Old 11-17-2015, 10:09 AM   #226
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Re: 1977 Silverado Crew Cab.
Wow that is a great shine!!! Looking great!
bowtieguy79 is offline   Reply With Quote
Old 11-17-2015, 10:12 AM   #227
OutlawDrifter
fantastic job! it's turning out very well!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 11-17-2015, 11:12 AM   #228
MTCK
MTCK's Avatar
Www.73-87chevytrucks.com is the web site.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-17-2015, 04:47 PM   #229
y5mgisi
Second Chance Program
y5mgisi's Avatar
Ordered all my stuff up! Hope to get it all installed over Thanksgiving weekend.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-17-2015, 05:09 PM   #230
Front Range
Front Range's Avatar
How many gallons of red did you end up using?
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 11-18-2015, 08:23 AM   #231
y5mgisi
y5mgisi's Avatar
Just one. In fact I still have to paint the tailgate and I have enough red left over from doing the truck to still paint the tailgate and the dash.
Old 11-18-2015, 10:13 AM   #232
77K10Silverado
77K10Silverado's Avatar
What all did you order?
Care to come paint my truck? lol
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 11-18-2015, 12:48 PM   #233
y5mgisi
y5mgisi's Avatar
Door seals, channel felts, window seals, auxiliary seals, I think that's it?
Old 11-18-2015, 01:04 PM   #234
y5mgisi
y5mgisi's Avatar
I wish I could come to paint yiur truck! More over, I want you to do it yourself! Mine turned out pretty nice for a first time paint job. I'm sure you could do the same!
Old 11-19-2015, 08:14 AM   #235
y5mgisi
y5mgisi's Avatar
Taillights in means one step closer to having it back on the road! The little things are still exciting!
Old 11-27-2015, 11:19 PM   #236
440marv
Great first paint job. What brand paint and clear did you use?
440marv is offline   Reply With Quote
Old 12-06-2015, 11:27 PM   #237
y5mgisi
y5mgisi's Avatar
Thanks! I used Wanda for the base coat and southern polyurethane for everything else including the clear. Great products!
With any luck I'm going to be picking up this truck in a couple days pilfering the Dana 60 front end and the th400/205 combo and selling the rest to a friend.
Old 12-06-2015, 11:37 PM   #238
MTCK
MTCK's Avatar
Looms like a good deal! Do it!
-Marcus
Project Plow Truck
Old 12-07-2015, 06:44 AM   #239
y5mgisi
y5mgisi's Avatar
Working on it! At this point the only thing holding me back is my financier. All my money is tied up in my kitchen remodel. So my buddy who will be taking the body and frame from me is loaning me the dough!
Old 12-08-2015, 01:20 PM   #240
justcuz
justcuz's Avatar
You going to keep the 205 or convert the newer t-case to the 400?
Although the 205 is beefy, I would personally prefer the gear reduction of the newer case, especially since the first gear in the 400 is not as low as a 700R4/4l60E.
Also spring mounts for your chassis and cross members, aftermarket or wrecking yard sourced?
I'd be tempted to run B52's up front with factory shackle mounts and factory 4wd front mounts and a flip kit in the rear. Maybe even sneak some 1 ton 64" late model springs out back.
Paint job looks great buy the way!
justcuz is offline   Reply With Quote
Old 12-09-2015, 08:42 AM   #241
y5mgisi
y5mgisi's Avatar
This will be mine on Saturday!
I'm going to sell the th400/205 combo and run a th400/241. The 241s are plenty strong for me and just seem to run smoother down the highway in my experience. And the extra low range compared to the 205 certainly won't hurt! For 4x4 mounts, I'm going to fab my own stuff I think. Although I will buy the rear shackle hangers for the front Springs from diy4x4. For the rear, for now, just going to do a block. If my calculations are correct, a standard run of the mill 4" block in the rear will get me level. I'll just be using stock front Springs.
Old 12-09-2015, 01:22 PM   #242
justcuz
justcuz's Avatar
If you use the 3 leaf 1 ton front springs you may get by with a shorter block.
Ford has a selection of blocks in their F250/350 trucks that are possibilities and also capture the inner part of the u bolts. Depending on the GVW the Ford blocks I've seen range from 2,3 or 4 inches.
I'd have to go measure but I don't think Chevy 4x4 spring mounts are 4" taller than 2wd, or did you already measure the Suburban rear spring mounts compared to your crew cab (2wd) rear spring mounts?
I like the fact that except for the front axle, your drive lines on both vehicle will be the same.
Old 12-09-2015, 08:43 PM   #243
justcuz
justcuz's Avatar
Have you installed any of the seals yet? How do you like them and who did you get them from?
Old 12-09-2015, 09:50 PM   #244
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
94-02 2500 and 3500 4x4 Dodges have a 4" cast block in the rear of them as well. The only problem you might run into might be the ford and dodge springs are wider than the older chevy ones. I almost went with a 241 for my 76. I still might if I can find a core at a decent price.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-09-2015, 10:42 PM   #245
68Timber
I know the pieces fit
68Timber's Avatar
I like the 241 idea. The TH400, adapter, and 205 can be flipped for good coin and the 241 is more than adequate for normal use.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-18-2015, 07:32 AM   #246
NastyBuzzard
NastyBuzzard's Avatar
Following closely! You are doing to yours what I want to do to my 88 GMC crew! I also have a donor 1 ton w/ the dana 60 I need to swap over.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 12-18-2015, 11:07 AM   #247
y5mgisi
y5mgisi's Avatar
The 2wd mounts are 3" shorter than 4x4. So I plan on using the 3 leaf front Springs and just doing whatever block makes the rear level.
I have them all installed. Near as I can tell it doesn't matter where you buy them from. I think I have bought seals from three different places over time and all of them look identical. So who knows. The seals are all pretty good. Can't expect perfection and they aren't perfect. The things of note that come to mind are on the window track seals you have to trim the lip that holds them in place everywhere where the door skin is attached or there will be bunched up tight points every few inches. Also with new door seals, I have yet to have them not suck as far as having to really slam the doors to get them to shut.
I have just had better luck with highway operation of 241s than 205s. Those are the only two transfer cases I like. And if it's a truck like this that will spend 95% of its time in 2wd on the highway, it's the right choice in my eyes.
Exactly. I have put my 241 in the burb through a good deal of hell over the years. If it can put up with what I have done, I have nothing to worry about.
Yep! I'm following yours too! Sadly the 60 swap won't start for a good couple months as I am remodeling my kitchen starting right after Christmas... Yippie!
Old 12-18-2015, 11:27 AM   #248
NastyBuzzard
Well then! Mine will be starting not in the far distant future I just have a lot going on right now with a couple of fbody's. I want to have the front end stripped from the 4x4 before the end of the year and the 350 tbi in the 88 needs a head gasket. Still trying to decide where I plan to get my 4x4 swap parts from.
Old 12-19-2015, 09:10 AM   #249
y5mgisi
y5mgisi's Avatar
I would get the spring mounts from diy4x4 and the cross member from either totally naked auto or off-road design. However , I'm thinking I'll make my own front mounts and buy the shackle mounts from diy4x4 and the crossmemeber probably from TNA.
Old 12-19-2015, 09:43 AM   #250
jott_06
Camaro Club
jott_06's Avatar
I'm not sure what those crossmembers or spring mounts cost but I was able to use all factory parts on my swap. The factory 4x4 engine crossmember only took a little bit of tweeking to fit in the 2wd frame. The frames are very similar but not exactly the same. I found that the 2wd frame was around 3/8 of an inch shorter in height at the engine crossmember area.
jott_06 is offline   Reply With Quote
