#251 |
I have a radical idea!
Re: 67 C-30 Dually pickup build.
Thanks David!
Thanks as well Doug! No, that's the CDR valve, which serves the same purpose as PCV for a gas engine. Water injection would be nice though! I'm planning on intercooling later.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#252 | |
FarmBoy.
Welcome back man! It's been lonely here without ya. Glad to see you're back and making progress on both your dually and the Camaro. Absolutely *****in'.
-Sam.
1969 GMC C1500. long fleet. 307. 3 on the tree. 3.07 gears. Oliver green. Bent and bruised. Daily Driver. Quote:
http://67-72chevytrucks.com/vboard/s...d.php?t=242993 |
#253 |
Thanks Sam! I looked back and saw that you are still driving the green beast daily, and also saw that you had got yourself a deuce. The red and white 2 tone will look great. I love Chevy II's and I can't wait to see your progress on it.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-21-2010 at 10:54 PM. |
#254 | |
FarmBoy.
Thanks! I sure am still driving that green meanie. She's gettin' tired, but still keeps goin'.
And my little II should be fun when all is said and done. As soon as all the rust is fixed it'll be simple. Haha, where have we heard that before... ![]() I'll be sure to post an update soon in my build in Alternate Tinkerings, I've been at it again. Thanks for keepin' tabs on me. ![]() -Sam.
#255 | |
I still have to commend you guys up North, because I would run in fear of that kind of rust, but you seem to be cutting it out and making it better that ever.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-21-2010 at 11:12 PM. |
#256 |
Good to see you back on the board.
Are you using the stock fuel system? If not, what size fuel lines did you change over to? That is one sweet setup! |
#257 |
Nice to have you back, now lets see some more progress! BTW, i dig the camaro, wish i had one, but the ones I am working on are not mine
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#258 |
Rottenwood Garage Member
Cruise on up this weekenf for the BBQ/mini meet.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
#259 | |
Thanks!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 03-22-2010 at 07:09 PM. |
#260 |
When and where is it?
#261 |
#262 | |
#263 |
I wired the glowplug harness and solenoid today, and started working on the radiator support. I am going to have modify a battery box for the driver's battery and I am going to go ahead and put cut outs in it for an intercooler because I know it will end with one. I ratchet strapped the (redneck, I know
) and moved it on it's own power for the first time. I could let out of the clutch at idle speed in 1st or 2nd gear with the NP435, and it would take right off. It seems like it is going to be very strong. My modified Z bar with the rod ends really works smooth. It feels more like a hyd clutch than an old manual one. I pulled a power steering box off of a parts truck tonight and I going to start working on the hydraboost brakes and power steering this weekend.
#265 |
Sorry to ask a question that I know has already been asked, but...
Did you use small block chevy harmonic balance bolts and washers with your big block towers? If not, what did you use? |
#266 |
No, I bought some Grade 8 3/8" bolts and used (2) 1.5" diameter 1/8" thick washers per each mount. A SBC harmonic balancer washer would probably work great though.
#267 |
Do you remember how long the 3/8 inch bolt is?
#268 |
I think they were 1 1/4" long, IIRC. I wanted as much thread holding as possible.
#269 |
dazed and confused
need more pics!!
members met: redbaron69, billsbowtie,nc67 |
#270 |
Well, I got the fuel lines hooked up and I got the accelerator pedal and cable installed. (Putter's accelerator rod to accelerator cable pedal swap FAQ thread was a life saver here! Big thanks!) I snapped a few shots of the cable. I wish I could find a cable with a preformed 90 in it down to the IP, but this is the way the early factory diesel trucks were, so I guess it will work. I may look into a Lokar braided cable eventually. They are more flexible, and it would look better.
PS: I have got to get a new camera! I do';t know what has happened to thing!!
#271 |
I got a call from uncle with some great news. He found me a nice pair of 67 stepside fenders. The final piece to the puzzle!
I'm going to pick them up ASAP.
#272 | |
Location: Help! I'm in an office park with its own network of freeways!
That engine is looking great.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
#273 |
what fuel tank are you using....I am putting a 6.2 in my 71 burb, and I am trying to figure the fuel system out. Can I use my existing blazer/burb style tank, and if so, what sending unit would I use to accommodate a return fuel line?
#274 |
Another question....the BBC motor mounts you used, are they available at the parts house? I see some have called them towers....are they the same thing. I am thinking you mean the motor mounts that mount on the front 2 sides of the block. I guess I am full of dumb questions....but i come by it honestly. thanks, and btw, your build keeps me inspired.
#275 | ||
Thanks! I'm using the original in-cab tank with a sending unit from a '71 - '72 model truck that has the return line. I'm assuming that's all you'd need for your Suburban as well. On the mounts, I'm talking about the towers that mount to the frame. You can use SBC motor mounts, but you have to get BBC towers.
| Bookmarks |
