Old 03-06-2016, 09:24 PM   #226
Possmguts
Possmguts's Avatar
Re: Blood Sweat and Tears.. 67 Build Thread
Originally Posted by swamp rat View Post
Or just make it where they don't drop as far, still would have the same effect.
As it is with that radiator... if I did that, they would only be about and inch deep... This radiator was just something the PO tossed in at some point and it didn't fit right anyway. Was too tall and not wide enough. I'm gonna look for a shorter radiator and then if I have to ill do something with the mounts. No need to do all that other stuff I said about the scoops... they will stay like they are and just get the opening cut into them.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 03-10-2016, 04:24 PM   #227
roushinator
roushinator's Avatar
Nice work. I was thinking about doing something like that to my hood.
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-11-2016, 10:30 AM   #228
Possmguts
Possmguts's Avatar
Thanks.. Gonna try to finish up this weekend... just got back in town at 2:30 this morning.
I've already started the finish work on it... I'm just going to finish up and move on. I'm sure I will find something that works with it...
Old 03-11-2016, 12:56 PM   #229
Possmguts
Possmguts's Avatar
On another note... I came home to find a nice shiny new set of stainless headers waiting on me
Old 03-12-2016, 02:14 PM   #230
Possmguts
Possmguts's Avatar
More pics of the good times... undoing work done the wrong way to redo it the right way... Probably should have done this part of the hood first before I started on the scoops...
Old 03-12-2016, 05:07 PM   #231
Metaldoc
Metaldoc's Avatar
That's a tough fix but it could be modified at this point. Just saying
Metaldoc is offline   Reply With Quote
Old 03-12-2016, 05:17 PM   #232
Metaldoc
Metaldoc's Avatar
Welp.. the more I thought about it I started to wondered if the radiator was even gonna fit now... I doesn't... I need to find a radiator that's no more than 17" tall to the top of the cap... it can be several inches wider than this one too...
This is the radiator that was in the truck when I got it... I know it was just tossed in there and half ass mounted, so I'm gonna be looking to see if I can find a shorter one that might give me the room I need to use this hood.. Since the scoops are so close to the support but I still have some room over top of the support, I'm thinking about connecting the front hood frame to the scoops (But not changing the over all appearance you see from out side) and creating an opening in front of the support to pull air from the grill area... This might still work after all....
Have the filler tube taken off the top and put a 90 out from the tank. Then sink the rad into the rad saddle. I've done this on an s10 v8 convertion
Old 03-13-2016, 02:32 PM   #233
Possmguts
Possmguts's Avatar
yeah, we'll end up doing something like that, but to a better fitting radiator than this one.. it wasnt right to start with.
Old 03-13-2016, 02:34 PM   #234
Possmguts
Possmguts's Avatar
More progress on the scoops... pretty close buts needs a little more work. Now that I shot a coat of primer on it I can see what needs done better.... and of coarse the holes still need cut. I'm having a hard time deciding what style I should go with...
Old 03-13-2016, 03:19 PM   #235
Advanced Design
Advanced Design's Avatar
Looks really cool!
Advanced Design is offline   Reply With Quote
Old 03-13-2016, 05:32 PM   #236
flashed
Looks great .I like it .
flashed is offline   Reply With Quote
Old 03-13-2016, 07:09 PM   #237
Possmguts
Possmguts's Avatar
Holes are cut... I'll clean them up and tack some screening behind all the way around the holes to help with strength.. but there is no flexing issue as I left some metal over and under the holes to start with.
Old 03-13-2016, 07:56 PM   #238
jlsanborn
jlsanborn's Avatar
You're making lemonade there man. My first thoughts were... then I saw the rot... now I'm seeing a pretty cool, custom hood. Well done!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 03-13-2016, 11:21 PM   #239
swamp rat
swamp rat's Avatar
When you said help on adding radius's i thought you just meant radiusing the corners but the way you built that ridge around the opening looks pretty nice.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-14-2016, 06:02 PM   #240
lower50's
lower50's's Avatar
I really like how your scoops turned out
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 03-14-2016, 07:26 PM   #241
mooseknuckles
mooseknuckles's Avatar
nailed it!
mooseknuckles is offline   Reply With Quote
Old 03-14-2016, 10:54 PM   #242
Possmguts
Possmguts's Avatar
Thanks.. what I ended up doing was using 3/8 round stock that i WAS going to weld on the underside and just radius the sides down, but got to thinking that would still be to dull and not finished looking... so on top it went and befor I kew it this is what was emerging.. I thinks its much more gooder
Thank you... wasnt as easy as I thought it was gonna be for sure.. 3 weekends I think so far and still not done. Plus I still have to patch up the leading edge of the hood to boot...
well it wasn't lemoaid that put this insanity in my head lol Thanks
Originally Posted by mooseknuckles View Post
nailed it!
Old 03-16-2016, 02:37 PM   #243
RRR18
RRR18's Avatar
Damn I was a page or so behind on this. Good for you havin the sack to do something that was in your head and make it come out as good as it is. Looks good.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 03-20-2016, 09:28 PM   #244
Possmguts
Possmguts's Avatar
Thank you sir... everything your body guy made look so easy takes me at least twice as long to do. I would be further along if I was home more than just 2 days a week too though... I just chip away at it until I have something worthy of a paint job. I haven't even touched the bed yet... its in pretty good shape but still needs a lot of work. Front and floor needs replaced (I think I'm gonna do something a little different with the floor) and the sides need some love to save.
I wish you would hurry up and bail yours out of paint jail, cant wait to see it!
Old 03-25-2016, 10:09 PM   #245
Possmguts
Possmguts's Avatar
Home again this weekend and the only new part waiting on me was a front shock lol... I screwed up on the last parts order and only ordered one so I had to put in an order for the other shock.
Gearing up for another big money order in the next week or two, but until then for the next couple weekends Ill be just be finishing up on the hood and maybe Ill stick the bed on so I can figure out where to mount the gas tank and where the fuel fill is gonna go and so on and so on...
Old 03-26-2016, 05:50 PM   #246
Possmguts
Possmguts's Avatar
I think I figured out what I'm going to do with that awkward notch I was left with when I mounted the visor lower than its supposed to be. Gonna channel a couple lights into them... A couple pieces of 1 1/4" OD pipe and a couple 1" LED lights will work just fine..
Old 03-28-2016, 09:21 AM   #247
aod92
aod92's Avatar
Hood looks killer. Can't wait to see it finished!
aod92 is offline   Reply With Quote
Old 03-30-2016, 09:00 PM   #248
Possmguts
Possmguts's Avatar
Didn't do much last weekend other than some sanding. I gotta get to the sheet metal shop to get a piece bent up for the front edge of the hood repairs, so i kicked her outside and did a "little" garage cleaning... meaning that i grabbed the blower and blew out a ton of dust
Old 03-30-2016, 09:55 PM   #249
swamp rat
swamp rat's Avatar
The blower is my favorite way to clean the garage LOL!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-30-2016, 11:25 PM   #250
lower50's
lower50's's Avatar
Yes best shop cleaning tool. Also the smell of 2 stroke.
1951 MG TD
