Old 03-05-2012, 01:34 AM   #251
Meatman
Meatman's Avatar
Re: Project No-buck!
Lifters keep cam from walking out. Only roller motors have cam retainer plate. Id say stick with same cam unless your after more hp. Breaking in new cam is a pita.
Fidlers is the best in town imo. Hes always done great work for me. Hes cheap and he knows his stuff, especially small block chevy. He knows alot about the LSX stuff too.
If it was me.....Id leave the shortblock the way it was if it all looks good. Throw in an oil pump and timing chain. If lifters all look good, keep same cam. Send heads to fidlers, have them cleaned, checked and reassembled. He will check all the springs to make sure there are no weak or bad ones. Pickup a good gasket kit and call it a day.
Then you can have a good solid motor but no major concerns like seating in rings or breaking in the cam etc.
If you want simple and reliable you've got it. All cast iron TBI small block chevy. I love the LS motors, but cant beat the simplicity of a TBI and the tried and true gen 1 SBC
Daily-94 K2500 350 5spd extended cab longbox
Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack.
Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881
My 01 TA and 88 Formula hide in the garage. :-)
Meatman is offline   Reply With Quote
Old 03-05-2012, 10:28 AM   #252
Ackattack
Ackattack's Avatar
That's what I was thinking about the cam, but just wanted to make sure. I'll give Fidlers a call.
The reliability and relatively good fuel economy is why I went with the TBI engine. So far it hasn't worked out so well, but I think once I get it put back together, I'll be there. [I've also actually thought about trying to fine a 305 TBI 5 speed third gen camaro as a daily driver too, but No-buck is cooler]
Ackattack is offline   Reply With Quote
Old 03-05-2012, 12:18 PM   #253
mcbassin
Still Learning
mcbassin's Avatar
Hang in there, you will get the bugs worked out. If you have to dump a lot of cash into the tbi you may consider a "cheap" LS. I bet you could pick up a 4.8 pretty cheap. Bone stock like mine it's right at 275 HP. Around here they are getting plentiful. Low buck is way cooler too.
Good luck!
mcbassin is offline   Reply With Quote
Old 03-17-2012, 12:36 AM   #254
68 TT
Still plays with trucks
68 TT's Avatar
For what a decent condition third gen will run you I would bet you could drop a 5.3 into no-buck especially since you just did the swap to your other truck.
You would get about the same gas mileage but have a much cooler vehicle as a commuter vehicle. The truck is probably much less expensive to insure too.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-18-2012, 07:04 PM   #255
Ackattack
Ackattack's Avatar
Got the engine put together and set the engine down the truck. Normally when I put an engine in (since this is the 3rd time I've installed an engine in No-buck) it takes a little bit of work to get the clutch splines lined up with the input shaft of the tranny, the dowls of the block, etc. Today I did it by myself in about 10 min. Pretty good in my book.
I still have the motor mount bolts to put in, and a lot of more hooking stuff up before its ready to drive, but its a big step getting the engine in.
Old 03-18-2012, 07:52 PM   #256
Old 03-18-2012, 09:03 PM   #257
mcbassin
Still Learning
mcbassin's Avatar
That was a fast install. What did you find out about the motor? Heads okay?
Old 03-18-2012, 10:02 PM   #258
Ackattack
Ackattack's Avatar
Blown headgasket, missing about 1" of material right between the #3 and 5 cylinders. Everything else looked perfectly fine.
I replaced the timing chain, oil pump, valve seals and valve springs while I had it apart. I also cleaned the intake and repainted it so it looks a little prettier. I also got a new throwout bearing.
The heads looked fine, the cam and lifters all looked fine.
Hopefully I'll be driving it by next weekend.
Old 03-18-2012, 10:28 PM   #259
mcbassin
Still Learning
mcbassin's Avatar
Sounds like you will be in business in no time. What's the reason for replacing the valve springs. Are these prone to failure? Just curious?
