08-01-2009, 01:18 PM | #251 |
Re: Shrunken66Stroker's build thread.
If you start messing with strippers you will get burned. You definitely need to cover up.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
08-09-2009, 11:40 PM | #252 |
Ok, I started back to work on the truck a little in the garage. I'm still a bit sore from the accident- physical therapy three times a week for six weeks. It's a PITA but my back should be fine after it's all through.
I hooked up the Mar-k tailgate hinges and the stealth latches this weekend. I did my best to do a step by step with the pictures since there are some deviations from the vague directions in both kits. I started with the hinges and immediately the directions went out the window. Step 1 is to unbolt the tailgate chain mount from the bedside facing the tailgate. Well mine weren't bolted in, they were plug welded. I drilled them out, lined up the new ones and plug welded them in. I did the relief cuts on the gate so they would tuck in and they were done.
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 08-09-2009 at 11:40 PM. |
08-09-2009, 11:52 PM | #253 |
I screwed that last post up so here's some more pics and the rest of the install.
I realized when I was measuring out the stealth latches that they weren't going to be long enough to reach where they were supposed to. I had to hammer out a plate and weld up so the latch would have a housing. I welded a stud to it so I could hold it in place while I tack welded it. Repeated on the other side. The instructions showed a step side bed and it wasn't even close to the same install. After I got the latches into the tailgate I closed it and pulled them and let go a few times. It made enough of a mark to where I could use it as a punch and know where to drill. I drilled the holes out, ground the welds down and put the rubber grommet on. I plugged the holes where the chains mounted on and I was done. Quite a bit of finagling for a straight forward conversion.
08-10-2009, 12:38 AM | #254 |
SSN 706
Nice work. I've seen those before did'nt know it was a kit. You missed a little paint.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 08-10-2009 at 12:39 AM. |
08-10-2009, 12:48 AM | #255 |
They're two separate kits but you need both to replace the chain functions. Ok so it's not 100% bare metal but damn close. There might be one or two other spots with paint on them too. Don't tell anybody else.
08-10-2009, 12:51 AM | #256 |
SSN 706
Ya I did'nt think about the piece that holds the gate up.
08-10-2009, 05:35 AM | #257 |
Check The Champ, Demonstrator
I used a Industrial Chemical stripper to remove the paint from a buddy's car. Even though I had Industrial rubber gloves on, I lost two layers of skin on the palms of my hands. Second degree chemical burns. My hands do not callus anymore and are sensitive to heat and cold. Please be careful when using this stuff.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
08-10-2009, 07:17 AM | #258 |
Registerd User
Trucks lookin good. I agree on the mar-k instructions. It's easier to figure it out than to fallow those things. I know you feel good about seeing it roll out of the garage like that. The only thing better is to drive it out.
08-10-2009, 08:49 AM | #259 | |
08-10-2009, 08:54 AM | #260 |
Soon the day will come when the shorty will exit the garage under it's own power. Congrats on that TOTM deal. You got my vote.
08-11-2009, 10:28 AM | #261 |
On those kits for the tailgate links and hidden latches, what was the problem with the instructions? I'd like to know because I wrote them. If I'm not getting the message across then I need to do it differently. I have only seen a couple of trucks with those chain attaching pieces welded in from the factory instead of bolted. Can not explain that one. Maybe a specific year or build plant? Anyway, any suggestions or comments would be appreciated.
08-11-2009, 10:44 AM | #262 |
Looks good, Shrunken66Stroker. I haven't ever used any of Mar-K's stuff yet, but that's customer service right there.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 08-11-2009 at 10:46 AM. |
08-11-2009, 10:45 AM | #263 |
Daring to be Different
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
08-11-2009, 12:20 PM | #264 | |
Registerd User
08-11-2009, 01:04 PM | #265 |
SSN 706
Sounds like a good guy. Maybe if your nice to him he'll come over and help you. Now that would be service.
08-11-2009, 06:29 PM | #266 |
Thanks for the kind words guys. I do find it difficult to write these instructions because I am part of the design team for these products. This includes initial design, prototyping, finished goods and the final, instruction writing. Knowing so much about the items, maybe I take some things for granted when writing the instructions. I will try to look at those a different way in the future.
08-11-2009, 06:38 PM | #267 | |
SSN 706
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 08-11-2009 at 06:40 PM. |
08-11-2009, 06:50 PM | #268 |
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT Last edited by Strodder; 08-11-2009 at 06:50 PM. |
08-11-2009, 09:13 PM | #269 | |
08-11-2009, 09:16 PM | #270 |
I have just enough sense to cut my bed down.
08-11-2009, 09:26 PM | #271 |
It's only a 15hr drive from OK. I'm done anyway I just wish it didn't take the better part of a whole day for the hinge and latch.
08-12-2009, 07:29 AM | #272 | |
Registerd User
08-12-2009, 09:21 AM | #273 |
I'll try to be more clear about this one. It actually wasn't the trunions. It was the arms that hold the tailgate level when you let it down, what ever the hell those are called. But now that you mention trunions... I had to offset them in the middle about a 1/16 to get them the tailgate to line up with the bedsides at the top. There was no adjustment left in them so I had no choice and the mounting holes are so close to the edge there's no material on them to ream out. I had to lock the round part down, take it out and offset it to one side. These are from Mar-k. I'd like a little more material on both sides of the mounting hole if you're still listening James.
08-12-2009, 09:37 AM | #274 | |
08-12-2009, 10:11 AM | #275 |
This part has been recently re-designed to match the original bracket.
Tags |
1966, bagged, disc, long to short, stroker |
