Old 10-08-2010, 03:10 PM   #251
SactoJim
SactoJim's Avatar
Re: 72 Cheyenne Build Thread
Had my truck on the lift the other day to change oil and check some other things and figured better take some pics before it gets too dirty and beat up!.....about 6k miles and it's staying pretty clean!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 10-08-2010, 03:21 PM   #252
67cheby
67cheby
67cheby's Avatar
Very Clean, nice job
67cheby is offline   Reply With Quote
Old 12-03-2010, 04:57 PM   #253
Racie
How do you like that transmission pan Jim? Does the 700r4 seem to be holding up to the abuse?
Racie is offline   Reply With Quote
Old 12-03-2010, 05:11 PM   #254
SactoJim
SactoJim's Avatar
So far so good......though I don't beat on it too hard. The pan is fine and I also have one of those aluminum finned coolers mounted to the side of the frame rail, but the tranny still gets too hot in traffic (have a trans temp gauge). I need to reroute the lines through the radiator and to a better cooler mounted up front.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-03-2010, 05:36 PM   #255
Racie
Sounds good I'm going to get a trans cooler just in case. I ordered a level 3 700r4 which should be plenty for a street truck but I wanted to be sure because of the 502big block but they say it will be good up to 700hp with a one year unlimited mile warranty. So I will be putting it through it's paces lol...
Old 12-03-2010, 05:38 PM   #256
Racie
BTW I have the drop and front/rear sway bar package also with all new bushings and springs. How does your handle and ride?
Old 12-03-2010, 05:46 PM   #257
SactoJim
SactoJim's Avatar
It rides pretty well for older lowering techniques....stepped A-arms and dropped springs. I bought the lowering kit for it waaaaay back in the early 90's when there wasn't much available. Shocks are also a good 15 years old (KYB gas adjusts that I painted). I also need to flip my tie rod ends because of some bumpsteer......but for the most part it works pretty good.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-03-2010, 11:05 PM   #258
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Very nice Jim. To bad John couldn't get those shots for your magazine feature.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 12-04-2010, 03:00 AM   #259
spike38
spike38's Avatar
Still looks great!
Spike
spike38 is offline   Reply With Quote
Old 12-13-2010, 08:01 AM   #260
Sicmaro
Always wrenching!!
Sicmaro's Avatar
Jim do you have a pictures of what you did with the inner passenger seat mount? I just picked up a 93 seat and am going to cut it down the 1.5 inches. Seems like the inner pass side may just need a spacer of some sort? Thanks.
71 C-10 5.3L/4L60E
72 Camaro LS6/4L60E
06 Duramax
19 RZR XP4 turbo Dynamix
56 Belair 5.3/4L60E swap in progress
Sicmaro is offline   Reply With Quote
Old 12-14-2010, 12:46 AM   #261
SactoJim
SactoJim's Avatar
Dang....looked all over for pics and can't find any......from what I remember, I had a spacer on the front before I cut the brackets down and It seems go me that the 1.5" I cut off was just enough to not need a spacer anymore on the front.....I'm pretty sure I cut the back down....been like 3 years since I did that! Pretty easy mod and I'm glad I did it.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-14-2010, 02:21 AM   #262
ryans69chevy
I was looking at your circuit board by your emergency brake and confused me by the color of the carpet. I see the seam of the black carpet but then it still goes black up the firewall. I'm wondering what material you used. You must have put something over your sound deadening...It looks pretty cool like that. Spectacular paint btw!!!!
ryans69chevy is offline   Reply With Quote
Old 12-15-2010, 08:38 PM   #263
SactoJim
SactoJim's Avatar
Thanks.......just some semi-gloss rattle can paint before I put the carpet down!
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-16-2010, 01:27 AM   #264
ryans69chevy
So you just painted over your sound deadening stuff? or did you lay any jute padding or anything?
Old 12-16-2010, 02:27 AM   #265
SactoJim
SactoJim's Avatar
I first sprayed the cab with Lizard Skin sound deadening material and then laid the foil back insulation down. I also used some hvac sticky back duct insulation material around the edges and up under the dash. When I put the carpet down, I just sprayed black on the foil areas that were exposed.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-16-2010, 10:37 AM   #266
76kcfdeng
Jim, your truck looks great! I can only hope mine comes out half as good. I would like to see it in person someday, I travel through Sac approximately every 10 days. Enjoy driving it.
Glen
70 Chevy SWB Fleet Project.
06 Lancer Evolution MR SE, stupid fast!
03 Ford f-250 crew cab, 6spd, diesel
56 ford f100 project
My build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=426739
76kcfdeng is offline   Reply With Quote
Old 12-16-2010, 10:09 PM   #267
ryans69chevy
That's a pretty nifty idea! How does the Lizard Skin compare to other sound deadening material? That stuff you have to use a spray gun right?
Old 12-16-2010, 11:32 PM   #268
SactoJim
SactoJim's Avatar
Glen
Thanks Glen......anytime your in the Roseville area, give me a shout 916-276-5317. Be glad to show you my truck along with the latest refinish and structural repair equipment.....we sell collision repair equipment.
Couldn't tell you how it compares......just seemed like a easier solution as opposed to Dynamat or similar....and yes, applied with a undercoating type spraygun.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 12-16-2010, 11:35 PM   #269
Painter D
Painter D's Avatar
"The latest refinish and structural equipment", too bad I don't make it out to Cali very often I wouldn't mind checkin out your truck , and your workplace myself.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 12-17-2010, 12:39 AM   #270
76kcfdeng
"Thanks Glen......anytime your in the Roseville area, give me a shout 916-276-5317 . Be glad to show you my truck along with the latest refinish and structural repair equipment.....we sell collision repair equipment."
Thanks Jim, I will definitely call you next time I am passing through.
Just what I need more tools.
My build thread.
Old 12-17-2010, 10:22 AM   #271
killer71
killer71's Avatar
Beautiful Truck! Nicely done!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 12-19-2010, 07:57 PM   #272
RCbowtie69
RCbowtie69's Avatar
nice truck!!!
RCbowtie69 is offline   Reply With Quote
Old 01-24-2011, 06:10 PM   #273
lowdownstar
big guy
lowdownstar's Avatar
I just took some time to look over your build and i have to say your truck came out fantastic. I love how clean and well put together everything is. I can see why you are winning shows with your truck! great job
Thanks Ray
lowdownstar is offline   Reply With Quote
Old 01-25-2011, 11:07 AM   #274
west9378
west9378's Avatar
If you have already shared with the group I am sorry to ask again but how did you refinish the frame, did you sandblast prime and paint or use some of that rust cover over paint?
Thank you in advance
West
west9378 is offline   Reply With Quote
Old 01-26-2011, 01:22 AM   #275
SactoJim
SactoJim's Avatar
Originally Posted by RCbowtie69 View Post
nice truck!!!
Originally Posted by lowdownstar View Post
I just took some time to look over your build and i have to say your truck came out fantastic. I love how clean and well put together everything is. I can see why you are winning shows with your truck! great job Thanks Ray
Thanks alot guys......compliments much appreciated!
West
I just cleaned and stripped it and then put on a good Black Epoxy primer. Nice thing about most Black Epoxy's are they typically dry to a nice satin finish.
- supercharged 383
- 4 wheel discs
My Build Thread
