Old 12-11-2014, 01:08 PM   #2676
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "What was I Thinking" 68 SWB
I'm jealous brother, your cab looks awesome and you did it yourself!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 12-11-2014, 01:40 PM   #2677
mcbassin
Still Learning
mcbassin's Avatar
Looks great to me Keith!
mcbassin is offline   Reply With Quote
Old 12-11-2014, 10:48 PM   #2678
mx289
mx289's Avatar
Looking good Keith.
Glad you hear you decided on the two tone.
And the LS is now in the mix.
Your right,If you want it now is the time.
Keep at it.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 12-12-2014, 07:06 AM   #2679
Bennett68C10
Bennett68C10's Avatar
Originally Posted by nds1968 View Post
Looking good, keep at it.
Thanks Nate, I try to do work on it whenever I get a chance but it seems to be taking forever.
Originally Posted by KMC3420 View Post
Dang Keith, your cab looks great. It will all be worth it in the end. Keep at it.
Thanks, I try to tell myself that as i'm sanding, it will be worth it but my arm still hates me anyway
Originally Posted by jlsanborn View Post
Looks awesome! How'd the drip rails go?
Thanks, it's not perfect but will have to do. The SEM self leveling went down really nice and if it wasn't for some spots of human error, then it would have been perfect. Good thing for me is it can be sanded so I sanded out the imperfections the best I could. Once I got the hang of it, it layed down like glass.
Thanks Buck, it has been a lot of work to get to this point and it's still not perfect but will have to do. I'm jealous of that LS1 you have going in your truck and I love the new wheels, one of my favorites.
Thanks Mike, it's not perfect but I honestly don't have the time or patience to try to make it absolutely perfect. Just hope it comes out good enough that only I can see where the flaws are
Originally Posted by mx289 View Post
Looking good Keith.
Keep at it.
Thanks Tom, yeah as long as I don't chicken out when I go to paint, it will be two tone it's probably not the right time budget wise to tear the big block out and go to an LS but it is the right time to do it before I assemble the truck for the last time. I can get it mocked up and run all my fuel lines and stuff before the cab goes back on.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-12-2014, 09:00 AM   #2680
mcbassin
Still Learning
mcbassin's Avatar
Trust me you will know exactly where every flaw is located
What type of guide coat are you using?
Old 12-12-2014, 10:24 AM   #2681
c10Dream'n
c10Dream'n's Avatar
you have made some major leaps and bounds with the progress. can't wait to see the paint.
c10Dream'n is offline   Reply With Quote
Old 12-12-2014, 11:10 AM   #2682
Bennett68C10
I'm using 3m powder guide coat with the foam applicator. It has helped me a ton.
Thanks, I can't wait to see some paint on it too. I'm tire of looking at gray
Keith
66 Suburban
IG: bennett68c10
Old 12-31-2014, 07:34 PM   #2683
zacthrasher
zacthrasher's Avatar
Your cab is looking good, I can't wait to see it with the paint! Also thanks for the advice on choosing a cam!
My 67 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=473825
zacthrasher is offline   Reply With Quote
Old 01-01-2015, 12:36 PM   #2684
Bennett68C10
Thanks, I've taken the last few weeks off from the truck, haven't had the time or the patience to do more blocking. I have been researching my LS swap pretty extensively though and everybody seems to recommend those cam guys to spec a cam for your application. I'm certainly learning myself but I still need to grab a motor before I figure out what cam I'm going to go with your way ahead of me in that department. I have spent the last couple of weeks over on LS1tech and read through a ton of info, great site.
Keith
66 Suburban
IG: bennett68c10
Old 01-01-2015, 12:40 PM   #2685
aggie91
I'm just glad to be here!
aggie91's Avatar
Keith, check out lt1swap.com too. He has a ton of info and shows how to convert your own factory harness to stand alone. I did that for Sunburn and it worked great. We had the PCM tuned/flashed by someone else for a bit more performance, but for a stock engine he can did a reflash for less then a $100.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-01-2015, 12:49 PM   #2686
Bennett68C10
Happy New Years everyone, if you read my previous post I haven't worked on the truck for a few weeks now. Just to much stuff to do around the holidays and what time I did have I couldn't stomach doing more blocking My wife picked me up some parts for Christmas, new PUI Black sunvisors and new brackets. I'll get back on the truck this weekend and start blocking again.
