Old 09-01-2012, 11:17 PM   #251
barnold
barnold's Avatar
Re: 2 for 1, My son's first Square Build
Where is your new shop at?
barnold is offline   Reply With Quote
Old 09-02-2012, 09:24 AM   #252
aggie91
I'm just glad to be here!
aggie91's Avatar
Brad - the shop is next door to Gymnastics world on Gilmer Road. We "plan" to be there some later today and most of Monday...
I took some pictures of yesterday's accomplishments, my real job tied me up most of the day and the wife and I had date night so not much got done yesterday.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-02-2012, 09:37 AM   #253
aggie91
aggie91's Avatar
Here is the inside of the outer rocker after coating it with Rust Encapsulator, silver is 3M weld thru primer getting ready to install the inner rocker panel:
one more look:
Covered the inside of the cab mount with RE..
Got the repaired Footwell tacked in place...I know, I need to work on my sheetmetal welding skills. I do better on the heavier stuff...
Inner rocker getting clamped into place. The flange to the left of the V is typically not bent, normaly the floor is raised in that area. We are doing something different with the floor since it was so rusted....
Inner rocker welded in. Need to make a few patches on the door sill. Hope to get that accomplished today...
Karl
The LST Challenge:
Old 09-02-2012, 03:09 PM   #254
aggie91
aggie91's Avatar
Just checked the tracking on our No Limit rack conversion, it shipped on Friday and should be here on Thursday of next week!
Karl
The LST Challenge:
Old 09-07-2012, 02:51 PM   #255
Can't kech me
Can't kech me's Avatar
we got the rack conversion in yesterday! plan on going to talk to a local tuner after school and seein if he will flash my pcm, and goin to the shop afterwards to install this rack hopefully!
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 09-08-2012, 12:21 AM   #256
Can't kech me
Talked to a tuner in town, Bluethunder2 Racing, and he's going to be doing my PCM work when i get ready, and when it comes time to get a real tune, it'll already be $100 off because he already will have the credits.
Started mounting the rack tonight, got the bracket installed, but ran into a few issues that i'll let dad elaborate more on. The biggest thing is that i need an older set of LCA's, older than 72, because the bushings are smaller and the rack will actually fit. my dad has been taking a lot of pics of the install, so when it's done i think he's going to post em.
Also started on engine mounts, should have those done soon too, then it's on to tranny mounts. i want to fire this thing so bad!
Old 09-08-2012, 11:41 PM   #257
Can't kech me
got the engine and transmission mounted finally!
going to get my pcm done soon and fire this thing! will have a vid for yall soon
Old 09-10-2012, 03:35 PM   #258
aggie91
aggie91's Avatar
Korbin had done a great job with his welding. Good strong welds. If he makes a bad one, we go back and fix it, only had to do 2 or 3...
Here are some pics of the rack install. We got the rack from Brothers, but it is a No Limit kit. The only thing the instuctions do not cover is where to drill
the frame for the bearing support. It covers the 63-72 trucks real well, but the frame on an 82 is different in the holes for the motor mounts. Pictures:
Marked the center
Korbin drilling holes
The only issues with mounting the bracket where the control arm U-bolts hits the bracket and at the lower hole on the DS
On the inside of the CM, this flange is in the way of the bolt/nut. We will cut clearence for a nut and socket when we take it apart for sandblasting.
Here are some more showing the interference with the control arm bushing. These are REALLY bigger than the 63-72 style arms. I have a set from
my 65 that we can use to finish the mock up.
Here is another of the start of a motor mounts with the engine in place...
That's all the pics we took at this time. The cab is back off and the engine and trans are mounted in the frame. We are going to work on the core support for the radiator and trans cooler, them back to the cab to finish the floor and firewall.
Karl
The LST Challenge:
Old 09-10-2012, 03:40 PM   #259
JRANGER
JRANGER's Avatar
looking good
JRANGER is offline   Reply With Quote
Old 09-10-2012, 04:20 PM   #260
made2drag
made2drag's Avatar
good progress
made2drag is offline   Reply With Quote
Old 09-17-2012, 05:28 PM   #261
aggie91
aggie91's Avatar
Got a little done this weekend. Korbin welded up holes in the cab and I worked on getting a couple of broken bolts out of the heads. Bought a new set of bolt extractors, first one worked real well got the bolt out on first try, then it went downhill from there....
The broken bolt was stuck on the extractor, so while tring to get it off I broke the extractor. Crap! I decided to use the next size up on the other bolt, started to turn the bolt (it moved a little) then I turned a little more and SNAP, the extractor broke off in the bolt still stuck in the head. I messed with it some more and poddibly did more damage then good so we called it a day and went home. Next opportunity will be Wednesday at the earliest. We are going to concentrate on the cab for now to get the floor done and the seats mounted...
Karl
The LST Challenge:
Old 09-23-2012, 08:00 PM   #262
bkilgore46
Hey Karl
This Bobby K. I lost track of you. Give me a call. (903)736-6182. I quit getting notices from this thread. I guess it had been too long since I was logged in. Had to reset my password.
bkilgore46 is offline   Reply With Quote
Old 10-01-2012, 04:48 PM   #263
aggie91
aggie91's Avatar
Bobby - just saw your post, Ill call you this week.
