09-12-2011, 12:09 PM | #251 |
Registered 1971 K5
Re: AJ's '72 Cruiser Crawler Build
12-04-2011, 08:32 AM | #252 |
I hope that my blazer will look that good some day.
1971 Chevy K5 Blazer (Big Blaze) 1974 Chevy 3/4 4x4 Stepside (The Minion) |
04-11-2013, 08:26 PM | #254 |
Yeah, I still have it. It's been waiting patiently at the shop on jack stands. Personal life has put the build largely on hold the past year. Nothing particularly worthy of updating the thread with.
04-12-2013, 07:42 AM | #255 |
Cool. I read through the build and seen it just stopped, wanted to see how it was doing. Hope ya can get her back out on the road!
04-14-2013, 11:28 AM | #256 |
PROJECT 7DEUCE
Good to see ya still have her... I hear ya on the life thing...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-14-2013, 08:19 PM | #257 |
X2, putting family first is the reason i have 12 years in my build, that plus money
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-22-2014, 08:19 PM | #258 |
4/21/14 - This build still exists?! Yes, actually it does... Getting back down to business.
Even though I haven't fired up the motor, I decided it needed a bigger cam. Pull the motor and dropped in a Lunati Voodoo and put on a new set of roller rockers. Sold off the Edelbrock MPFI...changed my mind here too. It was an older system and decided I wanted to go with one of the new self learning setups. So.... next came an Edelbrock dual plane manifold. Motor went back in go back in and then start putting this stuff on... Dropped on the throttle body. This thing is dead sexy if I do say so myself. Added the throttle cable bracket and set the TV cable on the tranny. Mounted up the regulator. The pressure gauge (not shown) is a little closer to the frame than I'd like, need to tweak it a bit. Plumbing is almost done. Changing out my supply line to -6 from -8 next. Waiting on parts from Summit. Those with a good eye might notice the rig has changed locations. Bought a new house with a <cough cough> three car garage. |
04-22-2014, 10:59 PM | #259 |
Looks good, glad to see your getting back into it.....nice to have your own workshop. I think youll like the fast system, have you logged into their website?
04-23-2014, 07:39 PM | #260 | |
Spent quite a bit of time on cpgnation researching the FAST system. I'm sure I'll be on there more once I get the motor turned over. |
04-23-2014, 10:50 PM | #261 | |
Seems like grounds are the main culprit on the install, keep us posted on the install....
04-23-2014, 11:44 PM | #262 |
Agreed. Running the wiring and grounds cleanly are crucial.
03-04-2015, 12:20 AM | #263 |
I've made a little progress.... I'm just gonna leave this here.
https://www.youtube.com/watch?v=cspt2YIx69M |
03-04-2015, 07:34 AM | #264 |
Awesome work AJ, motor sounds great....glad for ya
03-14-2015, 11:42 AM | #265 |
truck sounds awesome, glad to see you back on track with your project!
03-15-2015, 09:56 AM | #266 |
2WD Jimmy
Nothing sounds like a big block AJ.
03-15-2015, 03:09 PM | #267 |
Thanks guys. Haven't done the exhaust yet. It's open headers and crazy loud. Still working through a few bugs and leaks here and there. Nothing unexpected on a new engine build.
03-22-2015, 05:54 PM | #268 |
Congrats on your build progress AJ.
If I may ask, what made you choose the FAST 2.0 over the base model?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
03-22-2015, 10:02 PM | #269 |
More HP support. Better interface (handheld). Timing control.
03-23-2015, 11:52 AM | #270 |
I envy your garage! Motor looks sick
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
09-13-2015, 11:53 AM | #271 |
9/13/15 - Been a while since I've done an update...
Got it to here: Put in some of this: Did a few of these: Built a new exhaust: Put a couple hundred miles around town. Loaded up for a roadtrip with dad and the dog Had a to get a ride home. Lost 3rd and 4th gear in the tranny Tore it back down for repairs and upgrades |
09-13-2015, 01:00 PM | #272 |
Why did you take the roll bar out?
09-13-2015, 09:37 PM | #273 |
It was nothing more than a show bar. PO had painted the silver OVER chrome. I'll bend up a Hickey style bar at some point.
09-20-2015, 06:53 PM | #274 |
Bummer about the trans. Looks like it picked a good spot to break down tho. Nothing like Buccee's!
09-21-2015, 09:56 AM | #275 |
Sorry about the trans. Got a question about the heater hoses, what fittings did use for the heater box. Did you braze a fitting on, or use a compression fitting?
Exhaust looks sweet
