12-05-2012, 10:26 AM | #251 |
Junior Member
Re: 84 GMC C2500, V12 powered
I like your "fingers, truck" sayin'!
Each time I read it, I smile. Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. |
12-05-2012, 09:55 PM | #252 | |
Chevy Enthusiast
I'm glad you found the source of the knock and it just was a minor problem.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
12-05-2012, 11:11 PM | #253 |
Junior Member
Hit paydirt!!
I found a new .30 piston in a neighbors shop. Now, if I can get the rings off the old one on the new one without breaking one, I'll feel like I killed a bear bare handed. Cayoterun
12-06-2012, 12:32 AM | #254 |
Glad you found it and the crank was ok. I've seen that before and it was caused by the ring end gaps being too tight. They get hot, butt together, and bind up in the bore, the ring grooves become the weak link.
'50 GMC 350 COE, 702 V-12 / 4L80E powered '71 GMC 6500, 427, 5 spd |
12-06-2012, 04:48 AM | #255 |
Junior Member
Wow! Thanks a million, LB. Learn something new everyday, regardless of age.
Should I file a bigger gap in these old rings before putting them on the new piston? If so, would a small file be the best way? I'd be afraid to use anything that might create heat so it wouldn't take any temper out. I hope my service manual might give the recommended gap. Based on carbon accumulation, I think the motor had been run more than a shop run-in, but still all looked good. Some hone marks still showing in cylinders. Memories fade on details after 10-15 yrs. Cayoterun
12-06-2012, 11:23 PM | #256 |
I used a small fine tooth file for years before I bought a fancy special tool made for the job. Just make sure to file inward and keep the ends square. Also make sure the rings are square in the bore when you check the gaps.
Here is some more info. I copied from the Hastings website concerning end gaps just in case you can't find it in the manual. Ring gaps are often a confusing and misunderstood part of a rering job. There re MINIMUM and MAXIMUM ring gap specifications which must be observed for the best performance of a new ring set. Minimum gap tolerances must be observed in order to prevent the ring ends from butting together as the ring expands when the engine approaches operating temperature. Hastings recommends a MINIMUM of .0035 gap per inch of cylinder diameter. Example: 4" (bore) x .0035 = .0 14 minimum gap. Maximum ring gap is an important part of ring performance in that too much gap results in lost compression, power loss and ultimately poor oil control. The following chart indicates the specifications for compression ring gap as outlined by the SAE (Society of Automotive Engineers) as standards for the automotive piston ring manufacturers. SAE RECOMMENDED AUTOMOTIVE COMPRESSION RING GAP CLEARANCE Ring Diameter End Clearance Inspection Limit 1.0000 2.3624 .006 .014 2.3625 2.9524 .008 .016 2.9525 3.5424 .010 .020 3.5425 4.3299 .012 .022 4.3300 5.1174 .014 .026 5.1175 5.9049 .016 .030 5.9050 6.8899 .020 .035 6.8900 8.9999 .024 .041 9.0000 10.9999 .029 .047 An important fact to remember is that the manufacturers rigidly adhere to these tolerances and that the ring gaps are inspected in gauges accurate to .0001" at the cylinder diameter the ring is manufactured for. Any increase in the diameter of the cylinder is being used in, over the designated size, results in an increase of approximately .003" in ring gap for each .001" increase in cylinder diameter. In order to check ring gap, the rings should be placed at the lowest possible part of the cylinder (below ring travel area) as this is the portion of the cylinder which is unworn and which the ring is sized for. Checking ring gap in the worn portion of the cylinder will show a gap increase in direct relation to the amount of cylinder wear present. The illustration on the following page shows the effect of cylinder wear on ring gap. This graphically illustrates the effect on ring gap that cylinder wear has. You will notice that the tapered cylinder has .012 wear at the top portion of ring travel which increases the ring gap .036. Therefore, it is entirely possible for the ring to have .061 end gap in that portion of the cylinder and be within recommended manufacturing tolerance. For this reason, Hastings recommends a MAXIMUM of .003" wear per inch of cylinder diameter, not to exceed .012" in any case for successful reringing. If a cylinder is worn in excess of this it should be rebored and the proper oversize ring installed. Checking ring gaps can give an approximation of cylinder wear as well as keep you from installing wrong sized rings for the application being rerung.
12-09-2012, 02:32 PM | #257 |
Junior Member
Crazy, sneeky cracks in piston. When I was taking the rings off the broken piston, when I pulled the 3rd ring from the piston, another piece of the piston fell out. Sure left a sad looking hole. Several have agreed, I was lucky neither one had scored the cylinder wall.
I got it back together, and sounds like it should, with the typical clunky sounds. There's a noisy lifter, so will adjust them, but for now I'm a happy camper. LMB, thanks for the gap clearance chart. I'll sure print and put it in my service manual. Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. Last edited by cayoterun; 12-10-2012 at 02:46 AM. |
12-23-2012, 05:07 AM | #258 |
Junior Member
Saturday afternoon play time with Haystack, my son, and "Thumper's truck".
This is the hardest it will ever be kicked around, as long as I own it. The motor still rattles and clunks, but starts, runs and 700-R4 all runs great. We didn't hold it @2400rpm very long, so neither of us looked at the GPS, but supposed to be 73mph, top speed. What a high, and a great Christmas present!! A big THANK YOU to Rap-em-Pappy, Locomotive Breath, and all the others for helping me bring her this far. Merry Christmas to all, Cayoterun
12-23-2012, 03:20 PM | #259 |
Chevy Enthusiast
Awesome job!
