02-17-2015, 12:19 PM | #2601 | ||
Still Learning
Re: 1969 Short Wide
Thanks Scott. Quote:
I built this truck to drive, not a show piece. I will keep on truckin |
02-17-2015, 12:29 PM | #2602 |
Re: 1969 Short Wide
Oh man that sucks! It sure could have turned out much worse though.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
02-17-2015, 01:41 PM | #2603 |
Re: 1969 Short Wide
Sorry to hear it, Mike! Hey, at least the first scratch is out of the way now!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
02-17-2015, 01:54 PM | #2604 |
Re: 1969 Short Wide
Thanks Buck. It was painful but since it's not noticeable unless you lay underneath, I'm alright. If it dented the rocker or door, I would be crying in my beer.
I built this truck to drive, not a show piece. I will keep on truckin [/QUOTE] That's what I'm talking about. Drive the wheels off of it and then rebuild it again.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
02-17-2015, 02:44 PM | #2605 | |||
Still Learning
Re: 1969 Short Wide
I hit it square with it standing on it's edge. Quote:
02-17-2015, 04:29 PM | #2606 |
Re: 1969 Short Wide
Wow Mike sorry to hear that happened, I know you'll have it fixed good as new in no time.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-17-2015, 11:15 PM | #2607 |
Here kitty kitty kitty
Re: 1969 Short Wide
That sucks man...but like you said, it is a driver. My bed has many scratches already because I use it. A couple weekends and you will have it good as new, your ability is phenomenal brother. Truck is looking beautiful otherwise. I will have to hit you up for advice on the LS swap.
02-18-2015, 01:38 PM | #2608 |
Re: 1969 Short Wide
Mike your truck looks really great... I've still got a lot of catching up to do. Bummer about the trucker tread!
PROPS TO YOU SIR! Also you'll love the Talimena Byway. Went and rode it on my Harley last Fall and we decided to make it an annual trip. It's awesome. |
02-18-2015, 02:22 PM | #2609 | |||
Still Learning
Re: 1969 Short Wide
I actually made it out to the Talimena drive a few times this winter. Not in this truck but I will take it out there drive this fall. |
02-21-2015, 11:40 PM | #2610 |
Re: 1969 Short Wide
Sorry to see what happened to your truck, that sucks. i followed your build and when I saw the pictures it felt like my truck got dented. Thanks for sharing all your hard work with us, you did a great job on it and provided a lot of info and motivation!
02-21-2015, 11:52 PM | #2611 |
Re: 1969 Short Wide
Man that sucks! But unless you wrap it in bubble wrap things are going to happen. I'd rather get dents, dings and scratches & enjoy driving it than for it to sit in a garage.
02-22-2015, 08:58 PM | #2612 |
Loves all GMC trucks
Re: 1969 Short Wide
Mike,
That sucks to have that happen to you. I feel for you. I hope you get it back and good to go when you have time. It's beautiful still with the damage but I know it will bother you. I'm sure the pucker factor was high when you saw it coming and couldn't avoid it. I had a similar incident it 1993 with my 1992 mustang coupe competition car! The retread flipped under the air dam and smacked and pulled my 00 power able causing an engine fire. I got it put out but a scary ride/incident none the less.
Mike If your helping someone and expecting something in return... your doing business not kindness! |
02-22-2015, 09:15 PM | #2613 |
Re: 1969 Short Wide
Damn Mike that sucks, at least it's in an area hard to see! Good to hear most of the damage could be wiped off though.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
02-22-2015, 09:23 PM | #2614 |
Re: 1969 Short Wide
That kind of sucks. sorry to hear. i think it will be fine with some touch up as mentioned
Dean 1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187 in God we Trust |
02-23-2015, 09:35 AM | #2615 | ||||
Still Learning
Re: 1969 Short Wide
thanks Dean. Ole red will keep on truckin. |
02-23-2015, 10:35 AM | #2616 |
Man of Mini-Talents
Re: 1969 Short Wide
Well crap, what a shame. Most of the black marks should come off and it won't look so bad.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
02-24-2015, 01:09 AM | #2617 |
Re: 1969 Short Wide
Just went through your cab repair section on the cab corner Mike. It looks great. I'm having a issue with getting my LMC cab corner to fit right. It looks like I'm going to have to order a Tabco cab corner hopefully that will be the trick. I made templates before I cut off the cab corner and the LMC cab corner isn't even close.
Scott |
02-24-2015, 02:49 AM | #2618 |
6>8 Plugless........
Re: 1969 Short Wide
Sorry to see of your run in with a retread. At least it wasn't worse. Rub it out and keep on truckin.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-24-2015, 08:58 AM | #2619 | ||
Still Learning
Re: 1969 Short Wide
Thanks for stopping by Ryan. I'm gonna rock on in the truck as soon as we get a break from the weather here. |
02-24-2015, 10:49 AM | #2620 | |
Re: 1969 Short Wide
1970 SWB Build |
02-24-2015, 11:35 AM | #2621 |
Re: 1969 Short Wide
Thanks for the heads up. I had bought some from Classic Parts and they too fit like junk. I wish the people that make these panels for these old Chevy trucks would use what they make and maybe we wouldn't get sold the junk panels we do.
Scott |
02-24-2015, 12:28 PM | #2622 |
Re: 1969 Short Wide
Sucks to see the water pump and damage from the tire. At least the water pump was a fairly easy fix. I know you'll have the truck looking right again from the tire damage. It's good to see that you're out enjoying it. I need to get motivated and get my pile back on the road soon
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
03-27-2015, 08:06 AM | #2623 | |||
Still Learning
Re: 1969 Short Wide
03-27-2015, 09:30 AM | #2624 |
Still Learning
Re: 1969 Short Wide
I got the chance to meet up with some other C/10 enthusiasts a few weeks ago at the Coffee and Cars cruise in OKC. It was good meeting with board members Zoomin, Suspect, sambob2285 and a few new guys also checking out a bunch of nice trucks and cars. C/10 Club Oklahoma is off the ground.....
If you're in Oklahoma and want to meet up with us, we are gathering again next Saturday at the same location. Pictures.... |
03-27-2015, 12:26 PM | #2625 |
Re: 1969 Short Wide
Can't wait for cruise nights.. Nice stuff Mike. Just read up on the tire tread incident. I laugh (with respect) how calm you sound on these things. It's a virtue I struggle to achieve.
