05-17-2020, 10:01 PM | #226 |
Re: Son's 68 c10 Short Bed
Thank you. It will hopefully start coming together quick. The boy is getting excited for sure.
Former Build (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=724379 (SOLD) Current Built (68 c10 swb): http://67-72chevytrucks.com/vboard/s...d.php?t=787712 |
05-19-2020, 12:19 PM | #227 |
I ordered a "smoothie" bumper for the rear of the truck a couple months ago. It finally came in the other day and looks real nice. This is the match to the front bumper I had previously purchased a few years ago.
05-19-2020, 03:45 PM | #228 |
Can you get/post a pic of the inside (back-side)?
05-19-2020, 04:00 PM | #229 |
I have it boxed up and put away for now. I have used these in the past though and there is a tab welded on the inside of the bumper that your bolt slips into. The shoulder of the bolt holds it in place and it is then bolted to the factory brackets. Basically it is exactly the same as an original bumper but instead of the bolts shouldering through the bumper they rest on the tab.
Hope that makes sense - I will see about getting a picture this evening.
05-19-2020, 04:43 PM | #230 | |
In retrospect, I should have just welded regular hardware to the plates on the inside vs the bumper face & the plate. The plates helped spread any impact load (which worked). But, since the bolt was still welded in the OE holes as well, they puckered when it was involved in a fender-bender. You know what they say about hind-sight....
05-19-2020, 06:46 PM | #231 | |
05-19-2020, 07:44 PM | #232 |
Here are the pics...
05-19-2020, 08:09 PM | #233 |
Awesome & appreciated! What's your opinion of the bumper quality?
I know when I did my 74 & was looking for new bumpers the aftermarket stuff was crap (you could easily twist the bumper end-to-end). It took a while but I found OE units. I had OE units on my '89 dually until it got tagged in a p-lot. I was having a hard time finding another rear so I tried one of the LMC Premium units (along w/one of their Blazer gate panels). The aftermarket unit for that was as nice as my original OE unit. Weighed about the same & zero twist/flex end-to-end.
05-19-2020, 10:17 PM | #234 | |
05-23-2020, 09:15 PM | #235 |
Yesterday, we got the inside of the bed done. Came out pretty slick. Today, we finish sanded the bed sides and they will get sprayed on Tuesday.
05-25-2020, 12:21 AM | #236 |
Looks as good as a brand new one piece floor. Do you still think you would have been money ahead if you bought a new floor?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
05-25-2020, 09:28 AM | #237 |
Thank you. I definitely would have been better off just buying a whole floor. This floor was all new, just came in two sections. Honestly though, the floor has been all done by my son. He cut it out, welded it back together, ground it down, filled it, and did 3-4 rounds of sanding it. It came out nice and it really is the one part that has been all him. That in and of itself, is probably worth it.
05-25-2020, 09:43 AM | #238 |
I totally forgot about that aspect... excellent point and so true.
05-25-2020, 10:33 AM | #239 | |
No doubt he will treasure this truck for many many years to come, due to lessons learned, but even more importantly........time spent with Dad That truck is truly something to be proud of on many fronts, for both you and your son
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
05-25-2020, 10:59 AM | #240 | |
One of the biggest parts of this, for me, is him understanding and grasping his "Papa's" legacy.
05-25-2020, 12:45 PM | #241 | |
05-25-2020, 03:12 PM | #242 |
Yes sir, we're both blessed for sure.
05-26-2020, 10:06 AM | #243 |
That is a slick bed floor, your son did a great job on it.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632 1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047 1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184 1978 Chevy Scottsdale K20 1993 Chevy C1500 - 5.3/T56 swapped 2008 Silverado Duramax |
05-26-2020, 11:09 AM | #244 |
Almost Satisfied
Wow! From the old bed liner to this. A lot of work that he can be proud of for sure.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-26-2020, 12:40 PM | #245 |
Thank you both. They are painting the outside of the bed today while I'm stuck at work. Hoping I will get some pics at some point.
05-26-2020, 11:04 PM | #246 |
I’ll get some better pictures when I can. From what I’m told, it came out great and is really straight. Pretty happy about that, because it was pretty rough.
05-26-2020, 11:41 PM | #247 |
Looks good from here. 🤓👌
05-27-2020, 11:42 AM | #248 |
I just ran down to the shop and snapped a few pics. It still needs to be color sanded but looks pretty good.
05-27-2020, 11:43 AM | #249 |
Continued:
05-27-2020, 11:52 AM | #250 |
One more:
