08-08-2020, 04:57 PM | #226 |
Re: '72 Cheyenne K10
Looking good.
08-08-2020, 07:57 PM | #227 |
The ducts are in the dash like spaghetti.
08-09-2020, 06:16 AM | #228 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-09-2020, 04:43 PM | #229 |
FedEx said my compressor and controls were delivering yesterday but they didn't show. So today I played with wiring for the new gauges. Temp and volt gauges will be custom fit into the cluster, and the tachometer will hose clamp onto the steering column.
08-09-2020, 07:32 PM | #230 |
Jimbo, you will love your VA unit. Had mine charged Friday and took it out today to the Placerville wine country, high 90's to 100 and blew ice cold. Took no time at all to start blowing cold after starting up in a hot cab. The original AC in my truck never worked, so I can't compare to stock, but I really don't think it would be better than this.
08-09-2020, 07:35 PM | #231 | |
Question - does it use a regular factory AC belt? |
08-09-2020, 08:00 PM | #232 |
Here's the belt I used, Gates, pretty sure 58" I think which is what VA recommended, stock pulleys. Not sure what you mean about fans, I have a stock setup.
08-10-2020, 01:38 PM | #233 |
Custom voltmeter and temperature gauges are in the instrument cluster. They look good in the daytime, but I wonder how they will look at night with the lights on.
08-10-2020, 01:49 PM | #234 |
They look good. Don't forget to take a night pic for us.
08-11-2020, 04:41 PM | #235 |
Today's progress (so far):
08-11-2020, 10:58 PM | #236 |
How does an old work truck not have any tie-down anchors? I fixed that.
08-12-2020, 12:49 AM | #237 |
Here's that night dash photo. The tach ground is not hooked up yet, and I have to figure out why a few of the LED bulbs aren't working.
08-12-2020, 10:41 AM | #238 | |
08-12-2020, 11:00 AM | #239 |
It’s all looking good, great job.
08-12-2020, 12:02 PM | #240 |
Compressor install was easy. I really appreciate the previous owner using anti-seize on the exhaust bolts. Now I am on the hunt for a shop with the crimping tools to make the AC hoses.
Can anyone tell me if the main power for the Vintage Air is safe to hook up to the battery side of the American Autowire Megafuse? |
08-12-2020, 01:15 PM | #241 |
[QUOTE=jimbosprint;8790806]Compressor install was easy. I really appreciate the previous owner using anti-seize on the exhaust bolts. Now I am on the hunt for a shop with the crimping tools to make the AC hoses.
Can anyone tell me if the main power for the Vintage Air is safe to hook up to the battery side of the American Autowire Megafuse? Looks really good Jimbo, you are flying along compared to how long it took me. And, yes, you can wire directly into the megafuse terminal coming from the starter. I called AAW about exactly the same thing. They also said most people doing the VA install wire the negative lead to where the negative battery cable attaches to your engine. That's what I did too, looks cleaner. Last edited by NorCalC20LWB; 08-12-2020 at 01:16 PM. Reason: Add picture |
08-12-2020, 06:56 PM | #242 |
I got the AC hoses made and installed. I need a heater hose fitting for the top of the water pump and the heater hoses will be done.
As I suspected, there was no working thermostat. The spring was broken and it was stuck open. I replaced it with a new 180° thermostat. |
08-12-2020, 06:58 PM | #243 | |
08-13-2020, 12:01 PM | #244 |
A trip to the hardware store solved my heater hose plumbing. There was silicone RTV on the plug in the intake, so I put some on the new hose fitting too.
08-13-2020, 08:31 PM | #245 |
I finished up the last details for the Vintage Air install today. Wiring is finished, controls are programmed, fans and vents all work properly, and the compressor belt is on. Duralast part 17580 works well for the belt. (I tried parts 15580, 15585, 15570, 17570, and 17590 which all do not fit). I believe it is finally ready for the refrigerant to be charged!
08-13-2020, 11:57 PM | #246 |
Vintage Air install is complete! System is charged and everything works! Hot heater, cold AC, and a fan that will blow your hat off.
08-14-2020, 07:48 AM | #247 |
Carpe manana
Awesome. Can I have your old AC parts?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-14-2020, 09:20 AM | #248 | |
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul Last edited by Ol Blue K20; 08-14-2020 at 11:08 AM. |
08-14-2020, 11:04 AM | #249 |
Nice timing Jimbo, now you can sit in your truck this week nice and cool when it's 108 out!
08-14-2020, 02:36 PM | #250 |
Jimbo,
I am installing a vintage air right now as well. Which hose is supposed to be vertical (ie the dent shape in the cove box)? Is it the passenger defrost or passenger side vent? |
Tags |
ochre |
