Old 07-04-2012, 11:47 AM   #251
Str8-6-68
Str8-6-68's Avatar
Re: maxxy's 81 bagged c10 build
maxxxy great build man, awesome job on the front x member. do you want to make my front x member that awesome.
12ram3500 HS mm, FP 5" tbe, SB cai, 2.5" up, 35s on 20s. SOLD 02ram2500 twin turbo, built 47re, sticks & studs : SIKDZL -youtube.
68gmc1500 soon to be: shortbox, ppumped 24valve, s467.7, dap 300s, H2O/Air intecooled, meth controlled, 47re, 14bolt, 2wd.
Str8-6-68 is offline   Reply With Quote
Old 07-04-2012, 12:03 PM   #252
maxxxy
maxxxy's Avatar
To be honest, I love the way the crossmember turned out, but I'm still runnin into issues with getting the steering all tied up. If I were to do it again, I'd probably just do a small z instead of the section crossmember. Thank you for the compliment though!
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 07-31-2012, 11:59 AM   #253
made2drag
made2drag's Avatar
any progress pics? love your truck
made2drag is offline   Reply With Quote
Old 08-03-2012, 01:06 AM   #254
maxxxy
maxxxy's Avatar
I haven't got much done at all the last couple months. I've taken on a full time 55-60hour/week job. Working sucks. I don't how you "mature" people put up with it.
Plus, I've acquired a lady friend, who takes up all the rest of my waking time. Lol.*
Well in a slight update, I have painted most of my rear frame (behind cab). (no pictures)
And then I finally started tackling my steering today. Hopefully I can finish it in the next day or two.*
Since I sectioned my crossmember 1.25" I am also raising my steering 1.25". On the passenger side was easy, just redrill holes 1.25 higher. But on the drivers side, where the box bolts to, the frame is a weird shape.
So I'm cutting out this section
And moving it up the matching 1.25".*
Max
Max's bagged 81
Old 08-06-2012, 01:07 AM   #255
maxxxy
maxxxy's Avatar
this is the piece tacked in place.
This is an above view showing that stock steering shaft will work.*
It's since been welded and I'm making a filler piece for the bottom. *Then I have to cut notches for the tie rods. NOTE: I did have to still notch the drivers control arm.
More to come...
Max
Max's bagged 81
Old 08-06-2012, 04:58 AM   #256
CuRtdOgG
CuRtdOgG's Avatar
Lookin good dude!
CuRtdOgG is offline   Reply With Quote
Old 08-31-2012, 11:02 AM   #257
made2drag
made2drag's Avatar
love it. i still have to notch my drivers control arm too
Old 09-14-2012, 11:09 AM   #258
truckzilla
truckzilla's Avatar
Any updates Max or has that lady friend turned into a full time project in itself?
truckzilla is offline   Reply With Quote
Old 09-14-2012, 01:49 PM   #259
made2drag
made2drag's Avatar
i love how you left the original bottom peice of the frame to keep the contour right. i dont think ive ever seen anyone do that. its going to look great once you fill the gap!
Old 09-22-2012, 03:46 PM   #260
maxxxy
maxxxy's Avatar
I'm going to end up having to notch the bottom for steering arm clearance so I cant keep the contour completely. :/
Its not the lady friend thats keeping me from the truck, its school. haha
I started my first year at University of Oklahoma! I just got no time for fun!
Max
Max's bagged 81
Old 09-22-2012, 08:47 PM   #261
scotts62
One day...
scotts62's Avatar
Sucks when priorities get in the way huh, believe me i know!
Scott
93 crew cab build
Project 62
Old 09-25-2012, 12:53 AM   #262
maxxxy
maxxxy's Avatar
It sucks knowing I'm so close to having it ready to drop in the motor. I guess I never uploaded this one. I'm a little farther along than this picture, but this is the most up to date photo I have for ya.
