Closed Thread
Old 02-12-2011, 09:49 PM   #2551
faribran
Re: What did you do to your truck today?
i put some disc brakes on the front today... and added some T/A wheels..
faribran is offline
Old 02-12-2011, 11:31 PM   #2552
knuckledragger
knuckledragger's Avatar
Drilled the holes for the trans crossmember and bolted it in.Mocked up the e brake cables.Made the pivot for the shifter linkage.Por 15 the surface rust in the cab.Measured the drive shaft for cutting.
65 c-10 swb,bbw,step,402/t350,sold!!
1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold
Bought the wife a 84 gmc short step
knuckledragger is offline
Old 02-14-2011, 01:40 PM   #2553
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Sunday I finally got around to swapping in my new turn signal switch assembly, re-centered the steering wheel and put my 1965 Chevrolet license plate frame on the front. Sure is nice to have self cancelling signals again.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 02-14-2011, 02:44 PM   #2554
Italia
Italia's Avatar
Took out my stock gauge panel. Got my new custom gauge panel today. Put in turn signal lights and brights light in new gauge panel. Got them all wired up. Work great. Now just waiting on my gauges......
Italia is offline
Old 02-14-2011, 05:03 PM   #2555
knuckledragger
Finished the column shifter linkage.Pulled the front clip out of storage and cleaned it with clr and undercoated the innerfenders. reinstalled the headers.Modified the mufflers.
Old 02-16-2011, 07:51 PM   #2556
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
New/old license plate to be issued to my truck soon. This is where I started my yellow accent color. It might have had something to do with the Steelers too.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 02-16-2011, 08:05 PM   #2557
awbrown
Well since I just got it on monday , I have fixed the choke by installing a choke pulloff , installed a new dimmer switch, welded the exhaust back on ...tomorrow I take it for a test drive , after adjusting the brakes..
awbrown is offline
Old 02-17-2011, 01:54 PM   #2558
65Gregg
65Gregg's Avatar
Took my headers off, removed my dist cap & wires, slowly getting everything loose to be ready to pull the engine. For some reason I don't remember the headers being such a pain in the rear going on as they were coming off.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 02-18-2011, 10:08 PM   #2559
knuckledragger
finished the c notch,started on the harness,rebuilt the carb and installed it.
Old 02-19-2011, 08:17 PM   #2560
awbrown
Well I took the 63 out for it's maiden voyage today .. After tightening the headers , replacing the carb ,securing the trans dipstick tube , and adding fluid...... Then since I was so ambitious I adjusted the brakes , only to find out that some one mixed up 2 adjusters , side for side so they actually go the wrong way , I will fix that latter ... but got them adjusted and the pedal feels great ...replaced the thermostat gasket and tried to set the timing , but I am sure it has the wrong balancer on it, so I set it back after it seemed like it wanted to bind while turning it over ...Check the rear ratio , its a 3.08 non posi .. I do know before driving it again I am going to make a new shifter , the one on it has the wrong length arm , hard to find gears ....So anyways took my son around the block a few times , then the wife ... I think I need to make sure then is not a colony of mice in the heater , kind smells going down the road ... it kinda pops out the exhaust once and a while like it has a sticking valve , so I need to throw the vacuum gauge on it and see if I can figure it out.. other than that , it was a great day !! tThe wife says it needs a name . like valentine or mistress.. Ididnt see my wife all day monday when I was on the road towing it home.
awbrown is offline
Old 02-19-2011, 08:53 PM   #2561
jbgroby
jbgroby's Avatar
We got the cab mounted on the frame and bolted down. MILE STONE!! For those who missed it I save a plate for ya.
jbgroby is offline
Old 02-19-2011, 09:27 PM   #2562
billybaloo
Installed the engine and transmission, Sandblasted the pulley's, alternator bracket then painted and install. Measured the belt and purchased and install. I can see light at the end of the tunnel. Tuesday brings Harmonic balancer bolt and new starter. It's scary when you call up Summit to order parts and the guy on the other end remembers your first name $$.