Old 03-19-2012, 10:07 AM   #260
Ackattack
Ackattack's Avatar
Just figured I was in there, had the heads disassembled so why not.
Maybe I'm just used to high performance LS engines where back shortly after they came out people were breaking valve springs when they put in "big" cams. [Now days I think they've developed the after market springs and now have much larger cams and I don't think its as much of a problem]
Old 03-22-2012, 11:54 AM   #261
Ackattack
Ackattack's Avatar
It LIVES!!!
Got the truck fired up last night about 11pm. Didn't notice any leaks and once I got the timing dialed in it idled pretty good. Got a few loose ends to tie up before I take her for a spin.
Old 03-22-2012, 02:12 PM   #262
mcbassin
Still Learning
mcbassin's Avatar
It LIVES!!!
Congratulations on getting her running again!
Old 03-22-2012, 02:22 PM   #263
MILLER TIME
how much do you have to take out of the bed front and back to shorten it right?
Doin Work! Little At A Time....
MILLER TIME is offline   Reply With Quote
Old 03-22-2012, 02:25 PM   #264
Ackattack
Ackattack's Avatar
12" in front, 8" in back.
The 12" from the front comes out from under the cab, so you have to move the rear cab mount back 12" also. Do a search, there is a couple of good write ups....I think Rockcln (sp) did a real good one.
Old 03-22-2012, 02:28 PM   #265
MILLER TIME
I appreciate it, Im having a hard time finding a short fleetside bed for mine. I may end up doing that. Was it tough in your opinion?
Old 03-22-2012, 04:36 PM   #266
Ackattack
Ackattack's Avatar
Not really, but I wasn't going for show quality either. It did take some body work to make it look decent and since mine is wood bed, it didn't take as much welding.
Old 03-22-2012, 06:57 PM   #267
Meatman
Meatman's Avatar
Cool! You coming to track tomorrow nite? Its supposed to be totally free to get in!
Old 03-22-2012, 09:42 PM   #268
Ackattack
Ackattack's Avatar
I heard that. Don't know if I'll make it, we have family in town and have 36 people coming over on Sat. for my son's B-day party.
Old 03-24-2012, 12:31 AM   #269
Meatman
Meatman's Avatar
Track was packed! I only got to run 3 times it was so busy. Set a new best though!
Old 03-25-2012, 12:09 AM   #270
Ackattack
Ackattack's Avatar
So I drove the truck to the store this morning and had to get a jump start and barely made it home. So I went and got a new alternator and charged the battery. Put the new alternator and I was getting 14 volts. Then I headed out for the local cruise in. Well the alternator died on the way there. I was parked at a parts store and the tested it to confirm. So I left the truck there and will have to go get a new alternator tomorrow. The store I was at didn't have one on the shelf.
Looks like I need to wire in a resistor into the circuit to prevent killing them.
Other than the charging issues the truck seems to be running great.
Old 03-25-2012, 03:49 PM   #271
Ackattack
Ackattack's Avatar
I got the new alternator installed and wired up and got the truck home! I took the highway home and seems to run just fine out on the highway and might be a little quieter
Oh, I forgot to mention. On the way to the cruise in last night, I drag raced a Ferrari. It wasn't much of a competition I think this truck and a Ferrari are about polar opposites on the car spectrum.
Old 03-25-2012, 04:21 PM   #272
bigguy69
dazed and confused
bigguy69's Avatar
I would still be happier in the truck
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 03-25-2012, 05:15 PM   #273
Did you get the resistor piece in so your alternator won't go out again?
Old 03-25-2012, 05:35 PM   #274
Ackattack
Ackattack's Avatar
I put in a light bulb (as someone suggested) but its resistance was only like 5ohms. Someone else suggests a resister that was like 30-60 ohms, so I'll probably swing by radio shack and get a resistor.
The alternator was still putting out 14v when I got home though. (~10 miles)
Old 03-25-2012, 08:57 PM   #275
Tinkermc
and the saga continues
Tinkermc is offline   Reply With Quote
