01-16-2017, 06:33 PM | #226 |
Re: 68 C50 Looongbed pickup build
Ouch, thats Highway robbery
01-17-2017, 01:15 PM | #227 |
Finally!!!!!!!!!!!!! Been waitin, what about the schoolbus or the 89 radiator?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
01-17-2017, 01:42 PM | #228 |
Patience ,Grasshopper .LOL
01-17-2017, 03:48 PM | #229 |
I cant help it i love trucks lol And i was on lunch and i am hyper today. you know why john.
01-17-2017, 04:51 PM | #230 |
Yes I know .
01-17-2017, 10:36 PM | #231 | |
I have to get a couple more quotes. I know that if I tell them to build it within a week I'll find a used one for cheap... Just the way it goes.
Patience indeed. Our young grasshopper has not graced us with any pictures of his lifted 69. Just sayin... -Richard
I may have too many Chevys... Is that possible? 68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713 |
01-19-2017, 10:43 AM | #232 | |
01-19-2017, 10:47 AM | #233 |
THERE YA GO A CONCEPT PHOTO!!!!!!!!!! but seriously i love the look of this truck.
01-19-2017, 08:06 PM | #234 |
good progress on the truck, and that lifted stepside looks sweet. my blue knight is still getting gutted, all I have left on the wiring is whats running to the tail lights and reverse lights. work is slow when you're truck ain't covered and monies not plentiful. Now if only I could find the intake bolt that I dropped. I didn't think that an orange bolt would blend in so well with grass and gravel.
01-19-2017, 10:01 PM | #235 |
Rnk just for you today i took a picture of franken truck. Its sad i think i need a grill asap. And an oem steerin coloum. But i wanna drive ittttttt. But ive came up eith an awesome fuel filler idea.
01-20-2017, 11:16 PM | #236 | |||
I feel your pain on the missing bolt, check out the last picture in post 66 of this build. That roll of tape fell and landed there! Quote:
Come on deer hunter, you're killing me! -Richard
01-22-2017, 07:53 PM | #237 |
I don't have an actual build thread. I thought about it but couldn't justify having one what with the cold rainy days and no dry place to work on it quicker. But here is how she sits now minus the grille or front bumper
01-23-2017, 10:11 AM | #238 |
There ya go!!!!!!!!!!
01-23-2017, 10:13 AM | #239 |
Ahhhhhhhhhh i remember this day, the day i brought the ole girl home. and dude if ya ever near me i have a front axle so ya can make yout 67 a 4x4
01-23-2017, 11:33 PM | #240 | ||
-Richard
01-24-2017, 10:37 PM | #241 |
Update from last weekend:
I really wanted to bolt the front sheet metal back on and rig the too big radiator in and drive it. However... I still needed to deal with the park brake first. And even bigger deal, if the weather would permit I needed to work on my fencing project between my neighbor and myself. Well, the weather was good Saturday so I worked on the fence most of the day. Around 4:30 a squall blew in and ran me off of that. So I stopped for the day, washed off the poison ivy and had supper after that I attacked the park brake. The 68 had the park brake bolted directly to the transmission, sticking up to the right of the shifter. The 89 was under the dash next to the driver side kick panel and was cable operated. My original plan was to adapt the trans mounted brake lever but when I compared the throw the 68 moved the linkage less than an inch where the 89 was about an inch and a half. Rather than re-engineer the whole mess I decided to just reuse the whole 89 brake lever and mount it in the 68. The lever used three bolts, one aimed forward through the firewall and two bolted to the floorboard on the wheel hump. The height of the mount points meant that I needed to make it taller or have it too close to the floor. The two bolts that hold it to the floor were welded to the bracket so I not-so-delicately removed them, you can see in these pictures with one stuck back through the hole and the second with them gone. I figured out the height, drilled a hole in the firewall and screwed the assembly to the firewall. To hold it level I stuck a bolt through one of the holes while I measured for the new ears. Finally I cut off the old ears and added my home made pieces. The welds weren't perfect but are getting better. One last picture of the assembly installed. more to come... -Richard
01-24-2017, 10:58 PM | #242 |
...more on the park brake:
What I did not get pictures of was that I pulled the park brake assembly back out and painted it, I also sanded the part of the floor that it will cover and hit it with Rustoleum rust reformer paint. I was a bit stumped as to how the brake cable was supposed to be routed but eventually found a picture that hadn't made the cut to be posted at the time. But you get to see it now . As you can see the cable came out of the firewall, looped behind the body mount, over the trans and then down to connect at the back of the trans on the passenger side. (thank goodness for reference photos!) Since I wasn't able to locate that picture until Monday I didn't finish hooking it up over the weekend. Once it is connected there is literally nothing left that has to be done before the sheet metal goes back on. So pending fence work I may make it look like a truck again next weekend. Also, I have requested a quote from another radiator shop, so we'll see what they say. Oh, and last; that danged circuit breaker finally made it in from China! That's all for now folks, hopefully I'll have more to show next week! -Richard
01-24-2017, 11:04 PM | #243 |
Good to see someone's making progress on their truck! I ain't touched mine in months. She still needs new 3/8" fuel line, the tank dropped and cleaned, removing the frame in-line filter, and all new rubber hose.
01-25-2017, 10:38 AM | #244 |
Finnaly!!! and yeah money is whats keepin mine from runnin.
01-25-2017, 08:12 PM | #245 |
Richard, that is a good idea on the parking brake. Circuit breaker took its time....oh, my box cutter hasn't turned up yet either.
Appreciate the updates....were you putting up wire fence? |
01-25-2017, 09:57 PM | #246 | |||
The wire fence is down on the property where the truck resides. I'm on my iPad right now, next time I get on the PC I'll try to get a screen capture from google maps to show you what I have going. I haven't checked out your burb in a Few days. I think I'll head over there now. -Richard
01-25-2017, 10:08 PM | #247 | |
-Richard
01-26-2017, 11:41 AM | #248 |
Well in that case, maybe I'll take a day to remove the fenders and Gunk the whole motor. Hah.
01-26-2017, 12:59 PM | #249 | |
01-26-2017, 09:28 PM | #250 |
Good luck on the job Noah, and gunk is always nice when you have a hose or pressure washer to get it off with.
Tags |
22.5 wheels, c50, disk brake conversions, hydroboost, pickup |
