Old 06-03-2010, 03:52 PM   #251
SCOTI
SCOTI's Avatar
Re: Project: Recycle
Originally Posted by 8mpg View Post
Im a fan of vintage style aftermarket gauges. I really like the Autometer Street rod gauge sets. I think I will be using the Antique beige gauges in my truck.
Stewart Warner 'Deluxe' series for my 64.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-03-2010, 08:19 PM   #252
SCOTI
SCOTI's Avatar
Loaded the big window swap pics.
Slice & dice (No, that's not me in the pic).
Small skin out.
Large skin in to test fit & trim.
Stripped & initial sealer on the large window skin....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2010, 08:31 PM   #253
SCOTI
SCOTI's Avatar
Clean-up the inside surface of the OE outer skin in preparation for the install.
One final test fit to make sure every place that needs to be bare steel is for excellent adhesion.
Start the expert application of the panel bond adhesive (no, I didn't do it).
Continue the expert application of the panel bond adhesive .
Bunch of clamps to keep the new big window skin where we want it....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2010, 08:34 PM   #254
SCOTI
SCOTI's Avatar
Once the panel adhesive cures, the clamps are removed & the over-lapping OE small window skin is trimmed flush w/the new inner big window skin....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-03-2010, 10:25 PM   #255
Painter D
Painter D's Avatar
I don't know how you've had this thread goin on for 6 mos., and I just now found it. Guess I'm not very observant. Your work looks killer so far ,keep it up. The BBW window conversion will definately be worth it after it's all said and done, that was an excellent decision to do that. I'll try to come check it out in person sometime soon.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 06-03-2010, 10:51 PM   #256
SCOTI
SCOTI's Avatar
Thank you sir! I'm ready to get this thing rollin' so we can do the Kellers deal again. Although, next to yours..... it will really look patina.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2010, 12:42 AM   #257
Frizzle Fry
Frizzle Fry's Avatar
All adhesive and no welds? I thought I would at least weld at the door edges. Not knockin it. I bet it'll be fine.
Frizzle Fry is offline   Reply With Quote
Old 06-04-2010, 12:48 AM   #258
SCOTI
SCOTI's Avatar
Tacks for the corners & edges; adhesive everywhere else.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2010, 10:00 AM   #259
Jonboy
Slots go on anything!
That looks tons better, Scoti.
Maybe an engine turned insert around the gauges would look kinda period, too?
1974 Jimmy- 5.3/4L80e/NP241
Old 06-04-2010, 10:11 AM   #260
N2TRUX
Happy to be here
N2TRUX's Avatar
I love the BBW conversion. It's going to really bring this project forward. Aftermarket gauges....mmmm, not so much. This thing deserves more than that.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-04-2010, 10:21 AM   #261
SCOTI
SCOTI's Avatar
Look @ it this way..... Would you trust the project w/$400 45yr old gauges or $400 new '60's style gauges? Would it be better to know your actual voltage or guess what that handy (?) ampmeter is telling you? What about when the temp needle 1/2 way between H & C (or would you prefer to know you're @ 190°F)? Pick your poison.
I know our good firend N2billet faced a similar decision & opted for new gauges. I'm open to alternative suggestions....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-04-2010, 06:27 PM   #262
darkhorse970
darkhorse970's Avatar
BBW looks great! I am convinced, and I have a donor cab waiting for me to haul it home. As for the gauges, I agree with you that the aftermarket "old style" gauges with engine turned panel will give you more accurate readings, with an old rod look...and if you're happy with them, thats what matters.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 06-04-2010, 06:34 PM   #263
lakeroadster
I went with new aftermarket gauges. The stock cluster on our trucks is ok visually but just as you have said I want to know actual readings for Oil Pressure, Temperature, Volts, Vacuum, Etc.
Oh, and the BBW instal was quite educational and the results are awesome. (I still like small back windows though )
Your truck mod's are an inspiration to us all!
lakeroadster is offline   Reply With Quote
Old 06-04-2010, 08:08 PM   #264
Painter D
Painter D's Avatar
If you're using the adhesive I think your using you'll have nothing to worry about, on that particular application.
Old 06-05-2010, 12:55 AM   #265
SCOTI
SCOTI's Avatar
I'm not sure if they were trying to tell each other something in this pic or if they were trying to tell me something .... Either way, 3M panel bond adhesive was used.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2010, 11:06 AM   #266
protrash64
Resistance is Futile
protrash64's Avatar
Nice job on the conversion; looks very nice.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-05-2010, 11:42 AM   #267
N2TRUX
Happy to be here
N2TRUX's Avatar
You have very valid points, I just don't like the look of aftermarket gauges in these trucks dash. Doesn't anyone restore the OEM cluster?
Articles-
"Refining Sierra"
Old 06-05-2010, 02:19 PM   #268
SCOTI
SCOTI's Avatar
I considered having a gauge cluster restored. But, that $400 cost is just a clean 'gauge' cluster w/a 'new' re-pop tach (that works w/HEI). Now add the cost of restoring the gauges on top & we're way past the $400 aftermarket option.
I'm w/you on these trucks w/aftermarket gauges. I don't care for the generic billet/ABS plastic (like Covans) set-ups but there's only so much you can do when arranging the gauges within the given space. I'm trying to find some sort of compromise.... nostalgic appearing gauges that tell me what drivetrain vitals I need to know (actual temp, actual oil psi, actual voltage).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-05-2010, 03:13 PM   #269
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Beautiful BBW conversion, much better!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-06-2010, 01:51 PM   #270
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Just read all this....great job man, all the advice you give is being put to work now....
Looking good bro...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-06-2010, 02:05 PM   #271
LILRED66
LILRED66's Avatar
Nice write-up and photo-documentation on the BBW conversion. I am going to try the 3M, #8115, Panel Bonding Adhesive. It would make the conversion a lot less labor intensive, with regards to welding, grinding & top-dressing all puddle welds around the perimeter.
A completely restored factory dash cluster with gauges is less than $400.00...including night-glow green on inside of case, zinc-coat on outside of case, non-glare black on face of gauge backing plate, alumi-blast & clear on bezel surround, vinyl gauge faces, polished lens, refinished needles, bench-tested gauges, speedo lub & reset and new lamps. We have done several of them and they look amazing when they are done properly.
You can also purchase them refurbished at:
www.bowtiebits.com
LILRED66 is offline   Reply With Quote
Old 06-06-2010, 02:21 PM   #272
joe231
joe231's Avatar
$610 plus a $60 core charge at bowtiebits
CHEVY ONLY
Old 06-06-2010, 02:27 PM   #273
SCOTI
SCOTI's Avatar
www.bowtiebits.com
The cheapest I've found the aftermarket re-pop tach kits for is $190. The average prices for clean gauge clusters is $60-100. Add in the labor for clean-up, detailing or polishing, shipping, plus the 'new' tach kit w/shipping & that's where my $400 estimate for a restored 'gauge' cluster & bezel originated. I could be slightly high (or low) on the estimate & I'm not sure on the actual condition of the gauges or what if any warranty there would be.
Let me know if you've got a smokin' deal on something.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-06-2010, 02:28 PM   #274
SCOTI
SCOTI's Avatar
Exactly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-07-2010, 12:49 PM   #275
Jonboy
www.bowtiebits.com
8115 works really well for things like this. being lazy, I also used it to fill trim holes on a '94 Buick Roadmaster I had once upon a time. It worked great. I bring this up because the trim holes in these trucks are pretty similar. It would save a ton of panel warpage if one was going to fill all of the trim holes.