Do you have any plans for a speedo?
12-23-2012, 07:45 PM | #260 |
Junior Member
Maybe sometime in the future. Having driven road-rigs years ago, we depended more on our tachs, than speedos, as you soon learn speeds from what gear, and rpm.
I do have a nice dash insert that I can swap in with a speedo, and add tach. For now, plan to work any bugs out which I'm sure will show up with some use. I'm ready to enjoy it for awhile and add a few miles on it. I've run it about 120mi. so far, within 10miles from the house. Sure sucks up the little propane tank in a hurry, so a larger one will probably be swapped in before long. Cayoterun
01-11-2013, 04:14 AM | #261 |
Nice Job on tht truck Marvin.
Jolly ~ The 6066 GMC Guy Try the 6066 GMC Guy Facebook Page Jolly's Truck & Car Show Page! |
01-11-2013, 07:52 AM | #262 |
too cool! sounds nuts, Good job, Looks awesome.
01-11-2013, 10:53 AM | #263 |
Junior Member
Welcome aboard over here, Jolly. Now you can help me keep the V-12 running. I'll probably be bugging you for pointers and advice pretty often. You've offered a wealth of knowledge since I've been working on both trucks.
Long live the GMC V-6/V-12s. and You've been a great help to us to do that! Thanks, Cayoterun
Cayoterun Okla. Panhandle I think I'll do it myself and pay the extra $500. Last edited by cayoterun; 01-11-2013 at 11:21 AM. |
05-13-2013, 05:34 PM | #264 |
Junior Member
Probably only ol' Geezers will remember when this model pickup beds looked like this, except those who lived in farming areas where they grew grain crops in the '40s and '50s. They'd haul 60-70 bushels. They'd load them up, the wife, and kids would head for the grain elevator. 65 bushels @ 60# per bushel, meant these old flivvers had 3900# on their backs.
I've run the pickup about 400mi. around here locally, and it's doing good. Still have to keep my eye on the temp gauge, tho.
05-19-2013, 12:07 PM | #265 |
Junior Member
Temperary 80gal fuel reserve tank added. I'm looking for a 30-40gal propane tank to replace the 16gal tank in front. With 2-3mpg, 16gal don't last long. Old truck doing ok for my purposes.
05-19-2013, 03:24 PM | #266 |
Just read thru your build thread,that truck is awesome!!! Not something you see everyday. I am glad you went with that body too,it really suits it.It's really something to be proud of,great job man!!!!
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
05-20-2013, 10:45 AM | #267 | |
Junior Member
This truck probably should be in alternate tinkerings, but still really don't fit anywhere. I've always enjoyed watching the old car/truck hobbiests preferences and how they change over the years. This is what we were tinkering with 50 yrs. ago during the "Jalopy" days, when bits and pieces were put together from the salvage yards. No one had any money, so learned to make do with scraps. Would be interesting to look in a crystal ball and see what they'll be building 50 yrs from now. It's really all about a great hobby, self-expression, personal preference, and enjoyment anyway, so room for all, imo. I've hauled lots of watermelons, coffee beans, and all kinds of produce to Sask., Man. and Ont. back in the early 60s. You Canadians always treated us great, and welcomed us while we were in there. Eight day turn-around from Ark.-Gulf coast/southern Florida-Regina/Winnepeg-back to Ark. $.04 cents a mile. Big bucks back then. (Two drivers, and run 24/7, except for fuel, food, and showers) Thanks for your hospitality.
05-20-2013, 01:23 PM | #268 |
We think it belongs here just fine Cayoterun...Vernski
05-20-2013, 02:50 PM | #269 | |
05-20-2013, 06:07 PM | #270 | |
Junior Member
Also, Thanks, Vernski. I plan to hang around until my junk is banned. This is a great place for us ol" Geezers to hang out, spin yarns, and tell lies. "I used to have an old '51 Ford that would-----Oh well, you wouldn't believe me anyway". (grin)
05-20-2013, 07:42 PM | #271 |
[QUOTE=cayoterun;6081459]Good Grief, You ran by the museum we volunteer at, and where the other V12 GMC 1Ton is that I donated at Boise City, Ok. Last year, they built a new by-pass around Boise City on 287. The traffic was about to shake their old County court house down as you guys went around it on the town square.
Ya,I have not been thru there since 2000, but been around the court house lots before that.Too bad I didn't know about the V12 in the museum... Posted via Mobile Device Posted via Mobile Device
05-21-2013, 01:18 AM | #272 |
I've never seen anything like this build! This is awesome!
Tyler ------------------------------------------------------ 1980 2wd blazer 1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276 1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784 |
05-21-2013, 06:34 PM | #273 | |
Junior Member
If that means your 16yo, and money is tight. Keep plugging, just think of all the stuff your learning on your truck. Money management, personal priorities, patience, determination to reach a goal, independant thinking, and hard work. Some stuff can't be learned from books, but what your learning in the "school of hard knocks" lasts a life time. Enjoy your journey with the ol' Blazer.
05-21-2013, 09:07 PM | #274 | |
05-21-2013, 10:48 PM | #275 | |
Junior Member
The best to you,