Max
Max's bagged 81
Old 09-25-2012, 10:30 AM   #263
made2drag
made2drag's Avatar
dude thats the bomb...while your messing with the steering.... take your column out and lay the face of the steering wheel on grass and gently tap the rag joint end (drill the plastic plug out first). the column shaft will collapse giving you 1 1/2 more inches of room between you and the steering wheel in the cab. i did it to mine and now when i drive it feels way more natural. dont go more than 1 1/2. im not sure if the shaft would ever slide the other way if you went too far. also if you go more than 1 1/2 then you run into issues of it not fitting right near the dash. it is amazing what the 1 1/2 inches of extra reach gives you. way worth the effort and your already half way there
Old 09-25-2012, 10:41 AM   #264
made2drag
made2drag's Avatar
but make sure it looks like it will work on your truck before collapsing.... since you would have to make sure the shaft still clears the control arm notches and anything else that isnt stock
Old 09-25-2012, 11:15 AM   #265
truckzilla
truckzilla's Avatar
Thumbs up Re: maxxy's 81 bagged c10 build
Congrats on starting school! Now we'll understand if updates come a little more slowly. That studying stuff can be a real time hog! Best of luck and keep after it!
Old 09-30-2012, 04:01 PM   #266
CuRtdOgG
CuRtdOgG's Avatar
How you been man...I really need to start making some progress on mine...just been lazy! I still need to figure oit a time to grab that seat from you.. I got mine stripped to the frame...waiting to paint it and start putting it back together and install the engine. Then I am left to fix the body and paint...and I still need wheels....I cant wait for u to get yours driveable!
Old 10-13-2012, 03:51 AM   #267
INSIDIOUS '86
INSIDIOUS '86's Avatar
Looking forward to you getting the steering stuff worked out. Planning on doing this to my other truck but I'm not going bagged just lower than the static 6-8 extreme drop. Like static 7- 9 lol. Just raise my bed 3-4 inches and c notch the rear. Get us some updates!
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-14-2012, 01:35 PM   #268
slammed427
slammed427's Avatar
Just read the build thread, great improvement all the way around. Keep it up!
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 10-16-2012, 02:01 AM   #269
maxxxy
maxxxy's Avatar
Thanks! I really appreciate it!
Yeah it sure is! I don't have time to sleep! Let alone work on this toy! Lol
I'd like to do this, but I think moving the whole steering column forward would make my angle steeper and also push the shaft down, closer to the arm, and I already can't afford to give up any clearance there.
Max
Max's bagged 81
Old 10-16-2012, 02:25 AM   #270
INSIDIOUS '86
Did you move the steering linkage up because you had to from being low or do you think a static dropped truck would get away without needing it?
Old 10-16-2012, 02:32 AM   #271
maxxxy
maxxxy's Avatar
I moved the steering assembly up because of the way I sectioned the crossmember. If I didn't move it up the same amount as the crossmember, my steering arms would hit the front of my lower control arms.
Max
Max's bagged 81
Old 10-16-2012, 01:45 PM   #272
EngineCo.1
Lookin' good!!! Keep us updated!
EngineCo.1 is offline   Reply With Quote
Old 11-22-2012, 02:56 AM   #273
maxxxy
maxxxy's Avatar
Im home for thanksgiving break!!!
Here's the steering box mount moved up with my steering arm notches welded in. Don't mind the blobby texture in the middle. I started to try to put a layer of bondo on to smooth out the grinder nicks and hammer scratches, but soon realized that part would be covered by the steering box. Lol
Since then I put together all the steering, and bolted a lot of little things back up.
Max
Max's bagged 81
Old 11-23-2012, 11:25 PM   #274
maxxxy
maxxxy's Avatar
Got the front end all buttoned up except brakes.
I'm probably going to have to slightly tub the firewall... One thing leads to another I guess.
Does anyone know what I can do to clean up the drivers side firewall and still be fully DD functional?
Max
Max's bagged 81
Old 11-23-2012, 11:33 PM   #275
maxxxy
maxxxy's Avatar
Started to get my rear end prettied up and painted. When I opened it up, I realized that I have 2.56 gears....
My truck has become kind of a collect-all of tools and random other things. Lol
Max
Max's bagged 81
1981, bagged, c10, custom, oklahoma