I think I'll call the truck Chevolds. 425 hp 455.
billybaloo is offline
Old 02-19-2011, 09:39 PM   #2563
PGSigns
PGSigns's Avatar
Well this is my first post to this thread and I got a lot done. I have been collecting parts for this truck since I got it a couple of months ago. Today I removed the rear shocks and springs. Let the truck down and marked it for the c notch. Removed the entire stock front suspension and got the right side replaced with the new stuff. Swapped in the 83 A arms and the 2 1/2 inch dropped spindles and got the bag hardware mounted to the cross member. Had the new arms prepped and ready to go all painted up and with all new ball joints and bushings. I had all ready modded the lower control arms for bags. Plan to get the front end all mounted up tomorrow. Will start on the power steering and power brakes next.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline
Old 02-19-2011, 10:11 PM   #2564
Surfdaddy
Surfdaddy's Avatar
Dropped off parts at the plater for rechrome. Got the engine parts to get it on the 61 on the road, and, disassembled cleaned the extra mirrors. Stupid rain !! I'd bring the truck home today if it wasen't raining. There are only 2 seasons in California.... Summer and waiting for Summer.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline
Old 02-19-2011, 10:13 PM   #2565
knuckledragger
Sand blasted the inner fenders and painted them.Ran a tap through all of the front sheet metal mounting points.Might reunite them tomorrow!
Old 02-19-2011, 11:12 PM   #2566
onequickchevy
onequickchevy's Avatar
Put on a new starter, my old one was acting up. I also picked up a GMC grille, but I have to find the bezels now. Wish me luck on that one.
Slowly but surely getting it done.
onequickchevy is offline
Old 02-19-2011, 11:26 PM   #2567
markeb01
Senior Enthusiast
markeb01's Avatar
Looks great! It's nice to see a genuine engine swap every now and then!
markeb01 is offline
Old 02-19-2011, 11:53 PM   #2568
Vernski
Jbgroby that's going to be a nicewhen you get done. All those guys helping set the cab on kinda looks like a pissing contest, just kidding now
The plate of yummies looks good also...Vernski
Vernski is offline
Old 02-20-2011, 12:03 AM   #2569
daverod
SSN 706
daverod's Avatar
Thought about getting my cab on. Then it snowed a bunch so I worked on my snowmachine. Going riding tomorrow. Then I'll put my cab on.
daverod is offline
Old 02-20-2011, 01:13 AM   #2570
k1rodeoboater
69 Camaro tank mounting brackets and straps built and assembled. Tomorrow I'll be installing it into the truck, it got dark before we could do it.
I may run the lines and wiring tomorrow as well, but the tank can't be used till I get a gas cap for it.
k1rodeoboater is offline
Old 02-20-2011, 10:25 PM   #2571
nachodog2
Hell yeah!!!
nachodog2's Avatar
added a turn signal switch and some indicator lights on the dash, added a new interior light with door activated switch and picked up a freebiee steering wheel that if it fits is going on.
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 02-20-2011, 11:46 PM   #2572
Vics63Chevy
Vics63Chevy's Avatar
Took the original 3 on the tree manual tranny out of the truck!
By the way, I'm planning on selling this tranny since I have no use for it. How much do these go for?
Thanks guys
1963 Destiny Build Log
Vics63Chevy is offline
Old 02-20-2011, 11:53 PM   #2573
PAPA KENT
PAPA KENT's Avatar
with new paint last weekend installed the doors and hardware,installed the tailgate.reinstall the glass tomorrow.
PAPA KENT is offline
Old 02-21-2011, 10:05 AM   #2574
biohazardbill
Went from this:
to this:
I know its 8 lug and just sitting on the axles at the moment, just waiting on some parts to come in to get it down the rest of the way.
biohazardbill is offline
Old 02-21-2011, 02:51 PM   #2575
70inline6
Purdy'd up the valve cover, installed the HEI dist., and put on the new alternator. It's starting to go back together now.... Maybe I will drive it this spring...
70inline6 is offline
Closed Thread
