi all good. Holes drilled and I'm ready to put the tank in. Just working on mounting my filters and pump then bolt tank in. Also got the brake peddle mounted.
1951 MG TD
Old 07-13-2015, 03:29 PM   #234
99 to Life
99 to Life's Avatar
Re: My 52 GMC Build
nice job, always nice having all the pedals hooked up. that stuff takes longer than people think.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-13-2015, 04:02 PM   #235
Advanced Design
Advanced Design's Avatar
Re: My 52 GMC Build
Tank is nice! Not many of us can make our own...well done.
Advanced Design is offline   Reply With Quote
Old 07-14-2015, 01:59 PM   #236
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks 99!! Your right. 2 out of 3 ain't bad so far.
Thanks AD
1951 MG TD
Old 07-16-2015, 07:38 AM   #237
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Made up some stainless brackets to hold my fuel filters, water separator and electric pump. Also got tank mounted, all looks good back there. Then got my new front tires mounted. They are sexy.
1951 MG TD
Old 07-16-2015, 10:06 AM   #238
iowaboynca
iowaboynca's Avatar
Re: My 52 GMC Build
Looking good! quick question about the pedals. They come out of the donor S10?
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 07-16-2015, 12:40 PM   #239
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks. Gas peddle came out of the donor ford cube van. The 2 brake peddles and steering column came out of a mid '80's gm motor home (van front end).
1951 MG TD
Old 07-16-2015, 06:16 PM   #240
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: My 52 GMC Build
Nice work! Nice rubba marks too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-20-2015, 11:14 PM   #241
lower50's
lower50's's Avatar
Re: My 52 GMC Build
So Friday I picked up trans cooler. Today I figured out where under the bed it's going. Not ideal but I have no more room up front and limited out back, but it will work just fine. The box says recommended for transmission, fuel, power steering. Fuel? Does any one know why you would need a cooler like this for fuel? Also got my new mirrors installed. I went with the 5x7 mirror because I will be towing with the truck and want to see.
1951 MG TD
Old 07-21-2015, 03:16 PM   #242
Dieselwrencher
Re: My 52 GMC Build
With big high out put mechanical fuel pumps, the fuel temps can get crazy hot in a competition truck. I've seen guys that hot lap a lot install fuel coolers to help the fuel system live longer. It's cheap insurance for them when they have $5k or more in their fuel system.
Ryan
Old 07-21-2015, 11:12 PM   #243
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Oh cool. That makes sense. Thanks
1951 MG TD
Old 07-23-2015, 12:06 AM   #244
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Here is a vid of a small burn out I did before I mounted the fuel pump in the back. Afterwards I realized that I was in 3rd gear. I hope link works.
http://vid51.photobucket.com/albums/...psgy8ojgqr.mp4
1951 MG TD
Old 07-23-2015, 12:10 AM   #245
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Love this sound
http://vid51.photobucket.com/albums/...pshly2puws.mp4
1951 MG TD
Old 08-05-2015, 07:55 AM   #246
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Well after a bunch of other fun commitments and off roading holidays. I got back in the garage last night. Made the drive shaft hoop for the front of the shaft. Nothing fancy but good and strong. Then started covering in the transmission hump.
1951 MG TD
Old 08-05-2015, 02:09 PM   #247
ptc
ptc's Avatar
Re: My 52 GMC Build
Thats some serious iron work!!!
What is the GVWR going to be on this rig when its done????? You may have to get a permit to drive that thing on a highway!!! lol
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 08-05-2015, 02:12 PM   #248
lower50's
lower50's's Avatar
Re: My 52 GMC Build
Thanks. That tubing in the cab is 1x1 tube. I figure the truck will weigh around 5000lb. We will see.
1951 MG TD
Old 08-07-2015, 08:37 AM   #249
lower50's
lower50's's Avatar
Re: My 52 GMC Build
I got some more of the transmission tunnel done. I'm using 20ga sheet metal. Air hand sheers and the corner of my workbench.
1951 MG TD
Old 08-11-2015, 10:18 PM   #250
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Re: My 52 GMC Build
lower50's, Hi neighbour!
I'm usually on the 60-66 forum, but I noticed you're in Kitchener so I wanted to check out what you're working on.
I'm super impressed with your truck! It seems really well thought out... with the diesel and everything. And lots of fab work! I'm tuned in to see what's next...
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
bagged, build, diesel, gmc, hot rod