Keith
66 Suburban
IG: bennett68c10
Old 01-01-2015, 12:58 PM   #2687
Bennett68C10
Thanks for the info Karl, I'll check the site out. I don't know if I'm confident enough to cut my own harness down but I'll definitely give it a look. I'm planning on running a little more then a stock motor, I'll definitely be doing a cam swap and a intake swap. I picked up a LS6 intake off of LS1Tech because I just don't like the way the truck intake looks and like the car intakes much better. I also won't have to worry about hood clearance either. Of course now I have to figure out the front accessories and still actually get a motor I'm trying to decide between a 5.3 or spending the extra coin on a 6.0.
Keith
66 Suburban
IG: bennett68c10
Old 01-01-2015, 01:03 PM   #2688
Bennett68C10
I have to clean it up and plan on painting it Satin Black but it is perfect with no broken parts.
Keith
66 Suburban
IG: bennett68c10
Old 01-01-2015, 06:59 PM   #2689
gringoloco
A guy with a truck
gringoloco's Avatar
Good plan going LS. Great platform- BB power, SB size, and NO oil leaks! Keep it up; this thing is gonna be killer
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-02-2015, 12:22 AM   #2690
Bennett68C10
Thanks Chris, glad to see you back on here. The big block was really an ego thing for me, just popping the hood and seeing that fat rat motor has always made me smile but I decided that I really want a modern motor with fuel injection and the ability to drive it anywhere. I know I could add fuel injection and overdrive to my big block but it would cost me much more in the long run then the LS Swap but would still leave me with a motor that leaks oil, has iron heads and a flat tappet cam and gets less then 10 mpg. Wish I would have made the decision sooner but I'm not looking back now.
Keith
66 Suburban
IG: bennett68c10
Old 01-02-2015, 12:37 AM   #2691
ddubbs
ddubbs's Avatar
Can't go wrong with a ls swap. Truck is looking killer!!!
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 01-02-2015, 12:45 AM   #2692
sduckworth13
sduckworth13's Avatar
Keith your cab is looking awesome! Nice work!
Scott
sduckworth13 is offline   Reply With Quote
Old 01-02-2015, 12:48 AM   #2693
mikeleeshields
mikeleeshields's Avatar
Looks good Keith. I've been thinkin about a motor swap also. May wait till next winter
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 01-02-2015, 11:02 AM   #2694
jeh
jeh's Avatar
Hey Keith, looks like I've missed out on some changes in the last couple months going to be an awesome truck when it's finished.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 01-02-2015, 12:25 PM   #2695
SeTx67
SeTx67's Avatar
I know the truck intakes aren't pretty but they perform a little better on the torque side. I have a truck intake on mine with a engine cover and it doesn't look to horrible lol. You could just forget about the intake all together and bolt a blower on top
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 01-02-2015, 06:48 PM   #2696
Bennett68C10
Thanks I figured the truck won't be done anytime soon so I might as well go ahead and do the LS swap.
Thanks Scott I should be getting back on it Sunday
I have to re-do my exhaust and fuel lines for the dropmembers anyway so now is the perfect time to swap motors and get a little more modern. I had a 454/TH400 in my 72 and it is no comparison to the 5.3 in my 2013 GMC. This is what sold me on finally pulling the trigger on the swap. The 454 sounded better then my 5.3 does but I'll fix that
Thanks Jason, you haven't missed much, I'm still just working on the cab getting it ready for paint. Oh and I decided to swap drivetrains
I thought about swapping to the Trailblazer SS intake with the engine cover you have but I always liked the way the car intakes looked and my dropmember moves the motor up so I didn't want to run into any hood clearance issues. I wish I could do a blower but that is way out of my ballpark
Keith
66 Suburban
IG: bennett68c10
Old 01-10-2015, 10:29 PM   #2697
Bennett68C10
Some pics from last Sunday and today. The roof needed more filler work because I had low spots that ran the length of the drip rail above the door. I guess I sanded to much there and had no choice but to fill it.
Today I spent blocking the dash with 320, man what a huge pain that was. I'll sand it with 600 wet and it will be ready for sealer and paint.
Keith
66 Suburban
IG: bennett68c10
Old 01-10-2015, 10:42 PM   #2698
kxmotox247
kxmotox247's Avatar
looks great! Can't wait to see some paint on it.
kxmotox247 is offline   Reply With Quote
Old 01-10-2015, 10:53 PM   #2699
zicc1835
zicc1835's Avatar
really looking goooood.... maybe early spring .... i bet we see some color ....
zicc1835 is offline   Reply With Quote
Old 01-11-2015, 01:32 AM   #2700
mcbassin
Still Learning
mcbassin's Avatar
Very nice work Keith
bbc, dropmember, intro wheels, porterbuilt
