Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 03-31-2010, 09:59 PM   #251
VA72C10
VA72C10
VA72C10's Avatar
Re: 1972 Blazer - 'Bullet' Project
nice progress. Did you chemical strip the fenders?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-31-2010, 10:13 PM   #252
lks dcvn
lks dcvn's Avatar
Nope - I used to use the 3M strip disks like the one below.
I used to find 5 piece lots on ebay for pretty cheap so I bought 2 sets [10 total] and I am on my last one. I contacted the person that I used to buy from and they said that they were no longer able to get them - so I was at HF today and found that they have a similar product - for $4.99 each.
I picked one up being skeptical - but the one I got today worked better - yes something from HF worked better than a 3M product. It took me 20 mins to strip two fenders and the door to bare metal.
I have plenty of the 20% coupons for HF for when I go there - I wonder if I can get them to sell me a case for 1 SKU and get the discount - since the coupon is only good for 1 item.
lks dcvn is offline   Reply With Quote
Old 04-01-2010, 05:55 AM   #253
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Nice progress Tom!!
Hey, a friend of mine owns a machine shop and what he does for stripped/rusted in bolts is welds an allen wrench to the stripped head. The heat breaks it free and obviously the wrench gives you a handle to spin it right out. Just a thought.
When you get that thing together, you need to take it for a drive up to Michigan!
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 04-01-2010, 07:51 PM   #254
lks dcvn
lks dcvn's Avatar
on heading North when done! When is the cookout this year Tim?
Did a crap load on the tub today.
Ground it all down to bare metal and coated it with rust prevention paint - which I did some digging on - I can do my body work over this - just sand the area in question with 220 grit and then apply filler, then another coat of the rust paint - and then primer/BC/CC.
Pix...
Old 04-01-2010, 07:55 PM   #255
lks dcvn
lks dcvn's Avatar
Pix painted...
I got a few during shots. I started on the rough spots and worked out from there - most of the tub was to bare metal on the outside.
I did not do the back yet as I will need to swap in a better tailgate from my stash.
I will inspect this over the weekend to see what spots I will be working over. You can see a crease in the pass door, in the lower quarters, etc. - I will see if I can do some metal bumping on them before doing any filler work...
I need to patch the pass front quarter and replace the driver side rear by the light - then I should be good to go to put the doors, fenders and then start doing the interior -
Old 04-01-2010, 07:56 PM   #256
VA72C10
VA72C10
VA72C10's Avatar
Looking good!
Old 04-01-2010, 08:09 PM   #257
Chevyman63
Chevyman63's Avatar
That looks great Tom!
And the cookout can be almost any time. I will get the plans started and we will see if we can get Kurt and Jim to show up.
1972 4x4 Blazer
RIP
- CLR 10/11/09
Old 04-01-2010, 10:22 PM   #258
NorCalTank
Great work..Is that rust bullet on the bedside and door?
NorCalTank is offline   Reply With Quote
Old 04-02-2010, 01:11 AM   #259
lks dcvn
lks dcvn's Avatar
Thx for the comps guys - nice to have some motivation along the way.
Rust Bullet - pretty much the same stuff - it is the Master Series Coating found at www.nomorerust.com
I just picked up 2 more quarts for other stuff I need to coat - this stuff goes a LONG way - it covers on the first coat and the second coat is added protection.
I don't have a 'long term test yet' but this truck will probably see Ohio winters when it is done - so that will be a good test.
Old 04-02-2010, 08:26 PM   #260
JUSBLAZ
JUSBLAZ's Avatar
Looks good! Take advantage of these nice days.
So hows the door? From the one picture it looks fairly clean. Was there any bad areas?
Rich
JUSBLAZ is offline   Reply With Quote
Old 04-02-2010, 09:37 PM   #261
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=
Tom Vogel is offline   Reply With Quote
Old 04-04-2010, 07:55 PM   #262
lks dcvn
lks dcvn's Avatar
It was nice outside most of the weekend so I did some work in the driveway - cleaning up the 'new' seats, cleaning out the rust and grinding dust from the past 4 months...yuck.
Here are a few pix of the rust in the back [right around wheel wells - I take it these [wheel tubs] are just bolted in and I can clean that rust up and then bolt the wells back in with some seam sealer...can anybody confirm this?
There is also some minor rust in the floor near the tailgate that I will need to deal with as well...
I also mocked up the passenger fender while I was out there to see how it looked all one color -
Old 04-04-2010, 08:04 PM   #263
lks dcvn
lks dcvn's Avatar
Today I got the front of the rear quarter welded in - it will need a skim coat of filler to get it really dialed in though...
I also filled all the trim holes on the passenger side while I had the welder out again.
That should be the last of the welding except for the windshield frame replacement - and I might leave that to a professional since it involves some tolerances for a w/s that I would hate to screw up and have to redo.
We will see though when I take it to get an estimate - I might faint at the price and tackle it myself.
I need to get the passenger door moved back a bit in the door opening - I will likely do that when I do both doors for the final fitment once I have the driver door on.
Old 04-04-2010, 08:24 PM   #264
VA72C10
VA72C10
VA72C10's Avatar
Nice progress...glad to see you moving right along!
Have you given yourself a timeframe for paint?
