Old 05-24-2011, 09:00 PM   #251
exoticmetalworx
exoticmetalworx's Avatar
Re: my build thread
im about to turn my own set of dimple dies my self what stock did u use? i want to know if i could dimple 3/16 and how easy or hard that would be what thicknesses have you tried? cool build
exoticmetalworx is offline   Reply With Quote
Old 05-24-2011, 10:09 PM   #252
sams60gmc
sams60gmc's Avatar
Re: my build thread
I turned them out of 3'' 1045 steel.
I will try some 3/16 tomorrow. Should work just fine.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 05-24-2011, 10:32 PM   #253
sams60gmc
sams60gmc's Avatar
Re: my build thread
Was thinking about this, input please!
Old 05-24-2011, 11:43 PM   #254
exoticmetalworx
Re: my build thread
it kinda looks like bricks w the lines betwwen the holes but i see where ur heading i dig it if u coud figure out how to roll the corner that would be sick
Old 05-24-2011, 11:44 PM   #255
exoticmetalworx
Re: my build thread
oh do you think if i turned them out of aluminum they wouldnt work?
Old 05-25-2011, 12:25 AM   #256
Captainfab
60-66 Nut
Re: my build thread
If you would like a little more insight into making dimple dies, check out this thread.....
http://www.offroadfabnet.com/forums/...de+dimple+dies
Quite a bit of good useful info in there.
There are a few other threads on the OFN showing dimpled holes.
Old 05-25-2011, 09:01 PM   #257
exoticmetalworx
Re: my build thread
awsome
Old 05-26-2011, 10:26 PM   #258
sams60gmc
sams60gmc's Avatar
Re: my build thread
I built some fire wall mounted hood hinges today kinda like the Porterbuilt ones and after a trip to the Immediate Care to get metal scraped out of my eye and a new Tetnus shot I think it would have been cheaper and less painful to have just bought them lol.
Old 05-26-2011, 10:30 PM   #259
exoticmetalworx
Re: my build thread
oh dude that sux i need some wood to knock on!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 05-29-2011, 02:10 PM   #260
sams60gmc
sams60gmc's Avatar
Re: my build thread
Those holes will be dimple die'd The straight lines wont be there. I dunno having some fabricators block trying to figure out how to make them look good.
Old 05-29-2011, 02:11 PM   #261
sams60gmc
sams60gmc's Avatar
Re: my build thread
I think aluminum would be fine if you didn't go too thick on the material you were dimpling.
Old 05-29-2011, 02:12 PM   #262
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thanks Captain!
Old 06-02-2011, 08:01 PM   #263
sams60gmc
sams60gmc's Avatar
Re: my build thread
I finished building the hood hinges today, I'll test fit them tonight and if everything checks out I'll pull them back out for a final weld.
My hours got cut at work for a few weeks so it will be nice to have another full day to work on this thing, I'm excited for a longer weekend.
Old 06-02-2011, 09:15 PM   #264
exoticmetalworx
Re: my build thread
uh what do you think your building that truck for your self where are our pictures sam!
Old 06-02-2011, 11:52 PM   #265
sams60gmc
sams60gmc's Avatar
Re: my build thread
Pics when done
Old 06-04-2011, 10:09 PM   #266
sams60gmc
sams60gmc's Avatar
Re: my build thread
Hood hinges need a little more trimming then a final weld, but basically done. What a PITA those were to make.
Also ran the rear brake lines today.
Old 06-04-2011, 10:14 PM   #267
exoticmetalworx
Re: my build thread
awsome i dont even want to start on mine but ill have to soonner than later unless i do no hood lol i just want to suicide it so i dont want to do it 2x
Old 06-10-2011, 11:43 PM   #268
sams60gmc
sams60gmc's Avatar
Re: my build thread
Tank bracket, came out OK, I'll run it until the gap where its mitered gets the best of me. Should have welded it then drilled it.
Old 07-02-2011, 12:40 PM   #269
sams60gmc
sams60gmc's Avatar
Re: my build thread
Well I've been super busy with side projects lately, building parts for a guys rat rod he is building, and steering parts for a buddies Toyota crawler on 2.5 ton rockwells and I just finished up a set of dimple dies but I'm starting to get back to work on this thing, I towed my truck down to my shop so I could finally start getting some work done on it. I cut the mounts off of my air tank and lowered them, then got it mounted, also got some more work done on that damned drip rail. Might go to my buddies house this weekend and pick up my motor then start installing that.
I also noticed that my truck would not lay the rocker flat, so after some investigation I noticed it was laying on the front body mounts, so it would either let the front of the cab touch the ground or the rear, so those will be modified to get it to lay flat, I'm also debating on cutting off the lower pinch weld.
No pictures of the work just some randoms I thought were cool.
Old 07-02-2011, 12:42 PM   #270
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: my build thread
Nice build..looks great...I was just giving some thought to what i wanted to do with my hood...I think i am going to loose my inner fenders or what little of them i was using anyway...lol
keep up the good work dude it really looks great
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 07-02-2011, 12:48 PM   #271
sams60gmc
sams60gmc's Avatar
Re: my build thread
Thanks man I appreciate that.
Old 07-24-2011, 01:41 AM   #272
sams60gmc
sams60gmc's Avatar
Re: my build thread
Been getting a little work done on this thing lately. Made up a bunch of fish plates for the rear end and got those welded on. Also welded up my front tubs and got them smoothed out. Picked up my motor from my co workers house and now that is ready to go in this week.
Old 07-24-2011, 11:06 PM   #273
baggedout81
Re: my build thread
Sick build bro.
Digging those upper arms.Powder coating gets addicting once you start.
Just one word of advise.Add a water trap between that viair compressor an the tank.Had a buddy back in the day we bagged his dime an used those paddle gauges.He didnt have water traps so all the moisture sits in the bottom of the tank an gets nasty an smells.Trust me you dont want that smell inside the cab when your cruising around.
Another thing (speaking of moisture) i'd suggest welding a bung in at the lowest point of the tank.Then run what ever air line you have lying around to a ball valve to where w you can reach it.Then after driving just crack it open a bit pshhhh there goes what ever moisture/water that go by your trap.
baggedout81 is offline   Reply With Quote
Old 07-25-2011, 02:27 AM   #274
sams60gmc
sams60gmc's Avatar
Re: my build thread
Originally Posted by baggedout81 View Post
Sick build bro.
Thanks man. The tank has a petcock on the bottom that I open up all the time to drain the system.
Old 07-25-2011, 02:56 AM   #275
baggedout81
Re: my build thread
cool cool. running it to a ball valve will make it easier on ya tho.99% of the ball balves i've seen are rated to 300psi.Just sain to to make it easier on ya
