Old 01-29-2019, 01:29 AM   #2651
DransportGarage
DransportGarage's Avatar
Re: What did you do with your truck today, Part 3
Originally Posted by MiraclePieCo View Post
I'm going to nickname you "Aristotle" because all your comments are so profound!
I am humbled, but you won't have to wait very long to see me screw up!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 01-29-2019, 09:51 PM   #2652
MiraclePieCo
MiraclePieCo's Avatar
Starts, runs, no leaks so far on a brief test fire.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 01-29-2019, 09:57 PM   #2653
svr
svr's Avatar
Doors hung, door adjustment close, will need more fussing when i get the fenders on.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 01-29-2019, 10:00 PM   #2654
MiraclePieCo
Definitely unique and one of my favorite trucks. That long 6 is killer.
Old 01-30-2019, 12:21 AM   #2655
oldman3
oldman3's Avatar
Glad to hear, keep us posted...Jim
oldman3 is offline   Reply With Quote
Old 01-31-2019, 03:18 PM   #2656
DransportGarage
Made and installed the steering wheel cover. OK job. I made about five minor mistakes. If I ever do another one it will be better. The stitches need to be closer and material at the ends of the spokes needs to be a little longer. It looks better in real life than in the pictures.
Bob
Old 01-31-2019, 11:56 PM   #2657
svr
svr's Avatar
Noticed something i hadnt seen before today. Drivers door has damage i missed when i worked on it. Leaves a big gap when closed at the front of the door. The front of the door is crushed a bit, not sure who or how that happened. Dont know what to do, wish i had another door to fix up at this point.
Old 02-01-2019, 02:02 AM   #2658
MARTINSR
MARTINSR's Avatar
Bummer! But does the door seal? That right there isn't going to be seen, does it seal?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 02-01-2019, 03:03 AM   #2659
MiraclePieCo
OMG, that sucks - it's already painted! Is that door jamb at the front supposed to be curved? It almost looks like something got wedged in there as the door was closed.
Old 02-01-2019, 03:17 AM   #2660
DransportGarage
That sucks. If needed to seal the door, I'd be inclined to make a rubber strip that tapers on both ends, and would glue underneath your weatherstrip, effectively making it thicker where needed.
Bob
Old 02-01-2019, 11:31 AM   #2661
svr
svr's Avatar
Angry Re: What did you do with your truck today, Part 3
Not sure if it will seal or not, I don't think cab side is damaged but will make a template off the other side and see, kinda bummed out over the deal. Really don't want to by after market door, so door shopping in spare time.
Old 02-01-2019, 12:26 PM   #2662
idbeast
SVR I have an extra door it is yours if you want it, it will only cost you the time and gas money to come get it!
idbeast is offline   Reply With Quote
Old 02-01-2019, 12:52 PM   #2663
svr
svr's Avatar
Thanks, PM sent
Old 02-01-2019, 12:54 PM   #2664
DransportGarage
Looking at my truck vs. your pic, it looks like the cab is more bowed than the door. I hope I'm wrong. (A template will tell if your other side is undamaged.)
...or maybe I shouldn't hope I'm wrong. I little coaxing of the cab with a rubber mallet or a cushioned port-a-power may improve things quite a bit without paint damage. Keep us posted...
Bob
Old 02-01-2019, 07:32 PM   #2665
svr
svr's Avatar
Ok here's the situation, it appears somebody in this doors previous life tried to repair some damage or what ever. On the front inside corner between the hinges it either cracked and broke or they cut it on the corner. They hammered over about a1/2" of the inside skin over onto the front of the door and welded it. After i made a template from the pass side and put it onto the drivers side of the cab i found the drivers side of the cab was pushed forward about 1/4" between the hinges, not to big of a deal i got it back in shape with some blocks and a 2x4 prying on it. I cracked the paint a bit but it will be covered by the kick panel.
Old 02-01-2019, 07:35 PM   #2666
svr
svr's Avatar
Template on cab after the fix
Old 02-01-2019, 07:40 PM   #2667
svr
svr's Avatar
Next issue is when they did that it distorted the outside skin so the profile isn't right against the cab. Its not to bad except for about a foot below the top hinge level. The area between the blue tape will probably not seal.
Old 02-01-2019, 07:44 PM   #2668
DransportGarage
Crap. Significant bodywork should fix it, but the paint will be crap. Lots of hours. I'd be inclined to do that rather than replace the door and start over, which will be more hours.
Bob
Old 02-02-2019, 09:30 AM   #2669
MIKESAD50
Bob that steering wheel look awesome, especially for your first time
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-02-2019, 02:26 PM   #2670
DransportGarage
Thanks, Mike!
Bob
Old 02-02-2019, 09:46 PM   #2671
evilokc
I repaired the missing threaded insert on my hood. it was pretty easy to do. I was going to mount it and then decided I was going to spray the underside of the hood with a rubberized spray coating. I know it wont be beautiful but it will be a nicer cleaner universal colored hood that will look a lot better than the faded primer it is now. I did the first half and it went fine. on the second half the first thing I noticed was that the coating (same brand) looked darker. I hoped it would lighten up as it dried. the second coat was where everything went bad. the spray can started spitting and then dropped several large blobs of coating. I grabbed a different can and tried to fix it but the morning will tell me if that worked or if im going to be sanding. im annoyed. I also drover the truck all day. went to the gym, lunch, ran some errands. I believe I even created a future gearhead. I was at autozone getting a headlight bulb for shakes car. I saw a kid looking at the death rattle. I went out and let him have a real good look and answered several of his questions. im guessing he was 10. it was neat.
evilokc is offline   Reply With Quote
Old 02-02-2019, 11:06 PM   #2672
MiraclePieCo
Everywhere you go you are a rolling car show!
Old 02-03-2019, 11:09 PM   #2673
MARTINSR
MARTINSR's Avatar
Well, today I got my bed all stripped and all the bondo work done on the bed sides and head board and tail gate it's all ready for primer.........just kidding, I did nothing but I did get all that done, does that make sense?
I sold a couple of tools that have been hanging out in my garage for the past 20-30 years that will WAY more than buy a new bed for me so I don't have to do that bondo work and all that. I sold two pneumatic plannishing hammers for $3200, but I did pay a lot for them, I had $20 invested in the whole thing, no kidding! I bought one of them for $20 and the other I got for free, wow, holy crap! That and my 1962 Gibson E120 and a few other high end things and I have a bunch of money for my truck.
Wow, I am stunned here, I need to go and relax this hard work has beat me up.
Brian
1948 Chevy pickup
Old 02-03-2019, 11:29 PM   #2674
MiraclePieCo
Brian
We're in the wrong business!
I too have been selling off unused stuff that I once treasured to help finance my now 50% over budget truck build.
Old 02-03-2019, 11:37 PM   #2675
MARTINSR
MARTINSR's Avatar
Yep, I can't believe the stuff I have been selling, and a lot of it going for much more than I thought it would. Nothing like pulling a box of four HO slot cars out of the attic and getting $100 for them! No more storage, and a hundred bucks! Right on!
Brian
1948 Chevy pickup
