![]() Join Date: Oct 2012
Re: Project "Buffalo Blizzard Surprise" 71 SWB build
Looks amazing! Congrats.
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
![]() Join Date: Aug 2004
It looks good!
Man, that's a great color!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Thanks. I have some more pictures of it out in the sun and it looks different.
So after 11-months my friend and I traveled from Buffalo, New York to Roger Burman's shop (Lakeside Rods & Rides) in Rockwell City, Iowa to pick up the truck. All the final body and paint work has been completed by Roger and his crew. At this point I still had all the wiring, fuel lines, brake lines and interior work to be completed yet. Since I have to finish all the wiring, the truck still has not yet been running. This was the first time I got to see it in person. Wow! I was blown away!
The truck was loaded into my friends trailer and we were ready to make the 1,000 mile trip back. What a road trip.
![]() Join Date: Mar 2011
stunning ....congratulations ....safe travel
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
Here is the truck back home into my shop. At this point I still have a lot of work to do on it. All the wiring still needs to be finished as does fuel lines, brake lines and interior.
Wow! Your truck is gorgeous!
If patience is truely a virtue, Then I am so screwed 1970 Chevy SWB Gasser 364"LS and all the goodies 2001 Vette Road/Street 1990 IROCZ Vert |
Thanks for the kind words. It has been a long haul with this project. Over 12-years now!!! There is finally light at the end of the tunnel. There were times that I thought about giving up and selling the project, but my wife convinced me to push on. Glad that I kept it going.
Time to get working on the electrical. Way back when... I bought the American Auto Wire Highway 22 kit. I welded up a mounting plate for the fuse box up underneath on the driver side. Before welding it up, I drilled and tapped holes for mounting it. All that electrical needs to be run from front to rear.
There are a lot of electrical components that need to be installed and hidden. I'm using the Holley Terminator X Max system for my computer. That is mounted up front on the transmission tunnel, and should be hidden by my future console. I also have to install my Dakota Digital modules. I have modules for the HDX gauge cluster, a BIM module interface for the Holley Terminator, a GSS-3000 gear indicator, DCC-4000 HDX style climate control and a module for my keyless ignition. I also need to leave room for stereo components, as I want a strong sounding system. I also plan to install an E-Stopp electrical emergency braking system along with American Autowire push-button remote disconnect. Sounds like 10-pounds of $@!t in a 5-pound bag!!!
More wiring in process. The electric window controls are hidden just below the dash on both driver and passenger sides. This is a real mess of wires.
#13 |
I used the same American Autowire 22 circuit kit with my Holley TermX and Pro Dash setup. Has worked very well over the last 3yrs of cruising/racing. I'm converting to a faceplated t-56 magnum/E-Stop brake system currently, so it's nice to see someone using the same products.
#14 | |
What do you currently have for transmission setup? You must do some serious racing?
#15 | |
I'm going from a Jakes Performance Stage 3+ 4L80E to a faceplated magnum T56 from rpm. This will allow me to run more classes if the event won't let me in the Gasser class.
#16 | |
#17 |
More wiring work from the front end. Put the truck up on the lift to save my back. I bought headlights from Dapper Lighting. I used them for my 70 K10 and was extremely happy. This go around I'm using 7" LED Seven Halo headlights with HDR Switchback feature. Since I no longer have turn signals in the bumper, I had to come up with some something. These Halo's have a white halo ring that will switch to amber when the turn signal is used.
Here is my final connection for the headlights Like I said, I put the truck up on the lift to make it easier to work at the front You can see that I have the one 7" Dapper LED installed, while I'm still working on the other. While it's up here I will also install my fan relay kit from CE Auto Electric Supply. The relay kit will integrate with my Holley Terminator X Max ECU. The set up allows me to run both fans at half speed when the temp reaches about 165 deg. Once it gets to about 185 deg, both fans will run at full speed. I also have a trinary switch interface that allows a single fan to run in High Speed when the A/C is turned on and the engine coolant temperature is below the Low Speed set point in the ECU.
#18 |
How much of the headlight bucket had to be modified for those lights? I tried 2 different hid and halo light kits, and ended up going back to stock or id have nothing left of the buckets.
#19 |
Minimal modification. I only rounded out the hole a little bit so it would fit snug. They have very nice lights.
#20 |
Working on getting the horns installed. Got a good deal on these. Lol. Don't worry about it... It's just a horn.
#21 |
Engine bay looks good, but needs something.
Going to try some Holley 2-piece coil valve covers.
#22 |
Removed my D514A coils.
Removed the stock valve covers. Installed the 1st piece of the Holley valve cover Found out that the D514A coils wouldn't work with the Holley valve covers. I had to buy new D510C coils, so they would fit. Holley's bolts didn't fit either. They were too short. New D510 coils installed.
#23 |
Here is the finished install of Holley's red 2-piece valve covers. I like the touch of red with the blue engine bay. My buddy would have liked black, but we all have our own tastes. That's what keeps this hobby so much fun and interesting. Now it's back to finishing up the front end wiring.
#24 |
Working on the brake lines. I needed a bulkhead fitting to mount my passenger side brake line. Instead of buying one, I decided to make one out of aluminum. It turned out pretty good.
#25 |
Trying to get the fuel lines and tank finished up. Tank is ready to go back in. It was originally set up for bed fill, but I converted it over to side fill, so it could be used with the bedside fill.
Here is where the fuel fill is on the DS bedside.
| Bookmarks |