Old 04-05-2010, 09:39 AM   #265
lks dcvn
lks dcvn's Avatar
No time frame on paint yet...I will be staying with the Blue to make it easier. I don't want to take the whole thing apart - I just want it to be solid and be dependable.
No more major welding now - just fixing the inside of the bed and the area around the rear tubs...
Once the minor welding is done - I will start the body work on it for the questionable areas [crease on pass door, B pillar areas, etc.].
There isn't any major damage on the body - just some bumps and bruises along the way that will need to be fixed.
Old 04-06-2010, 04:44 PM   #266
68 TT
Still plays with trucks
68 TT's Avatar
Great progress. Keep at it.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-08-2010, 11:32 AM   #267
1956cameo
1956cameo's Avatar
It's looking great!
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 04-10-2010, 09:50 PM   #268
lks dcvn
lks dcvn's Avatar
Thanks guys. I haven't done anything with the Blazer for about a week. The vacation has been mentally refreshing for this project. I stared at it almost every day for many months...so spending some time working on other projects has been nice.
Now that it has been warm - I got the yard stuff done, house stuff done and working on odds and ends that I have been putting off for when the sun gets here.
Once I get the part I need for the door [thanks again 1949gmc!]- I will hang the driver door again and be putting more time into getting it wrapped up -
Old 04-11-2010, 11:01 PM   #269
BLUE THUNDER
BLUE THUNDER's Avatar
Did alot of things to the house and yard this weekend too. Not much on the Blazer. House looks good, well, at least the outside does. Now I can put the stereo in the Blazer and maybe the two rear tires. The bullet is looking good.
BLUE THUNDER is offline   Reply With Quote
Old 04-13-2010, 11:31 AM   #270
lks dcvn
lks dcvn's Avatar
Got the door latch last night [from 1949GMC - who was nice enough to mail me what I needed for FREE - you rock Ray!] and then it started to rain so I had to head inside.
Now that I have the Impala SS and the 69 Blazer back from storage - they have run of the garage - so I am out in the elements. See why I wanted to get the major welding work done on the body...
I want to get the driver door ready [paint-wise] to go on the inside before I hang it - so I have some work to do first...
I have a ton of little odds and ends to do on this thing - including checking out the rust in the bed/wheel tubs [I keep putting it off].
Old 04-14-2010, 09:59 PM   #271
lks dcvn
lks dcvn's Avatar
OK - got something done (finally)
I got that clean blazer tub, but there were no bolts that came with it to assemble a truck while it waits it's turn in the project rotation so I ordered a box o bolts from Randy [teeitup] and they showed up last night.
I figured I would clean them up a bit so I grabbed the bolts, a gallon or so of simple green and a spare bucket that I had.
Bolts went in and then they were covered with roughly a gallon [I had two partial jugs] of SG and I will let them sit until the weekend and see how the bolts turn out.
I also got the hood cleaned up today. It has some surface rust that was more annoying that damaging - it was rough to the touch, but one swipe of the strip disk and it was smooth as can be.
I used the HF strip disk on the top and then painted it with the rust paint [which I forgot to get pix of when I got done] - duh.
There is some minor damage on the hood, but not enough to stop me from using it. I will see if I can hammer it out to reduce filler consumption.
Old 04-15-2010, 08:45 PM   #272
lks dcvn
lks dcvn's Avatar
Got some more done today after work, but only got one pic.
I started the process of removing the rear wheel wells - let me tell you - that sucks...
I tried to loosen two of them and then remembered that somebody said just to sacrifice the bolts and to tighten them until the bolt snapped so you can just take them out that way...well it worked for the most part.
I have 3-4 bolts per side left that I will need to use a cut off wheel with, but that shouldn't take that long to do.
I surveyed the rust on the inside and there is a spot near the gas tank filler tube in the bed that might need some more time to resolve. The inner bedside is weak there and I might be able to get the wheel well out, clean the metal and then just add a larger bead of seam sealer, but I won't know until I can get in there and see.
I also would like to talk to the genius at GM that made the torsion box cover one of the bolts on each side [rear middle bolt] from the underside...could not get at it to tighten it off...guess it will get cut off as well.
I did snap a picture of the hood now that it is coated though...looks a hell of a lot better than it did earlier this week [Before and After Shots] This pic is with one coat on the whole thing (that stuff really lays out thick). The way it was sitting yesterday I couldn't get to a few spots so I rotated it a bit to get those missed spots today.
I will likely add one more coat to the whole thing since it will see the elements the most.
Some minor body work to do on it - and then it will be bolted on the truck.
Total time to get to this point on the hood:
~30 mins to strip it
~2 mins cleaning it up
~2 mins wax and grease remover
~5 mins drying time
~20 mins painting with rust sealant
About an hour to clean up the hood yesterday and then another 20 mins or so to finish a few spots today
I am looking forward to seeing how the body work will be over the top of this stuff - might go well - might not - we will see. 220 grit, body work, another layer of rust sealant, etc.
Old 04-15-2010, 08:58 PM   #273
VA72C10
VA72C10
VA72C10's Avatar
keep up the good work
Old 04-16-2010, 12:18 PM   #274
OldCreek
OldCreek's Avatar
Take all of your clean bolts and then push them through a piece of cardboard. Then, you can hit the heads with a little black spray paint and make them look new.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 04-18-2010, 02:51 AM   #275
BLUE THUNDER
looking good Tom.