We made some progress this weekend. Korbin fab'd up some mounts for the radiator. We are using the one from the wrecked GMC we had. The tanks line up with the factory '82 mounts at the bottom of the core support, but did not have a place to mount the top. So he made this:
The radiator is in about the same location as it would be for the factory truck, so we are going to try factory hoses first and see what it looks like.
I worked on the floor. Korbin did a lot of the spot welding with the mig, passenger side is nearly done and the driver's side has the inner rocker replaced and the rusted areas cut out. I started the rear part of the floor and this is where we got:
We won't get back on to it till Wednesday at the earliest so I hope to get the floor done enough to set it back on the frame and do the trans hump and center of the rear floor and mock up the seats by this weekend. If we do, then its tear down time for the frame and suspension to send to the blaster.
Karl
The LST Challenge:
Old 10-06-2012, 01:34 PM   #264
aggie91
aggie91's Avatar
Quick post...we are trying to head to the Good Guys show at TWS.
We are now offically members of the Porterbuilt club. Are parts came in yesterday here is a sneak peek:
Karl
The LST Challenge:
Old 10-06-2012, 10:34 PM   #265
gringoloco
A guy with a truck
gringoloco's Avatar
Cool build, guys! If you're still having trouble getting the bolts out of the aluminum heads, try plug welding through the middle of a steel hex nut to the broken bolt. The weld won't stick to the head, you'll have a nut to grab and turn, and the heat helps break it loose...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
Sporadically present, non-dues paying member of the world-famous Louisiana Classic Truck Club (LCTC).
gringoloco is offline   Reply With Quote
Old 10-08-2012, 12:37 PM   #266
aggie91
aggie91's Avatar
Went to the Good Guys show at TWS yesterday. Good show, but the weather I think sent some home early. Korbin got a good deal on a trans cooler and we had a good time for the day. Korbin's brother Owen saw a few style he likes, he is 11 and ready to get a truck to work on. Maybe in 3 or so more years we will do the same with him.
Anyway, Here are some more pictures of the Porterbuilt Forward Arms we just got in for this project:
Last week I got some more done on the floors:
Got the center jumpseat/console in to see if the trans hump is going to clear with the new flat floor...looks like it will.
More later.....
Karl
The LST Challenge:
Old 10-09-2012, 06:27 PM   #267
76stepside01
76stepside01's Avatar
Is your new floor going to clear the frame? we had to notch mine. Looks good, love the porterbuilt stuff
76stepside01 is offline   Reply With Quote
Old 10-10-2012, 02:36 PM   #268
Can't kech me
yes we will have to notch it.
Old 10-12-2012, 04:32 PM   #269
aggie91
aggie91's Avatar
Made it to the shop last night for a short time. We got the seats mocked up in the cab and thru in the steering column. We like where the seats are in relation to the pedals, but the steering wheel is to close. Looks like we are going to modify the steering column or how it is mounted to get more room.
Here are some pictures:
Karl
The LST Challenge:
Old 10-18-2012, 09:41 AM   #270
burb1085
burb1085's Avatar
Man that trucks coming along nicely! Nice build.
burb1085 is offline   Reply With Quote
Old 10-30-2012, 04:39 PM   #271
laid67c10
laid67c10's Avatar
im from lonview as well!! cant wait to see this truck finished and cruising the streets!!
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!!
09 - Harley nighttrain on air ride!
laid67c10 is offline   Reply With Quote
Old 10-31-2012, 10:17 AM   #272
aggie91
aggie91's Avatar
Most of the floor under the seats is done. Seats/console fit, drive shaft clears and carpet should not be to difficult to do under there...Now on to the trans hump...not sure how its going to look yet...
Got our brackets for the rear C5 Corvette brakes, thanks to Clint (87chevy.com)...
We will put the cab off this week and get the frame and stuff ready for the blaster. I'll finish the trans hump off of the frame so that we can move forward with the drive train and frame. Then we will start the body work on the cab...Shoot'n for a roller with cab for Turkey Drag in Tyler on December 1 & 2.
Karl
The LST Challenge:
Old 11-04-2012, 04:48 PM   #273
Can't kech me
Also got an fbody oil pan that wont hang below the frame, mocked up the tranny tunnel with cardboard lastnight also.
Old 11-08-2012, 03:35 PM   #274
aggie91
aggie91's Avatar
Well the truck is all apart ready to go to the blaster. We have it broken down and in a bunch of pieces.
The oil pan is actually from an LSA engine and is a little different from a F-Body pan. It is 6.75" deep and should work fine for this set up. We will try to put up some pictures tonight....
Karl
The LST Challenge:
Old 11-08-2012, 11:35 PM   #275
aggie91
aggie91's Avatar
here are some pictures..
Parts ready to go to the blaster...
Karl
The LST Challenge:
project, son, square body
