06-03-2010, 01:52 AM | #251 |
Gone to greener pastures
Re: What did you do to your truck today!
Tracked down an electrical problem in the tail light circuit & fixed it. No more blown fuses, at least for a while.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-03-2010, 12:47 PM | #252 |
BlahBlahBlah
Moved my truck back down the driveway a few feet so my honeys dad could get around it when he mows our yard...then I went back in and watched TV =)
06-03-2010, 03:49 PM | #253 |
today i went and picked up new outside door hamdles and driverside hinge pins
06-03-2010, 05:01 PM | #254 |
Future TOTM Winner
THAT'S WHAT I'M TALKIN BOUT!
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
06-03-2010, 06:15 PM | #255 |
What?
Just finished hand waxing the burb.
Still need to go and do the roof though.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
06-03-2010, 06:36 PM | #256 |
My Daughter, Hanna and I removed the radiator, battery tray, grill support and a bunch of hoses.
[IMG][/IMG]
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
06-03-2010, 06:44 PM | #257 |
I put on new header gaskets and went for a criuse.
I'm not as good as I once was, But I'm as good once as I ever was. |
06-03-2010, 08:58 PM | #258 |
I bought new door mirrors and weather stripping. Put the mirrors on. Didnt realize I needed adhesive to make the weather stripping stay in place.
I hate rude behavior in a man.....I won't tolerate it - Cpt Woodrow F Call (Lonesome Dove) 1968 GMC C-10 (soon to be my oldest daughters) 2001 - 1500 4x4 ext cab - 150,000 miles 2001 - 1500 Burb - 233,000 Miles (wifes ride) |
06-03-2010, 09:00 PM | #259 |
Cruzin
painted wife's rad. support yesterday, painted hood hinges today and fixed heater box come off the hook i had it on a made a quarter size hole in it after i had it together and painted
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
06-03-2010, 11:00 PM | #260 |
checked timing and pulled some vacuum advance timing and....
CRIED.... because there was water all over my carpet I have a leak under my cowl.........I have to take the whole frontend off and more to fix it........I had it apart last year when I had the fenders off and I neglected to fix it
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
06-03-2010, 11:10 PM | #261 |
I finally installed my hitch. It tucks a little deep under the bumper, but it is solid. Wired and ready to go. Now if only the engine ran...
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-03-2010, 11:31 PM | #262 |
Grandpa in the rustmobile...
american muscle where exactly is that spot at?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-03-2010, 11:32 PM | #263 |
Truck and auto performance nut
...finished getting my motor ready to pull, pulled front coil springs and most of steering.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-04-2010, 12:07 AM | #264 |
if you take off the cowl panel and look down in the cowling air vent area directly over where the heater core is you'll find it (I hope that makes sense)
I also have these spots on both sides in the channel under the hood-to-cowl seal, and directly beside the other one
06-04-2010, 12:31 PM | #265 |
English Chevy Owner
Started her up, listened to the misfire, realised I have more work to do than I thought to get her back on the road and then put the cover back on!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
06-04-2010, 07:12 PM | #266 |
Sheetmetal Psycho
Got the axle in. Shocks and adjustable panhard bar too. Still need to to the brake lines, driveshaft.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
06-04-2010, 07:33 PM | #267 |
...pulled the motor and trans...along with the front steering and front coils.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 06-04-2010 at 07:36 PM. |
06-04-2010, 07:37 PM | #268 |
What?
Waxed the roof the the burb.
06-04-2010, 08:13 PM | #269 |
Those are about the size of Rhode Island!
Well at least it feels that way when you are doing one.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 06-04-2010 at 08:14 PM. |
06-05-2010, 12:31 AM | #270 |
Changed the oil, fuel fliter and PCV valve. Finally made a spacer to raise the tranmission up and get the drivers side header pipe off of the transmission crossmember. A few more things to check tomorrow, preparing for about a 250 mile trip Sunday to Billet Proof Show in Giddings, Tx.
06-05-2010, 12:50 AM | #271 |
Painted my steering column my interior is now done other then finishing the wiring in the dash!
So much closer to my new motor and tranny ! |
06-05-2010, 09:04 AM | #272 | |
What?
yea, doing a burb with rubbing compound is like doing 3 or 4 pick ups! Plus, with my burb I need to use a ladder to do everything from the hood up. I know but after wards - so nice!
06-05-2010, 09:05 AM | #273 | |
BlahBlahBlah
06-05-2010, 11:29 AM | #274 |
Cruzin
installed 1 new fender 1 oringinal, new rad. support on my wife's 67, and put new seals in the heater box
06-05-2010, 04:41 PM | #275 |
Installed a new windshield washer pump. Moved it from inside the cab to the firewall. NOW it will pass inspection...
