Closed Thread
Old 07-22-2015, 07:21 PM   #2526
JG67
Re: What did you do to your truck today? Chapter II
Did some body work to mine. The first two pics are how it sits today (its a little tough doing body work in Phoenix in 105 degree weather). The last picture is when i picked her up. A lot of sheet metal work but she's getting close.
JG67 is offline
Old 07-22-2015, 07:43 PM   #2527
tdangle
tdangle's Avatar
Originally Posted by Burgie70 View Post
I put on a new fuel pump. What a pain trying to keep that rod up in there and get the gaskets situated. Required another set of hands from my friend. Now I know why people go with an electric one.
Put a glob of grease on the end of the rod, push it in it will say in place while you mount the pump. Old school trick I learned from my dad.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline
Old 07-22-2015, 08:55 PM   #2528
firedemon
got the rims sandblasted painted mounted and put on now just need a lil cash for trim rings and center caps . didn't get pics but found a puddle of brake fluid on floor mat so I had to replace the master and front brake hoses
firedemon is offline
Old 07-22-2015, 10:09 PM   #2529
In The Ten Ring
I worked on my truck all day but didn't take any pics.
1). Ran ERR on a bracket (with little effect).
2). Used compressed air to blow out the tunnel at the base of the new-to-me core support. Not sure if this is sand from the blaster or from its last home of California.
3). I spay painted the strap to the canister bracket.
4). I NAPA Rust Treated the screws for the headlight adjustments after a bit of time on the wire wheel.
5). I bought spray paint for the truck's parts.
6). I bought the new Dorman headlight clips.
7). I made some measurements for the planned trailer hitch plug and D ring tow hitch.
In The Ten Ring is offline
Old 07-23-2015, 03:19 AM   #2530
64chevtruck
Finished my exhaust, re located my compressor and second battery, raised and widened my wheel tubs, added wood to the bed to make it more usable, Put in a Flamethrower, and Completed my quest for fire......
Click link to see flames,
https://youtu.be/LTNf5-nEjbE
Have a good week,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline
Old 07-23-2015, 08:39 AM   #2531
VWNate1
VWNate1's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
As mentioned , just driving 'round and doing chores or wasting Gasoline is always fun and never boring in Chevrolet trucks .
" Festina Lenta " ~ I love it .
I've seen several homemade motorized bicycles , some were really vintage looking using old Briggs & Stratten W1 engines , beach cruiser frames with fat 29" wheels and discarded 1936 Ford spare tire band cut into fenders....
I like your and would love to have one like it for putt - putting around town .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 07-23-2015, 12:19 PM   #2532
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Next time you're up this way, take her for a nice long ride.
At 150 mpg, I'll buy the gas.
https://magwa.smugmug.com/Gasbike/
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-23-2015, 05:48 PM   #2533
VWNate1
VWNate1's Avatar
Thank you Sir ;
I'll do that .
-Nate
Geezer
VWNate1 is offline
Old 07-23-2015, 06:01 PM   #2534
mud.man.rj
mud.man.rj's Avatar
Ride it up to Northern Canada Mag, I will pay the gas..
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 07-23-2015, 06:40 PM   #2535
magwakeenercew2jh
Talking Re: What did you do to your truck today? Chapter II
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 07-24-2015, 01:33 AM   #2536
In The Ten Ring
I used a sealer product from O'Reilly's to seal the panel unions on one side of my core support. *More sides coming tomorrow.
Old 07-24-2015, 02:44 AM   #2537
elkniks
elkniks's Avatar
You know when you are looking at the front of the engine and the fuel pump is just to your left? There are two 3/8" holes right above each other. The lower one goes nowhere, just to a big hole coming up from the bottom of the engine. But the one above that should have a short bolt in it, remove it use a longer bolt and lightly tighten it while holding the pump rod up. The longer bolt will stop against the fuel pump rod and hold it in place.
