Old 01-16-2015, 11:39 PM   #251
texastrendz
Re: El Chingon
Decided to make the pinion angle adjustable at the crossmember. Got the idea front porterbuilts crossmember. Right now my pinion angle is between 3 and 4 degrees nose down. I think with the adjustable bracket I can get it close too 1 or 0. Started fabricating the brackets from 1/4 plate. Hotchkis makes something similar, I refuse to pay $280.00 for it.
texastrendz is offline   Reply With Quote
Old 01-16-2015, 11:45 PM   #252
texastrendz
Re: El Chingon
Out of the mill
Old 01-17-2015, 11:03 PM   #253
texastrendz
Re: El Chingon
Finished them this afternoon. I'm not a "Porterbuilt" welder but it will do.
Old 01-17-2015, 11:07 PM   #254
texastrendz
Re: El Chingon
Back view of one side welded and the other side next
Old 01-21-2015, 09:37 PM   #255
texastrendz
Re: El Chingon
Trailing arm mounts turned out perfect. Now I can move every aspect of the drive line. Trans angle, carrier bearing, and diff angle can now be adjusted.
Old 01-22-2015, 07:23 AM   #256
kev2809
low n' slo
kev2809's Avatar
Re: El Chingon
that turned out great nice work!
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-22-2015, 12:08 PM   #257
mcbassin
Still Learning
mcbassin's Avatar
Re: El Chingon
Nice brackets! Welds look good too.
mcbassin is offline   Reply With Quote
Old 01-22-2015, 12:27 PM   #258
Justin@EntropyRad
Justin@EntropyRad's Avatar
Re: El Chingon
love the skill involved on this
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 01-23-2015, 01:07 AM   #259
rwade
rwade's Avatar
Re: El Chingon
Why are you using the spacers between the brackets and the crossmember?
Thanks, Wade
rwade is offline   Reply With Quote
Old 01-23-2015, 10:42 AM   #260
texastrendz
Re: El Chingon
Thanks, Wade
When you use the factory trailing arms in my application it tends to pull the axle forward towards the front of the truck. These spacers will push the axle back to center it in the fender wells in the bed.
Old 01-23-2015, 10:51 AM   #261
Justin@EntropyRad
Re: El Chingon
Doesnt PB have adjustable arms?
Justin Novick
(773) 303-8251
Sales/Support
Old 01-23-2015, 11:41 AM   #262
texastrendz
Re: El Chingon
Yes he does. I'm just to cheap to buy them. I like the challenge of building and resolving my own issues. Porterbuilt makes nice products and I have used a few of them to speed my build.
Old 01-23-2015, 11:43 AM   #263
Justin@EntropyRad
Re: El Chingon
I hear ya, my buddy has them on his '70 with a 6.0...when coming on/off a freeway ramp with any sort of bump..she will shake her butt worse than a cheap stripper
Methinks they aren't adjusted evenly
Justin Novick
(773) 303-8251
Sales/Support
Old 03-01-2015, 10:12 PM   #264
texastrendz
Re: El Chingon
Carrier bearing spacer made and installed. This should get the drive line dialed in according to the porterbuilt specs
Old 03-01-2015, 10:13 PM   #265
texastrendz
Re: El Chingon
Installed
Old 03-01-2015, 10:16 PM   #266
sduckworth13
sduckworth13's Avatar
Re: El Chingon
Welding job looks great!
Scott
sduckworth13 is offline   Reply With Quote
Old 03-02-2015, 02:15 AM   #267
moggey01
Re: El Chingon
I had to shorten my trailing arms to get the wheels in the center of the bed. Just redid the crossmember.
moggey01 is offline   Reply With Quote
Old 03-02-2015, 02:18 AM   #268
moggey01
Re: El Chingon
Stoney you not far from me. I'm off Jones road.
Old 11-20-2015, 12:26 AM   #269
texastrendz
Re: El Chingon
Got it up in the air. Going to finish plumbing, steering, exhaust, and lines.
Old 11-20-2015, 12:27 AM   #270
texastrendz
Re: El Chingon
High hump going in
Old 12-13-2015, 08:19 PM   #271
texastrendz
Re: El Chingon
Bed dolly is done Time to repair the bed and make the false floor.
Old 12-13-2015, 10:12 PM   #272
BossHogg69
motor exploder
BossHogg69's Avatar
Re: El Chingon
That's a really nice bed dolly - those big tires will be nice to roll around in the shop! Pretty slick how you made it to bolt together in the middle.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-13-2015, 10:50 PM   #273
texastrendz
Re: El Chingon
Thanks, I wanted it where I can store it flat when not in use. It will be easily adjustable with a spacer having a two piece middle section.
Old 12-14-2015, 03:04 PM   #274
Hart_Rod
Hart_Rod's Avatar
Re: El Chingon
Project looks great! Are you going to need some #Chubtubz also? I'll make you a package deal on them and the hood brackets. LMK.
Hart_Rod is offline   Reply With Quote
Old 12-15-2015, 10:07 AM   #275
mcbassin
Still Learning
mcbassin's Avatar
Re: El Chingon
Very nice progress on your truck! Keep up the good work