This is in response to the fuel pump question I saw above. Sorry, I'm still learning how to use this forum thing.
elkniks is offline
Old 07-28-2015, 07:32 AM   #2538
hamjet
hamjet's Avatar
I have to bring this thread back to the top.. I made my fuel line for the 3x2 set up, and I installed my NOS AM/FM/ 8 track player, but for the radio I need to find a hidden antenna for the radio part. the cowl was never drilled for an antenna and I'm not drilling it after 46 years of it being that way..Neil Young! the good old days!!!!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 07-28-2015, 01:24 PM   #2539
BlacklandCamper
Started making progress on my head swap.
Glad I parked under a shade tree before I started. It's been over 100 for the last week.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 07-28-2015, 01:40 PM   #2540
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
Could you expand on the cylinder heads for those of us not sharp on V8's ? .
-Nate
Geezer
VWNate1 is offline
Old 07-28-2015, 05:51 PM   #2541
In The Ten Ring
And I thought I was the only one on here with an 8 track player!
So today, all I have done to my truck is put on two coats of Rustoleum Engine Enamel to the bottom of my truck's new-to-it core support. *It has 1 coat of epoxy primer, 2 coats of Krylon satin black to most sides, and 2 coats of the enamel to the bottom.
Old 07-28-2015, 06:11 PM   #2542
BlacklandCamper
The heads I'm removing are 53cc chamber, with 1.94/1.5 valves. They came off a 305ci engine. The heads I'm putting on are 64cc chamber, with 2.02/1.6 valves, and 164cc runners. Those came stock on HiPo 327ci engines.
The old heads need to be rebuilt, and were already old when they were installed, granted the heads I'm installing are older, but they are fresher.
Old 07-30-2015, 12:12 AM   #2543
VWNate1
VWNate1's Avatar
Post SBC Cylinder Heads
THANX ! .
When I worked in a heavy Duty Truck Shop 30 years ago , all the mechanics had Chevy pickups with 350's in them and they were always going on about the cylinder heads they'd found , factory ones with bigger valves and better porting .
I like to build low compression engines that breathe well , they're unburstable and very fun to drive .
I don't care about stop light drags , I run em hard and fast in the Desert and canyons .
-Nate
Geezer
VWNate1 is offline
Old 07-30-2015, 12:40 AM   #2544
Bowtiguy
Bowtiguy's Avatar
Finally on the ground after starting the dissassembly 4 months ago, only thing left to do is everything!
Bowtiguy is offline
Old 07-30-2015, 12:43 AM   #2545
RustyBucket
RustyBucket's Avatar
2 day brake job/bearing re-pack. New pads, shoes, turned rotors. Put new shocks on the front. No calipers or wheel cylinders leaking, just had to dip a little fluid out of the frt. reservoir on the master cyl. to compensate for the thickness of the new pads. Good pedal, stops nice n straight.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline
Old 07-30-2015, 01:23 AM   #2546
Ozzy2013
Ozzy2013's Avatar
Set the cab and made the z bar linkage and hydroboost bracket and rod.
Ozzy2013 is offline
Old 07-30-2015, 09:54 AM   #2547
fartblossom
fartblossom's Avatar
Got my truck back with new shocks and power steering. Also removed aftermarket load booster springs. It's like a new truck!
Now for some sway bars.
fartblossom is offline
Old 07-30-2015, 07:05 PM   #2548
Ozzy2013
Ozzy2013's Avatar
Cool power steering is great when you didnt have it to begin with !We take it for granted .
Ozzy2013 is offline
Old 07-30-2015, 07:23 PM   #2549
GRX
GRX's Avatar
Originally Posted by jethro5333 View Post
how do you delete a post?
Contact an Admin.
GRX is offline
Old 07-31-2015, 10:58 AM   #2550
mlbrickey
Worked on getting my broken dipstick tube out of the block. I also swapped my intake and prepped for new carb.
mlbrickey is offline
Closed Thread
